CPU/SMP 高獎勵得分 選購/設定/除錯...集中綜合討論串
Abcb
小弟跑了一個多月也沒收到P10114,
大大可否提供多一點資訊.
您跑的SMP版本是不是6.34? 我是改跑6.34之後才收到P1XXXX...
不過6.34卻讓我遇到個問題, 那就是會有算完的WU, 但伺服器端卻因為沒有記錄而不收.
我兩台跑SMP的機器都遇到, 看來應該是新版軟體發佈後的配套工作沒做好?
Nightstalker
對.......小弟已更新到SMP 6.34.
就是收不到P10114,
不過如果像Abcb大那樣因為沒有記錄而不收,
收不到看來是好事:PPP:
j0413865888
[12:15:01] + Attempting to send results [March 17 12:15:01 UTC]
[12:15:01] - Reading file work/wuresults_00.dat from core
[12:15:02] (Read 95885356 bytes from disk)
[12:15:02] Connecting to http://130.237.165.141:8080/
[12:15:02] - Couldn't send HTTP request to server
[12:15:02] + Could not connect to Work Server (results)
[12:15:02] (130.237.165.141:8080)
[12:15:02] + Retrying using alternative port
[12:15:02] Connecting to http://130.237.165.141:80/
[12:15:06] - Couldn't send HTTP request to server
[12:15:06] + Could not connect to Work Server (results)
[12:15:06] (130.237.165.141:80)
[12:15:06] Could not transmit unit 00 to Collection server; keeping in queue.
已經兩天連不上了,我該怎麼辦
oegg
2684 總比 抓不到 WU 好, 繼續跑囉...
我兩個不到 10% 都是今天才下的 WU...
Server 應該沒問題吧?!
lchiang
[15:08:32] + Attempting to get work packet
[15:08:32] + No unsent completed units remaining.
[15:08:32] Passkey found
[15:08:32] - Autosend completed
[15:08:32] - Will indicate memory of 6135 MB
[15:08:32] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 4
[15:08:32] - Connecting to assignment server
[15:08:32] Connecting to http://assign.stanford.edu:8080/
[15:08:33] Posted data.
[15:08:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:08:33] + Couldn't get work instructions.
[15:08:33] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[15:08:53] + Attempting to get work packet
[15:08:53] Passkey found
[15:08:53] - Will indicate memory of 6135 MB
[15:08:53] - Connecting to assignment server
[15:08:53] Connecting to http://assign.stanford.edu:8080/
[15:08:53] Posted data.
[15:08:53] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:08:53] + Couldn't get work instructions.
[15:08:53] - Attempt #2 to get work failed, and no other work to do.
[15:09:12] + Attempting to get work packet
[15:09:12] Passkey found
[15:09:12] - Will indicate memory of 6135 MB
[15:09:12] - Connecting to assignment server
[15:09:12] Connecting to http://assign.stanford.edu:8080/
[15:09:13] Posted data.
[15:09:13] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:09:13] + Couldn't get work instructions.
[15:09:13] - Attempt #3 to get work failed, and no other work to do.
[15:09:47] + Attempting to get work packet
[15:09:47] Passkey found
[15:09:47] - Will indicate memory of 6135 MB
[15:09:47] - Connecting to assignment server
[15:09:47] Connecting to http://assign.stanford.edu:8080/
[15:09:47] Posted data.
[15:09:47] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:09:47] + Couldn't get work instructions.
[15:09:47] - Attempt #4 to get work failed, and no other work to do.
[15:10:42] + Attempting to get work packet
[15:10:42] Passkey found
[15:10:42] - Will indicate memory of 6135 MB
[15:10:42] - Connecting to assignment server
[15:10:42] Connecting to http://assign.stanford.edu:8080/
[15:10:43] Posted data.
[15:10:43] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:10:43] + Couldn't get work instructions.
[15:10:43] - Attempt #5 to get work failed, and no other work to do.
[15:12:06] + Attempting to get work packet
[15:12:06] Passkey found
[15:12:06] - Will indicate memory of 6135 MB
[15:12:06] - Connecting to assignment server
[15:12:06] Connecting to http://assign.stanford.edu:8080/
[15:12:07] Posted data.
[15:12:07] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:12:07] + Couldn't get work instructions.
[15:12:07] - Attempt #6 to get work failed, and no other work to do.
小弟的其中一個SMP client也收不到WU, 不過這台主機CP不夠快, 所以沒跑bigadv....乾脆先關機, 明天早上在看看...
OverFold
難怪早一星期前i7-860那組完成BigAdv後說Server Problem不接受,
累我白算了多天並白白浪費了該已完成之WU,唉~只怪自己急於更新SMP版本之過....
dinoking
不能再敗了
最近換一張gts450跑GPU3, Forceware 267.59顯卡驅動.額外參數設 -verbosity 9 -forcegpu nvidia_fermi, 現在穩穩跑可以 8000+ PPD, 差不多2分14秒增加1%進度,但是有時候會變慢 30~45分才增加1%???? 不知道那裡出問題???
xs910203
我也遇到過~直接把這台的砍了!
別他算到一半的拉過來繼續算就好了
不同WU的關係!?
Abcb
GTS450跑到再怎麼痛苦的WU都應該不會是30分鐘甚至以上才1%...
我曾經遇到的情況是顯示卡進入了省電模式, 這時候時脈相當低, 才有可能會30分鐘以上1%...
偶爾會遇到, 不過不太常見. 用檢測軟體看一下吧... 不然去抓微星的Afterburner看看囉^_^
dinoking
不能再敗了
如何關掉顯卡省電模式;x; Thanks~~
