FAH 硬體及客戶端綜合討論 (part 1)
tuan
CBB 銀河英雄傳説
請問VGA
超GPU CLOCK
Memory
Shader
超那種比較有効率?:confused:
monkp
... loading ...
請問VGA
超GPU CLOCK
Memory
Shader
超那種比較有効率?:confused:
F@H 只用 shader 作計算
我的 8800GS's 550/800/1375 (core/memory/shader) 平常的 PPD 值約 3800
oc shader 到 1850MHz PPD 變成 4600, 多 22%
多耗電 8.5 ~ 10W
monkp
... loading ...
最新消息
GPU 6.12 beta 8, 6.12 beta 11, SMP 5.91, SMP 5.92 明天將會過期
假如 client 持續跑的話不會影響, 但是後天新啟動時它會要求你更新 client
記得明天到官網下載新的客戶端 :)
ssss8kimo
會不會是這個原因
導致沒辦法把算好的WU更新上排行
算了一整天了=.=
那不是可以先停掉;rr;
過兩天等客戶端好了再跑;face12;
傳不上去,感覺白跑;bike;
浩雲
那不是可以先停掉;rr;
過兩天等客戶端好了再跑;face12;
傳不上去,感覺白跑;bike;
明天會更新所有客戶端
上面有說
等可以更新之後再下載新的跑好了
[14:15:39] Opening http://foldingforum.org/...
[14:16:13]
[14:16:13] Finished Work Unit:
[14:16:13] - Reading up to 1441080 from "work/wudata_01.trr": Read 1441080
[14:16:13] trr file hash check passed.
[14:16:13] - Reading up to 452128 from "work/wudata_01.xtc": Read 452128
[14:16:13] xtc file hash check passed.
[14:16:13] edr file hash check passed.
[14:16:13] logfile size: 45570
[14:16:13] Leaving Run
[14:16:16] - Writing 1939850 bytes of core data to disk...
[14:16:16] Done: 1939338 -> 1801176 (compressed to 92.8 percent)
[14:16:16] ... Done.
[14:16:16] - Shutting down core
[14:16:16]
[14:16:16] Folding@home Core Shutdown: FINISHED_UNIT
[14:16:21] CoreStatus = 64 (100)
[14:16:21] Sending work to server
[14:16:21] Project: 4730 (Run 9, Clone 4, Gen 25)
[14:16:21] - Read packet limit of 540015616... Set to 524286976.
[14:16:21] + Attempting to send results [August 1 14:16:21 UTC]
[14:16:59] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=133977...
[14:17:00] + Results successfully sent
[14:17:00] Thank you for your contribution to Folding@Home.
[14:17:00] + Starting local stats count at 1
[14:17:04] - Preparing to get new work unit...
[14:17:04] + Attempting to get work packet
[14:17:04] - Connecting to assignment server
[14:17:19] + Could not connect to Assignment Server
[14:17:33] - Successful: assigned to (171.64.65.103).
[14:17:33] + News From Folding@Home: GPU folding beta
[14:17:33] Loaded queue successfully.
[14:17:36] + Closed connections
[14:17:36]
[14:17:36] + Processing work unit
[14:17:36] Core required: FahCore_11.exe
[14:17:36] Core found.
[14:17:36] Working on queue slot 02 [August 1 14:17:36 UTC]
[14:17:36] + Working ...
[14:17:37]
[14:17:37] *------------------------------*
[14:17:37] Folding@Home GPU Core - Beta
[14:17:37] Version 1.04 (Fri Jun 6 15:46:09 PDT 2008)
[14:17:37]
[14:17:37] Compiler :
[14:17:37] Build host: amoeba
[14:17:37] Preparing to commence simulation
[14:17:37] - Looking at optimizations...
[14:17:37] - Created dyn
[14:17:37] - Files status OK
[14:17:37] - Expanded 41092 -> 231745 (decompressed 563.9 percent)
[14:17:37] Called DecompressByteArray: compressed_data_size=41092 data_size=231745, decompressed_data_size=231745 diff=0
[14:17:37] - Digital signature verified
[14:17:37]
[14:17:37] Project: 4731 (Run 0, Clone 79, Gen 91)
[14:17:37]
[14:17:37] Assembly optimizations on if available.
[14:17:37] Entering M.D.
[14:17:43] Working on 544 p4731_fip35_ww_domain
[14:17:43] Client config found, loading data.
[14:17:43] Starting GUI Server
這是剛跑完的結果
monkp
... loading ...
那不是可以先停掉;rr;
過兩天等客戶端好了再跑;face12;
傳不上去,感覺白跑;bike;
GPU 的 WU 期限通常只有三天
還是想辦法讓它傳回去吧 :PPP: :PPP:
