ZIPPY PSL-6850P G1 demo
滄者小蟲
心情區版主
哇靠
現在台灣還買的到比它大瓦數的電供嗎
850瓦
真高檔
wwweagle
新巨出品...台灣製造...一級棒
這是我對他們power的評價
狂少
Bulletproof Themer
大哥..這顆不錯...不過輸我在用的一點點點點... ;em03;
官網:
http://www.zippy.com.tw/P_product_d...name=3U Single&pcpw_rfnbr=6&pp_code=P3M-9950P
Features:
•TEMPERATURE RANGE: OPERATING: 0℃ --- 40℃ STORAGE: -20℃ --- 80℃
•HUMIDITY:OPERATING:20%-95%, NON-OPERATING:10%-95%
•REMARKS:85% IS NORMAL CONDITION AND 95% IS WITH SPECIAL COATING PROCESS
•HOLD UP TIME: 16 ms MINIMUM AT FULL LOAD & NORMAL INPUT VOLTAGE
•DIELECTRIC WITHSTAND: INPUT / OUTPUT 1800 VAC FOR 1 SECOND
INPUT TO FRAME GROUND 1800 VAC FOR 1 SECOND
• EFFICIENCY: 70% TYPICAL AT 115VAC FULL LOAD
•POWER GOOD SIGNAL: ON DELAY 100 ms TO 500 ms, OFF DELAY 1 ms
•OVER POWER PROTECTION: 110% ~ 150%
•OVEROVER VOLTAGE PROTECTION: If an over voltage fault occurs,the power supply will latch all DC output into a shutdown state.
•EMI NOISE FILTER: FCC CLASS B CISPR22 CLASS B
•SAFETY: UL 1950, CSA 22.2 NO/ 950, TUV IEC 950
•REMOTE ON / OFF CONTROL
THE UNIT SHALL ACCEPT A LOGIC OPEN COLLECTOR LEVEL WHICH WILL DISABLE / ENABLE ALL THE OUTPUT VOLTAGE (EXCLUDE +5V STANDBY),
AS LOGIC LEVEL IS LOW, OUTPUTS VOLTAGE WERE ENABLE,
AS LOGIC LEVEL IS HIGH, OUTPUTS VOLTAGE WERE DISABL
這顆摸到會死倫...我把它拆下來 ;face12;
Zippy 3u single 950w
看一下output:
test:
1. 3.3v
2. 5v
12v
cpu temp:
vcore:
quite a good result, during the run, those voltage looks like "lock up" never change.
certainly, we can't omit super pi 32m..
during the run:
zshing
狂少 說:
看一下output:
950w +12V1 28A , +12V2 42,規格真漂亮. CPU 跟 其他裝置 都很夠用 ;nq;
古虛懷
療傷...
大家比高W的
;face12;
比較好超就對了;x;
jusy
新巨出品的POWER評價超好的
我都用他們的POWER
Second2
古虛懷 說:
大家比高W的
;face12;
比較好超就對了;x;
好像是喔! ;0a155537;
LSI狼
zshing 說:
這顆是合體POWER,把2U跟1U的兩顆POWER合併起來。
zshing
LSI狼 說:
請問狼大在cpu , vga 高耗電量下,不知會不會比1U 850w好用? ex:壓降問題.
