[W7 撥放王者] PotPlayer 將領風騷
princewang8
<< Deep Bomb >>
will be offline anytime
這種東東有這麻神奇嗎?
跑了幾遍,一些微細的副音譜,聲音都跑出來了....
唔!還是我把[鼻屎](共鳴腔加大了)挖乾淨後的因素 ;face12;
princewang8
<<< 很懶的打字,故借帖>>>
[轉貼]: poster id: 专泼冷水
百度搜了一下,才知道这是个什么玩艺:这个PC-Fi 优化软件,号称可以实时地将PC变成发烧工作站(audiophile workstation),听起来很牛,其实原理就是修改系统service,thread、I/O 优先级,还有clock 精度等等那些。
但是用起来就很傻很方便,不用你打开注册表一个个改。
打开软件后会看到有个等级选项,分别是professional、audiophile和state of art三个等级,对应不同的优化程度,等级越高,效果越明显,但对系统运行速度影响也越大。
还有两个功能框选项,可以都去掉,最后点下fidelize 就OK了,它就会自己在系统后台运行。
还有个好处就是电脑重启后所有优化选项都会还原,不会影响电脑的正常使用和安全性。
[DL]:
http://www.mediafire.com/?ora921122qikuqi
pk466610
<<< 很懶的打字,故借帖>>>
[DL]:
看了一下,還是不了解,實質作用是?
princewang8
看了一下,還是不了解,實質作用是?
有一派,說聽音樂不要用電腦訊源( 因不純淨 )
而它可說就是[淨化劑]...
我們沒發燒硬體,就用軟體實現[美聲]噜!!!
pk466610
而它可說就是[淨化劑]...
多謝解釋,不過說實在目前使用聽不出來><
princewang8
現 hdmi AMP 猛出!
很多 DD,DTS 5.1 amp 一直放出來,不乏高級機種,去2手一台
+ 兩個被動式喇叭,就嚇嚇叫了.....
princewang8
<<< MPC-HC >>>
Revision 3724 - Directory Listing
Modified Tue Sep 13 18:33:34 2011 UTC (12 hours, 26 minutes ago) by v0lt
DTSAC3Source: fixed playing time for AC3WAV
Revision 3723 - Directory Listing
Modified Tue Sep 13 18:05:20 2011 UTC (12 hours, 54 minutes ago) by v0lt
some fixes for r3721
Revision 3722 - Directory Listing
Modified Mon Sep 12 22:43:24 2011 UTC (32 hours, 16 minutes ago) by aleksoid
Change : FLVSplitter, add support FSV1(Flash screen video), ticket #271.
Revision 3721 - Directory Listing
Modified Mon Sep 12 15:58:15 2011 UTC (39 hours, 2 minutes ago) by v0lt
DTSAC3Source:
- rewritten most of the code
- added support DTSWAV (DTS-CD) (required SPDIF or AC3Filter), ticket #1683
- improved support for TrueHD (works with ffdshow and partly with LAV Audio)
- improved working with Sonic Audio Decoder 4.3
[DL]: 3724
http://www.mediafire.com/?uel56xha7k07xpf
eLove
SmoothVideo Project (SVP) v3.0.4 (09/15/2011)
- SVP Manager won't crash any more with EInvalidOp error (reported by fooladi, Fenyx, combine666);
- Fixed issue with non-latin Windows usernames (reported by dzid_);
+ Added compatibility with latest AMD Catalyst 11.8 drivers;
+ Emergency frame doubling setting added to menu;
+ Hidden settings file translated into English (asked by BipBip);
= Updated versions of components: MPC-HC 1.5.2.3456, ffdShow rev.3981, Haali Media Splitter 1.11.288.0, madVR 0.74, MVTools 2.5.11.2 (modified).
官網下載: SVP v3.0.4
SVPmark v3.0.2 (09/09/2011)
- Code updated to support latest AMD Catalyst 11.8 drivers
= Tests and scores in this version are completely equal to tests and scores of version 3.0.1
官網下載: SVPmark v3.0.2
