[W7 撥放王者] PotPlayer 將領風騷
tqmgp
請問一下~我使用LAV 0.37 播放AC3音效時 沒有聲音 是否那裡有設定錯誤?
TAS
"人"生淫家...
去LAV設定裡看有沒有勾選AC3
tcstar22
謝謝分享嚕~~
雖然介面實在不怎麼好看~~@Q@"
TAS
"人"生淫家...
謝謝分享嚕~~
雖然介面實在不怎麼好看~~@Q@"
這不是問題...
POT和KMP一樣網路上找得到一大堆自製面板可以給你換
eLove
LAV Filters Changelog
0.38 - 2011/11/01
LAV Splitter
- New subtitle selection options (see release notes or readme)
- Improved handling of languages with more then one ISO 639-2 code (f.ex. German, French, etc)
- Improved seeking to the start of the file
- Added support for VobSubs in MP4
- Added support for MKV nested chapters
- Improved playback of RV40 in MKV
- Improved support of H264 in WTV
LAV Audio
- Fixed a crash with raw audio and SPDIF processing
- Improved support for COOK
- Improved DTS-in-WAV detection
LAV Video
- Fixed a issue that caused MPC-HCs EVR-CP to produce wrong colors when using CUVID decoding
- Support Multi-Threading and CUVID decoding for MPEG-1
- Improve decoder flushing
- Fixed a potential freeze on load and dynamic type changes
- Fixed a freeze on seeking with certain VP8 files
- Added support for UtVideo
- Added support for H264 4:2:2
Installer (both x86/x64)
Zips: 32-bit & 64-bit
eLove
SmoothVideo Project (SVP) Changelog
3.0.5 (11/02/2011)
+ Speed improvements - up to 10% faster than 3.0.4;
+ SVP-manager stability imporved significantly;
+ Log file translated into english;
- Fixed small bugs (reported by Fenyx, Reflex, farookh1, Noweol, Rimsky);
= New versions of components: ffdShow rev.3996, madVR 0.77, MVTools 2.5.11.3 (modified).
SVP 3.0.5 Full
Since version 3.0 SVP provides GPU acceleration and now it's possible to watch FullHD 1080p-video recalculated to 60Hz in real-time on any modern GPU hardware. Here is the speed comparsion (*) between CPU-only mode and GPU accelerated:
(*) FPS values based on SVPmark 3.0.2 results for FullHD (1920*1080) video 24 to 60 Hz recalculation using software decoder and "good" SVP settings.
TAS
"人"生淫家...
YA~
SVP又加快10%
現在只希望FFDShow快支援10bit...
不然SVP一定要用到他都不能同時開...
eLove
madVR v0.78
* added support for DXVA2 deinterlacing
* added option to enable/disable automatic activation of deinterlacing
* added option to force off deinterlacing for 48i sources
* added option enable/disable performing deinterlacing in a separate thread
* added auto 4:2:2/4:4:4 to 4:2:0 conversion when using DXVA2 deinterlacing
* added OSD deinterlacing information
* Ctrl+Alt+Shift+D turns deinterlacing on/off
* Ctrl+Alt+Shift+F switches deinterlacing field order (auto, top, bottom first)
* changed gamma decrease key combo from Ctrl+Alt+Shift+F to Ctrl+Alt+Shift+B
* increased decoder queue size to 12 frames
* added support for h264 10bit 4:2:2 decoding
* improved frame stepping
* improved internal frame locking mechanism
* removed warning "creating 10bit render texture failed, used 8bit instead"
* updated libav/ffmpeg dlls
