[W7 撥放王者] PotPlayer 將領風騷
princewang8
[LAVFsplitter]:
http://github.com/Nevcairiel/LAVFSplitter/tree/master
Someone Takes it a TRY.
I don't know how to make it work .
TAS
"人"生淫家...
princewang8
搞不懂...
加也加不進去...
However, some other splitters register in a "bad" way and force all players
to use them. The Haali Media Splitter is one of those, and to give priority
to the LAVFSplitter you have to either uninstall Haali or rename its .ax file
at least temporarily.
似乎跟 Haali 不能並存!!要移掉 or 改名
還要 VC++ 2010
您玩一下口貝!! :):)))))
princewang8
<<<< 強大的 Codec 調節器 >>>>
因我們常常 install , uninstall 以至[註冊表] 常留下無效的鍵碼 , 會影響你 player 的穩定度
用這就可移掉它們了,當然還有其它的功能!!!
http://www.mediafire.com/?id3tf9clt330c20
kaiju2
不錯的討論﹐就是不喜歡沒有中文的POT
princewang8
不錯的討論﹐就是不喜歡沒有中文的POT
你可找對岸的[簡體版]用 ......
我不只在中文論談,寫寫東西!且常和[老外瞎掰], So....
princewang8
like this,try it
replace it in built-in source filter.
[LAVF 0.10]
Changelog
0.10 - 2010/10/26
- Added more MOV/MP4 byte markers
- Added support for multichannel PCM tracks
- Added support for DVD LPCM tracks
- Added support for usign the ArcSoft HD decoder for DTS and TrueHD tracks
- Send the proper media type for TrueHD instead of trying to connect with AC-3
- Improved H264 frame rate detection
- Improved FLAC support
- Fix loading of files with unicode characters in their names
- Fixed timestamping issues that caused certain videos to play too fast
- Fixed M-JPEG media type
- Fixed corruption with MPEG-4 ASP (DivX/Xvid) when using the Xvid decoder
For the full changelog, see CHANGELOG.txt in the download!
x86
http://www.mediafire.com/?qq24w45f9cka4kw
x64
http://www.mediafire.com/?imelu1p3opxyd01
