FAH 硬體及客戶端綜合討論 (part 2)
qscgy44
我原本用5450想加入FAH的倉者團隊可是都出現This GPU is not supported這樣的錯誤訊息
然後新入手一張4850不會出現這個錯誤但是打開沒多久會錯誤是窗.按下確定就被關掉了
我有把log檔案裡面的資訊抓出來
請教各為這樣該如何解決?
[12:31:10] Loaded queue successfully.
[12:31:10] Initialization complete
[12:31:10]
[12:31:10] + Processing work unit
[12:31:10] Core required: FahCore_78.exe
[12:31:10] Core found.
[12:31:10] Working on queue slot 02 [November 5 12:31:10 UTC]
[12:31:10] + Working ...
[12:31:10]
[12:31:10] *------------------------------*
[12:31:10] Folding@Home Gromacs Core
[12:31:10] Version 1.90 (March 8, 2006)
[12:31:10]
[12:31:10] Preparing to commence simulation
[12:31:10] - Ensuring status. Please wait.
[12:31:27] - Looking at optimizations...
[12:31:27] - Working with standard loops on this execution.
[12:31:27] - Created dyn
[12:31:27] - Files status OK
[12:31:27] - Expanded 343965 -> 1740952 (decompressed 506.1 percent)
[12:31:27] - Starting from initial work packet
[12:31:27]
[12:31:27] Project: 11270 (Run 9, Clone 193, Gen 18)
[12:31:27]
[12:31:27] Entering M.D.
[12:31:33] Gromacs error.
[12:31:33]
[12:31:33] Folding@home Core Shutdown: UNKNOWN_ERROR
[12:31:36] CoreStatus = 79 (121)
[12:31:36] Client-core communications error: ERROR 0x79
[12:31:36] This is a sign of more serious problems, shutting down.
qscgy44
再請教一個問題.版上有網兄提供Windows SMP2 Bouns的教學其中有提到Bigadv要4C8T的CPU
我的I5-750只有4C4T的狀況下跑OK嗎?
ssss8kimo
我有把log檔案裡面的資訊抓出來
請教各為這樣該如何解決?
[12:31:10]
[12:31:10]
[12:31:10]
[12:31:27]
[12:31:27]
[12:31:33]
79
Gromacs error.
Deleting current work unit & continuing...
This error can occur with these lines preceding the error message above:
- Couldn't open work/wudata_xx.chk
Couldn't open for writing
Writing local files
In this case the error is caused by the core being unable to open, and therefore write-to, it's checkpoint file. Check that the permissions on the files are correct and that you didn't run out of space on the disk
This error also can be caused by memory errors which may be related to overclocking or wrong voltages or simply by bad RAM. If this error occurs when the core is just starting, there's a reasonable chance that it was an "unable to allocate" issue such as running out of space in the paging file or a memory fragmentation issue.
This error also can be caused by a WU which is corrupted during downloading.
你下載這個跑嗎 :confused:
卡有無超頻?
另外
ATI卡跑這個效率比較NV差蠻多的...
qscgy44
79
Gromacs error.
Writing local files
你下載這個跑嗎 :confused:
卡有無超頻?
另外
是跑這個沒錯 無超頻
因為跳水要玩遊戲的關係所以選這張卡.FAH是順便想加入貢獻一點
另外說不支援的型號是不是要加甚麼命令才能跑?我找不到家在哪裡
Abcb
我認為OK...
4C才是真正的運算單元啊^_^
Abcb
是跑這個沒錯 無超頻
應該是沒有支不支援的問題才對...
建議把FAH GPU程式移除後重跑看看.
記得要找出原先安裝的資料夾, 確實把內容都刪除後再重新安裝喔!!
如果問題還是依舊, 那可能是硬體上不夠穩定...
我曾遇過某張4670就是會這樣, 換一張4670就好了=_=
qscgy44
應該是沒有支不支援的問題才對...
可是它顯示的訊息確實是不支援
我爬聞看到要打一個forcegpu的命令但是不知道打在哪
5450我只有一張 影音機用的
qscgy44
請問SMP跟CPU差在哪?SMP不就是CPU在跑嗎?
爬文看到有GPU.CPU.SMP之分.不知這兩者差異
那I5-750在32BIT的WIN 7上有4G的RAM跑BIGADV的SMP會OK嗎?
還有台灣隊的網站為什麼上不去呢是不是掛掉了啊有人上的去嗎?
謝謝
ssss8kimo
謝謝
台灣隊網站? 是指論壇嗎?
很久前就停止運作囉~
目前討論集中在這邊
還有pcdvd
