{狂}Sandy Bridge完整攻略(含除錯疑難解決)
狀態
不開放回覆。
h4513072
如果我真的能完全看懂已經不幸中的大幸了
更甭論討論了
後面的除錯篇
努力看中
alexchao5983
狂少
Bulletproof Themer
Asus M4E lastest Beta bios 1052
change log:
修正
選擇By number of active cores mode下, CPU ratio 和BCLK 一起變更時 , Reset 後會自動跳回 ALL cores mode
x33h5ddx
狂少大
小弟用4.5g 1.28v sp2004燒過
ram也用sp2004跑過一圈
設定正確都有燒到
其實1.26就能過了 但常常閒置時就直接當機了
省電都有關 問題出在哪呢?
感謝
alexchao5983
狂少大
ram也用sp2004跑過一圈
設定正確都有燒到
省電都有關 問題出在哪呢?
感謝
是當機
還是出現藍底白字
如果是藍底白字
要看它出現甚麼錯誤訊息
但我想應該還是跟你的電壓有關吧!
跑那些可以過
不代表舊電壓沒問題的哦!
這次P67系列感覺BUG蠻多的
我現在寧可電壓加高一點
也不要在時常發生當機或是藍底白字囉!
蕭中劍
舞秋月 佾江風
很棒的文章
再次感謝狂少~~~ 辛苦的解說
yym
P8P67 Deluxe / Pro / EVO / Standard / Sabertooth - 1305 -
Change Log -
- Improved OC performance using Multipliers or Auto Overclocking
- Improved BCLK and DRAM OC capabilities when enabling the “Internal PLL Overvoltage” option in BIOS. Note - Sleep/Hibernate will not operate properly due to Intel Specs.
- Improved USB performance, Improved P67 XMP profile compatibility (please note, memory with X58/P55 XMP profiles will generally work but is not optimized for P67 and will usually cause problems when overclocking in several cases)
- Per Core Save Fixed
- Disable/Enable BT
- Minor Bug Fixes including new Auto Rules for C-States (C3/C6) when overclocking. If you are overclocking, C-States will be disabled for enhanced performance.
- Intel RAID will not support bootable volumes greater than 2.2TB yet, Intel plans a firmware update shortly to allow this operation. AHCI and IDE are not affected.
- Enhanced AI Suite II compatibility
Note - These UEFI releases will be on our FTP and Support Sites shortly.
UEFI 1305 - Pro
http://www.mediafire.com/file/f9ujd5...-ASUS-1305.rar
UEFI 1305 - Standard
http://www.mediafire.com/file/74uqtk...-ASUS-1305.rar
UEFI 1305 - EVO
http://www.mediafire.com/file/uhyxd7...-ASUS-1305.rar
UEFI 1305 - Deluxe
http://www.mediafire.com/file/k84d6d...-ASUS-1305.rar
UEFI 1305 - Sabertooth
http://www.mediafire.com/file/dn39uv...-ASUS-1305.rar
a83a83cjcj
還沒睡醒...
Change Log -
- Disable/Enable BT
感謝Y兄第一時間分享給大家
雖然玩的是ASRock的主板, 但看看ASUS這邊的更新方向以及更新訊息也是很有幫助
多少可以了解原先可能存在著哪些bug是沒有注意到的,或者是補足腦中一些已知細節
(像打開PLL Over Voltage會導致休眠無法正常運作這我就沒注意到過 )
希望ASRock的BIOS也能快快完善些。
狂少
Bulletproof Themer
狂少
Bulletproof Themer
We have new official UEFI releases for the P8P67 Standard/Pro/EVO/Deluxe/Sabertooth boards today. You will not be able to roll back to an older UEFI after this update as it contains new firmware and B3 stepping compatibility. Additional UEFI releases for the balance of our P67/H67 product lineup will be released in the near future after qualification testing is complete (H67/P67M/WS). The next official UEFI update (13xx series) in the near future will feature additional user enhancements, USB drift fix and updated Marvell/Intel MEI controller firmware. I highly suggest a Clear CMOS event after loading the updated UEFI and then entering UEFI to reset your custom settings. JJ and I will have updated information on memory setups and SSD testing over the course of the next week.
1. Reset your UEFI to Optimized Defaults, reboot, enter UEFI and then flash to the new UEFI build.
2. After flash and restart, shutdown the system before you enter Windows/Linux.
3. Remover the power cord from the power supply, wait thirty seconds, press Power On button to clear any remaining charge, clear CMOS for five seconds, reattach the power cord, power on the system, enter UEFI, set to Optimized Defaults, save and exit.
4. Enter UEFI, set your system to customized settings based on your system configuration (RAID, OC, etc), save and exit.
Change Log -
- Disable/Enable BT
UEFI 1305 - Pro
http://www.mediafire.com/file/f9ujd5kn3l8kllc/P8P67-PRO-ASUS-1305.rar
http://www.mediafire.com/file/74uqtkkctbk44jv/P8P67-ASUS-1305.rar
UEFI 1305 - EVO
http://www.mediafire.com/file/uhyxd79ihfhtl58/P8P67-EVO-ASUS-1305.rar
UEFI 1305 - Deluxe
http://www.mediafire.com/file/k84d6d5dz6e17e0/P8P67-DELUXE-ASUS-1305.rar
http://www.mediafire.com/file/dn39uvqj5ciy9cl/SABERTOOTH-P67-ASUS-1305.rar
Other Releases-
P8P67 LE UEFI 1003
Change Log -
- Removes full reset at POST (double post) on cold boot or auto overclocking routine.
- Improved OC performance using Auto Overclocking
- Minor Bug Fixes including Auto Rule for C3, C6 being disabled when overclocking and improved USB compatibility.
- Enabling Internal PLL Voltage will still cause resume/hibernate issues (Intel related) but we are working with Intel on any potential workarounds.
UEFI 1003 -
http://www.mediafire.com/file/zvx22714vd7g4t7/P8P67-LE-ASUS-1003.rar
Maximus IV Extreme -Change Log -
- Improved Memory Profiles and Performance (Elpida Hyper owners, please use Red Slots for best performance, CFG Lock to Disable should improve SuperPI times)
- Minor Bug Fixes
Beta - UEFI 1090 -
http://www.mediafire.com/file/kky8cxhhe5hc20x/MaximusIV-Extreme-ASUS-1090.rar
Please note - Enabling Memory Bandwidth Boost will tighten memory subtimings and can cause non-post conditions with certain memory kits. It is currently optimized for Elpida Hyper and High Speed PSC ICs. This setting will be optimized with additional memory profiles over time and we are working on "best" settings for mainstream kits now. I recommend unless you are trying to set SuperPI records with the above kits that most users leave this option disabled. It is meant for "on the edge" overclocking.
P8P67M UEFI 0408-
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1155/P8P67-M/P8P67-M-ASUS-0408.zip
P8P67M Pro UEFI 0413-
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1155/P8P67-M_PRO/P8P67-M-PRO-ASUS-0413.zip
P8H67 UEFI 0606-
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1155/P8H67/P8H67-ASUS-0606.zip
P8H67M Pro UEFI 0410-
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1155/P8H67-M_PRO/P8H67-M-PRO-ASUS-0410.zip
AI Suite II Updates - Please Download if you are still using the Support CD version as they are optimized for use with the new BIOS updates
P8P67 Basic / PRO / EVO / Deluxe Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/utils/AISuite_II_P8P.zip
Maximus IV Extreme Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/utils/AISuite_II_M4E.zip
P8H67M-EVO Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/utils/AISuite_II_P8H67_M_EVO.zip
P8P67 Sabertooth Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/utils/AISuite_II_V10113_WindowsXP_Vista_7.zip
As always please ensure you have the latest Intel Chipset, LAN and Management Engine Interface drivers loaded.
Intel INF Update 1021 -
http://downloadcenter.intel.com/con...st_autol.exe&lang=eng&Dwnldid=19596&ProductID =3301&ProductFamily=Chipsets&ProductLine=Desktop+C hipsets&ProductProduct=Intel%c2%ae+6+Series+Chipse t
Intel Management Engine Interface Driver Update 1197 -
http://downloadcenter.intel.com/Det...tProduct=Intel®+Desktop+Board+DB65AL&lang=eng
Intel LAN Driver Update 16.0
Intel RST
(expecting updated driver set from Intel shortly)
Other-
P8P67 WS - Official UEFI 1007 (1305 will be released shortly)
ftp://ftp.asus.com.tw/pub/ASUS/mb/L...on/BIOS/p8p67-ws-revolution-asus-1007_slp.zip
P8P67M - Beta UEFI 0503
http://www.mediafire.com/?tv7mr26jv4r96tr
P8P67M Pro - Beta UEFI 0601
http://www.mediafire.com/?ii1hze5m5e8gapc
- Minor Bug Fixes including Auto Rule for C1E, C3, C6 is returned to Enabled and improved USB compatibility.
狀態
不開放回覆。
