FAH 硬體及客戶端綜合討論 (part 1)
阿南
回答Tuan大的問題:
合理的範圍內應該是沒差,它還壞你就想換了它吧。
回答monkp大的問題:
當初因不想增加管理的困難,所以不敢亂增加新主題,
大家都沒意見的話,2部曲會已增加新主題方式呈現。
當初的想法,同個 WU 應該會比較準,大家有任何新的測試法歡迎提出。
你怎麼知道2部曲取樣點為10%,你太神了。
monkp
... loading ...
我加了~
會出現;oq;
generic socket failure, error stack:
這個問題的出現多半是 MPI 沒安裝好, 所以 FAH 無法啟動
請大大重新安裝一次, 關閉現有的 MPICH2 服務, 再移除.
新的 client 安裝完後先執行 install.bat, 輸入您目前的使用者名稱和密碼.
如果都正確的話會出現下列的訊息:
If you see this twice, MPI is working
84036980
F@H滄者極限團隊
84036980
F@H滄者極限團隊
如果都正確的話會出現下列的訊息:
If you see this twice, MPI is...
可以了~非常感謝~
請問monkp兄~
新版SMP是不是效能較低弱?PPD平均都掉了100~300不等:confused:
monkp
... loading ...
可以了~非常感謝~
請問monkp兄~
84036980 大
您是用幾個 core 作運算?
我剛測的時候也有發現到, 但是過了一陣子後 PPD 就回復正常了, -verbosity 9 參數的運用和 FahMon 的 PPD 計算程式似乎不相容 (未證實), 海外論壇也有回報一樣的問題.
舉個例子:
[08:21:58] Completed 14%
[08:23:16] - Couldn't send HTTP request to server
[08:23:16] + Could not connect to Work Server (results)
[08:23:16] (171.64.122.74:80)
[08:23:16] - Error: Could not transmit unit 09 (completed August 3) to work server.
[08:23:16] - 7 failed uploads of this unit.
[08:23:16] - Read packet limit of 540015616... Set to 524286976.
[08:23:16] + Attempting to send results [August 4 08:23:16 UTC]
[08:23:16] - Reading file work/wuresults_09.dat from core
[08:23:16] (Read 1160621 bytes from disk)
[08:23:16] Connecting to http://171.64.122.76:8080/
[08:23:27] Completed 15%
[08:23:37] - Couldn't send HTTP request to server
[08:23:37] + Could not connect to Work Server (results)
[08:23:37] (171.64.122.76:8080)
[08:23:37] + Retrying using alternative port
[08:23:37] Connecting to http://171.64.122.76:80/
[08:23:58] - Couldn't send HTTP request to server
[08:23:58] + Could not connect to Work Server (results)
[08:23:58] (171.64.122.76:80)
[08:23:58] Could not transmit unit 09 to Collection server; keeping in queue.
[08:23:58] + Sent 0 of 1 completed units to the server
[08:23:58] - Autosend completed
[08:25:01] Completed 16%
[08:26:33] Completed 17%
[08:28:02] Completed 18%
14% ~ 16% 回報的 PPD 大約 42xx
16% ~ 18% 回報的 PPD 約 46xx
紀錄中完成的 % 訊息間隔時間都差不多, 但是, 中間多紀錄的其他訊息和時間會搞亂了 FahMon 的 PPD 計算
對了, 您是用 Vista 作業系統吧? 可以嘗試 Deino 版的 SMP 唷 ... 好像有比較快些, 據說.
補: Deino 安裝教學 (英文版) 裡頭的 Passkey 部分我正在求證中 ;) 聽說有加上去會加分 :confused:
F@H滄者極限團隊
84036980 大
您是用幾個 core 作運算?
舉個例子:
紀錄中完成的 % 訊息間隔時間都差不多, 但是, 中間多紀錄的其他訊息和時間會搞亂了 FahMon...
我是用4核跑~但我有在跑GPU所以只分配SMP 3核,
我一開始就是裝Deino~但就只要加-smp是會出現錯誤(我上面的那個錯誤) ;em44;
看來Deino還有請monkp兄研究研究~;x;
salunt
Silent Link
話說我這邊三台SMP,兩台裝一般版本,一台裝Deino
結果現在只有Deino那台正常在跑
剩下兩台都會出現
Foldinig@Home has run into a serious error running the core. and will shutdown
;oq;
84036980
F@H滄者極限團隊
結果現在只有Deoin那台正常在跑
剩下兩台都會出現
;oq;
是喔~真怪~
我Deoin只有一台裝成功~但是效能好像比較弱~PPD少了200多分~
我就把他換掉了~
ssss8kimo
GPU運算,ATI 的1.09 核心好像都沒下文...慘了;face12;
