【軟體名稱】:AIDA64 Extreme Edition 2.60.2146 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:14 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:
http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v2.60.2146 Beta 更新紀錄:
* extended CPUID features (Extended Page Table, INVEPT Instruction, INVVPID Instruction, Virtual Processor ID)
* sensor support for Nuvoton NCT6791D sensor chip
* motherboard specific sensor info for Asus P8B75-M LX
* motherboard specific sensor info for Sapphire PC-A9RD580 Series, PC-AM2RD580Adv
* improved motherboard specific sensor info for ASRock boards
* GPU information for nVIDIA GeForce GT 645M (GK107M)
* GPU information for nVIDIA GeForce GTS 150M (G94M)
* GPU information for nVIDIA GeForce GTX 650 Ti (GK106)
* GPU information for nVIDIA GeForce GTX 670MX (GK104M)
* GPU information for nVIDIA GeForce GTX 675MX (GK104M)
* GPU information for nVIDIA Quadro K600 (GK107GL)
* GPU information for nVIDIA Quadro K2000D (GK107GL)
* GPU information for nVIDIA Quadro NVS 510 (GK107GL)
* fixed: identification of AMD FX-xxxx (aka Vishera)
* fixed: identification of AMD Opteron 33xx (aka Delhi)
* fixed: identification of AMD Opteron 43xx (aka Seoul)
* fixed: identification of AMD Opteron 63xx (aka Abu Dhabi)
