[W7 撥放王者] PotPlayer 將領風騷
pk466610
CoreAVC H.264 Video Codec - Version 3.0.0.0 (20110906)
- ADD: 9 bit support
- ADD: 10 bit support
- ADD: DXVA fallback to software
- ADD: Intel Media SDK Support (DXVA2)
- ADD: Intel GMA Support (DXVA2)
- ADD: 10 bit output format (P010)
- ADD: 16 bit output format (P016)
- ADD: Directshow dithering when filter output is downsampled
- ADD: Improved DXVA handling for interlaced streams
- ADD: Colorspace conversion from 10 bit formats to 8 bit formats
- ADD: DXVA 2 Long slice support
- ADD: Initial 4:4:4 integration (No decode support yet)
- ADD: New assembly engine
- ADD: New assembly IDCT
- ADD: New assembly motion compensation
- ADD: New assembly inter-prediction
- ADD: New assembly weighted prediction
- ADD: New assembly 9-bit
- ADD: New assembly 10-bit
- ADD: Improved assembly 8 bit performance
- CHG: Use container AR when there is no stream AR
- FIX: Improved Frame order handling
- FIX: Hardware deinterlacing field order
- CHG: DXVA increase max buffers
- CHG: Sanitize sample stop times for buggy splitters, for hardware deinterlacing compatibility
- FIX: Better recovery point handling, reduces artifacts for poorly cut streams
- SDK: Updated xcode support for iOS and OS X
- SDK: Improved APIs
- SDK: Fix: Missing APIs
- SDK: Initial support for MVC (CoreMVC) integration
Haali Media Splitter - Version 1.11.233.7 (20110830)
- FIX: Various DTS Audio bugs
- ADD: Improved DTS support
- ADD: Support for MVC 3D videos
來這吧!~http://midsofts.com/archives/coreavc-v-3-0-professional-edition-retail.html
goldenbird
請問Potplyer,看DVD時怎都沒字幕,好像開啟硬體加速,字幕就出不來
最新版也一樣出不來
自己回給自己,找到原因了
視訊解碼 MPEG2使用內建解碼器(推薦)..字幕就出來了
之前都是掛 LAV CUID 或 LAV Vedio Decoder,所以字幕出不來.
princewang8
自己回給自己,找到原因了
lav 分離器 設一下!再用 lav 解碼看看吧!!
pk466610
LAV LAV Filters 0.35 - 2011/09/07
http://files.1f0.de/lavf/LAVFilters-0.35.exe
LAV Splitter
- Fixed a crash in IAMStreamSelect::Info handling with certain applications
- Improve duration calculation for MPEG files
LAV Audio
- Fix playback of DTS streams which change the channel mid-playback
LAV Video
- Fixed a crash with 10-bit decoding and benchmarking tools
- Fixed a H264 NALU parsing issue with certain streams
我愛星期天
這軟體挺好用的~
現在都改用這個看影片
只是相關設定還在摸索中...
TAS
"人"生淫家...
我試著在 lav Splitter加入 cht chi eng 或cht,chi,eng 使用LAV CUVID或LAV Video Decoder
字冪還是出不來..
設定圖PO上來吧...
Filter 和 Subtitle的部分
不然就先reset所有設定(左下Initialize)
TAS
"人"生淫家...
[1.5.29603] 2011/09/09
- 修正點播報記憶體不足錯誤問題
[1.5.29601] 2011/09/06
- 改善字幕輸出速度
- 修正某些 FLV 播放黑屏問題
- 修正無法採集 H.263+ 視頻題
- 修正 MPEG1 文件影音同步問題
- 修正字幕超長顯示錯誤問題
- 修正某些文件影音同步問題
- 修正 H264 用多執行緒並行處理無法解碼問題
- 修正向播放清單添加文件耗時問題
- 錄製點播時可忽略直觀視頻
- 修正EVR(CP)渲染逐幀遞進問題
- 增加視窗處於半透明時的採集功能
- 修正 OGG 流無法播放問題
