[W7 撥放王者] PotPlayer 將領風騷
TAS
"人"生淫家...
PotPlayer+CoreAVC+madVR 0.3
KMPlayer+CoreAVC+madVR 0.3
KMP有點偏黃...
PotPlayer 1.5.23965 跑大一點的檔案跳軌太快容易當掉...Orz
TAS
"人"生淫家...
KMPlayer(X銳化+精確柔化+色階修復(亮度))+CoreAVC+madVR 0.3
PotPlayer(銳化+自動色階修復)+CoreAVC+madVR 0.3
PotPlayer(銳化+自動色階修復+色階控制)+CoreAVC+madVR 0.3
KMP有點偏黃...
PotPlayer(銳化+自動色階修復)+CoreAVC+madVR 0.3 不錯:rolleyes:
princewang8
你是用 72 吋的螢幕嘛?? 圖真大@@
madVR 0.3 開 3D Luts 開[跳動播放] 常弄 down 我的 pc , :<
howard24
Try this :)
http://madshi.net/madVR.zip
Code:
madVR v0.31
* fixed: sometimes frames were incorrectly dropped in paused state
* fixed: SoftCubic100 didn't stick for Luma up/downscaling
* fixed: media player icon was not transfered correctly from win7 to XP
* local communication is not done via TCP/IP, anymore -> no firewall problems
* the exe/dll/ax files are now signed to reduce anti virus false alarms
* added reference vs. system "clock deviation" information to OSD
* added information about estimated number of dropped/frames per second to OSD
* uninstall.bat now automatically removes the tray icon
* added new option "delay switch to exclusive mode for 3 seconds"
* renamed some settings foldersfeatures:
- high quality chroma upsampling
- high quality scaling (bicubic, mitchell, lanczos, spline etc)
- high quality YCbCr -> RGB conversion
- gamut & gamma correction for display calibration
- full 16bit processing queue
- final 16bit processing result is dithered down to RGB output bitdepth
- bypasses graphics card's video (damage) algorithms
- all work is done via GPU shaders
- no shortcuts, highest quality has priority over anything else
requirements:
- graphics card with full Direct3D9 hardware support
- at least 128MB of dedicated graphics card memory
- Windows XP or newer
disadvantages:
- slightly slower startup when using 3dlut technology (96MB file must be read)
known problems / limitations:
- no subtitle support yet
- DVD playback with navigation/menu currently only works in XP, but not in newer OSs
- hardware accelerated video decoding (DXVA) is currently not supported
- hardware accelerated deinterlacing (DXVA) is currently not supported
princewang8
1.5 24134 x86 x64 都更新
jnlyu
想問說為何 CoreAVC + madvr 是較佳的組合呢?
雖然 CodeAVC 解碼效率不錯
但可自訂的東西比 ffdshow 少很多吧?
princewang8
雖然 CodeAVC 解碼效率不錯
全掛上~~
