[W7 撥放王者] PotPlayer 將領風騷
princewang8
測試你的功力:
硬解,軟解,字幕........
( 互相研究 ) ;painkille
http://depositfiles.com/en/files/r7gunxvz4
(內建雙字幕)
(a) POT ( 原 ):
(b) POT ( 修 ):
1,DXVA 硬解
2,雙字幕
3,完美渲染
( Your Turn Now );painkille
princewang8
Code:
madVR v0.25
* added *automatic* fullscreen exclusive mode
* added optional seek bar (only for fullscreen exclusive mode)
* added OSD interface for media players
* added new options for automatic fullscreen exlusive mode and seek bar
* added rendering mode information to OSD
* added some code to avoid playback freezes
* changed Aero timing mode slightly
* changing backbuffer count now shows immediate effect
* added keyboard shortcut Ctrl+Alt+Shift+Y for switching PC <-> video levelsfeatures:
- high quality chroma upsampling
- high quality scaling (bicubic, mitchell, lanczos, spline etc)
- high quality YCbCr -> RGB conversion
- gamut & gamma correction for display calibration
- full 16bit processing queue
- final 16bit processing result is dithered down to RGB output bitdepth
- bypasses graphics card's video (damage) algorithms
- all work is done via GPU shaders
- no shortcuts, highest quality has priority over anything else
requirements:
- graphics card with full Direct3D9 hardware support
- at least 128MB of dedicated graphics card memory
- Windows XP or newer
disadvantages:
- hardware accelerated video decoding (DXVA) is currently not supported
- slightly slower startup when using 3dlut technology (96MB file must be read)
http://depositfiles.com/en/files/xklctpja3
princewang8
Daum PotPlayer 版本更新信息
[1.5.23457] 2010/08/05
+ 添加以屏幕中心位置播放功能
+ 添加保留字幕邊距功能
+ 添加直接保存 DHTV 流功能
- 修正使用EVR 渲染時寬高比計算錯誤問題
- 修正Intel GMA-HD 顯卡開啟DXVA 後黑屏問題
- 修正從右鍵菜單添加到播放列表會強制排序問題
- 修正某些電腦中無效論點報錯問題
- 修正某些VC-1 編碼視頻不能用DMO 解碼播放問題
- 修正DTS-HD 與DTS 直通功能不完善問題
princewang8
Daum PotPlayer version update information
[ 1.5.23507 ] 2010/08/11
+ Add to the center of the screen playback
+ Add to retain margins feature subtitles
+ add streaming capabilities directly save DHTV
+ add command line parameters automatically play (/ autoplay)
- Fixed some H264 TS file format for playback recognition problems
- Fixed refresh issues associated with expansion
- Fixed bookmarks / chapters identify display problems
- Fixed ARGB -> YV12 color conversion error problem
- Fix aspect ratio calculation when using EVR rendering error problem
- Fixed Intel GMA-HD video card black screen problem after open DXVA
- modified from the context menu to sort the playlist will force the issue
- Fixed some computer problems in an invalid argument error
- Fixed some VC-1 encoded video playback can not be decoded with DMO
- Fixed DTS-HD and DTS through the problem to imperfect
princewang8
Code:
madVR v0.26
* fixed: windows on primary monitor were seen as covering secondary playback
* fixed: when starting in fullscreen mode, madVR's seek bar didn't work
* fixed: starting ZoomPlayer in fullscreen exclusive mode made problems
* when "maximizing" the media player, exclusive mode is activated at once now
* exclusive mode switch is now done after 3 seconds instead of 1 second
* while exclusive mode is active, media player window is made topmost now
* windowed tweak "timing model" is now used for exclusive mode, too
* changed Aero timing mode once again
* added forced OSD display "windowed" vs. "exclusive" when switching
* new interface allows media players to ask whether madVR is in exclusive mode
http://depositfiles.com/en/files/z0w1906qb
