[W7 撥放王者] PotPlayer 將領風騷
princewang8
Changelog
0.11 - 2010/11/06
- Smart stream pre-selection based on language, flags and quality
- Properties page for configuration (languages, stream selection logic)
- Added support for AAC LATM (single stream)
- Changed the "No Subtitles" pin to a more "friendly" Media Type
- Fixed a crash with certain AAC tracks
Mr. nevcairiel say: ( MPC-HC SVN Team )
(an author of LAVF)
Hi folks,
We've been working on this for quite a while already, and i feel its time to release it into the wild for some more comprehensive testing.
LAVFSplitter is a multi-format media splitter that uses libavformat (the demuxing library from ffmpeg) to demux all sorts of media files.
The project has been growing in my mind for quite a while, until i found out that Ti-BEN from the XBMC DSPlayer team was working on this as well,
so we joined forces and developed the first prototype together. Since then some time passed, and this is the third design that came out of
our combined efforts. It is already in use in the XBMC DSPlayer branch as the internal splitter, and now available as a standalone for everyone!
At this point i would like to thank Ti-BEN for his contributions. Without his work on this project, it probably would have stayed a design in my mind.
It is planned for this splitter to eventually replace the internal splitters of MPC-HC.
( 將準備以此為 MPC-HC 之內建分離器 )
State of the project
Note that this list only lists properly tested formats/codecs, many others may just work!
- MKV/WebM, AVI, MP4/MOV, MPEG-TS, FLV, OGG are tested and will be registered for. Other formats can be tested using GraphStudio.
- H264, VC-1, MPEG4-ASP (Divx/Xvid), VP8 have been tested and are working well.
- DTS, AC3, TrueHD, MP3, Vorbis have been tested.
- Rudimentary Subtitle Support
- Stream Switching
Note:
Not all containers are equally supported, so some formats may fail in one container and work in another.
Also note that "tested" doesn't mean it won't fail eventually. There are many combinations of codecs, and its impossible to test all of them for me.
Known issues
- H264 in MPEG-TS is demuxed in AnnexB format, and thus not supported by ffdshow/MPCVideoDec. The MS H264 decoder and CoreAVC play it fine, however.
- WMV Video streams don't show any video when connected to a MS DMO decoder. (Thus, WMV will not be registered for yet)
TAS
"人"生淫家...
PotPlayer 1.5.25642 (2010.11.11)
Change Log:
+Added image overlay on screen feature (Direct3D, LayeredWindow)
+Added translucent skin function mode
+Added file information feature to playlist
+Added auto-login feature
+Added RTSP protocol
+Added chat ban function
-Fixed a proglem that some videos did not work with Winamp DSP plug-in modification
-Changed some shortcuts
-Built-in codecs as default for WMV7/8/9
-Fixed a problem that some PC were terminated when mouse right button is pressed
-Slideshow of visualization output can be modified
-Fixed in some novelties SRT subtitle reading
-Some fixs that occured while playing MPEG2 files
-Fixed a problem that when often search stopped while playing a .MP4 file
-Some fixs for Win Vista to allows more control
-Fixed a problem in Built-in subtitles that when often search stopped while playing a .mkv file
-Some fixs for built-in PAL DVD playback codec or problem behaviors
-Fixed a problem that INI saving operation was over environmental management
-Fixed H264 DXVA problem while watching TV or Video recording
-Fixed a problem that screen horde of DV files when double sound track playing
-Fixed a problem in bookmark
-Fixed a related broadcast problem
32bit
64bit
princewang8
32bit
64bit
coolbee.....
[ POT+LAVF+Reclock+MadVR + CodeAVC + (ffdshow) = The Best ] ( 就個人觀點 )
想要留 Alian 的 icon 請把上次我 po 的 exe 換回即可....
You are a PRO user. ;painkille
ps: MadVR 可惜不支援 x64
台灣台客
小弟最近升級WIN7
剛好可以來實驗看看^^
希望校能很棒!
princewang8
MR. Madshi ( author of MadVR ) 另一傑作:
---[MadFlac 1.9]---
This is a DirectShow source + decoder filter for FLAC files. It should work with any FLAC files you can throw at it and give out bit perfect results.
Supported are both external standalone FLAC files and FLAC tracks inside of containers (e.g. MKV).
http://www.mediafire.com/?4b3qqs1wv1snmmw
princewang8
---[MadFlac 1.9]---
test file:
http://www.mediafire.com/?gluvb6wlb2yrgh2
