[W7 撥放王者] PotPlayer 將領風騷
這邊問一下有沒有人跟我一樣是
potplayer 1.5.29686
lav 0.35
madvr 0.74
設定參照TAS兄blog那篇
VGA R6970 driver 11.8 ccc>影片內全部關掉
看影片只要切到全螢幕就很容易整個卡死
後來把madvr換成EVR(CP)就好了
這邊問一下有沒有人跟我一樣是
potplayer 1.5.29686
lav 0.35
madvr 0.74
設定參照TAS兄blog那篇
看影片只要切到全螢幕就很容易整個卡死
全螢幕獨佔模式(POT和MADVR都有)有關掉嗎?
<<<< 依檔名自動切換大法 >>>
[預設方案] (一般檔案,使用內建) 當然你亦可用你喜愛的解碼
[播 RM 時] (可見到自動改為 LAV )
其它檔名可依此法另設一[設定檔]
[1.5.29769] 2011/09/23
-Captioned video playing, the error doesn't consecutive Fix
- Some ASS / SSA subtitles strange problem (fixed) output
- Improved voice modulation broadcasting
- Br tag Add to ignore
- Rather than the file view the file information, media playback enhancements
- 500M or Zip / Rar files can be modified to support
LAV Filters Changelog
0.36 - 2011/09/29
LAV Splitter
- Improved support for ADTS AAC
- Fixed MPEG-2 timestamps in VOB
- Fixed MPEG-2 frame rate reporting for telecined/interlaced
LAV Video
- Integrated NVIDIA CUVID Hardware decoder
- Performance enhancements in 10bit decoding
- Support for Flash Screen Video (FSV1)
- Support for Apple ProRes
- Improved MPEG-2 playback
- Improved A/V sync with VC-1 and MPEG4-ASP
連結:https://code.google.com/p/lavfilters/downloads/list
0.37 - 2011/10/06
LAV Splitter
- Improved handling of failures on the output pins
- Improved VC-1 in EVO timestamps
LAV Audio
- Added support for dynamic channel count changes in AAC
- Implemented support for sample format conversions
- Implemented Audio Delay options
- Disabled the WMA codecs by default
- Improved Bitstreaming data flow
LAV Video
- Fixed cropping of VP6 video
- New SSE2 YUV420 -> YUV422 converter
- Performance enhancements in the CUVID decoder on some systems
- Fixed playback with the XP Overlay Mixer
- Fixed a crash when decoding RGB video (Fraps, etc)
http://madshi.net/madVR.zip
madVR v0.76
* fixed: v0.74 stopped decoder DirectShow filter from being released properly
* fixed: PotPlayer sometimes crashed when switching video files
* fixed: internal decoders made problems with cropped MKVs & Haali Splitter
* fixed: OSD sometimes didn't appear in ZoomPlayer in exclusive mode
* fixed: VP70 decoder showed video upside down
* fixed: RGB24 input sometimes crashed madVR
* fixed: ffdshow RGB input level detection sometimes failed
* internal decoders are now auto disabled if required decoder dlls are missing
* added option to scale Luma in linear light, disabled by default
* RGB input with unknown range is now treated by default as full range
* added detailed information about matrix, primaries and levels to debug OSD
* updated libav/ffmpeg dlls
madVR v0.77
* added support for ffmpeg/libav h264 4:2:2 decoding
* optimized ffmpeg/libav compiling options
* fixed: madVR disliked getting 2 frames with identical timecodes all the time
* modified autodetect priorities slightly
