主機板 某大夢寐以求的Z68 ITX 主機板 ZOTAC Z68-ITX WiFi 和 Z68-ITX WiFi Supreme
m2315961
特級會員
前陣子就已經發現到有這兩張坂子的消息,相信本站的某大哈這個版子已經很久了,但是到現在才發,恩....... 好像有點太晚,本人因為工作勞累就隨便傳訊息上來給大家知道,圖文來源都是從ZOTAC的官網抓回來的,不多做贅述,請各位大大見諒......
第一款:
Z68-ITX WiFi 圖:
規格:
Model
Model Z68ITX-A-E
Chipset
Manufacturer Intel
Chipset Z68 Express
GPU Intel® HD Graphics 2000/3000 ready
CPU Compatibility
Name 2nd Generation Intel® Core™ series
2000 Series Intel® Core i3, i5 & i7 ready
Support up to 130-watt TDP
Socket LGA1155
Front-side bus
Memory
Memory Type DDR3
Memory Speed 2133 MHz
Slots 2 x 240-pin DIMM
Capacity Up to 16GB
Expansion
Expansion Slots 1 x PCI Express x16
1 x Combo mini-PCI Express / mSATA (occupied by WiFi card)
3D API
DirectX DirectX 10.1
OpenGL OpenGL 2.1
Networking
Ethernet 2 x 10/100/1000 Mbps
WiFi 802.11n/g/b (300 Mb/s)
Audio
Analog 8-ch HD
Digital S/PDIF
Ports
DVI NA
HDMI 2 (HDMI 1.4a)
VGA NA
DisplayPort 1 (min-DP)
SATA 2 (SATA 6.0 Gb/s)
2 (SATA 3.0 Gb/s)
eSATA NA
IDE N/A
PS/2 1 (keyboard/mouse)
Serial Port NA
USB Ports 4 USB 3.0 (2 on back panel, 2 on pin header)
8 USB 2.0 (4 on back panel, 4 on pin header)
Firewire N/A
Cooler
Cooler Passive (without fan)
Form Factor
Form Factor mini-ITX
OS Compatibility
Windows Windows® Vista/7 premium ready
General
SLI Supported No
Maximum Resolution 2048x1536
Other
Wake-On Support
Overclocking features
Packaging
Package Contents 4 x SATA cables
1 x I/O back plate
2 x WiFi antennas
1 x 8-pin power extension cable
1 x USB 3.0 header (full-size bracket)
1 x USB 3.0 low-profile bracket
1 x Vertical mini-PCI Express full height bracket (for mSATA SSDs)
1 x mini-DisplayPort to DisplayPort adapter
第二款:
Z68-ITX WiFi Supreme 圖:
規格:
Model
Model Z68ITX-B-E
Chipset
Manufacturer Intel
Chipset Z68 Express
GPU NVIDIA® GeForce® GT 430 w/1GB DDR3
CPU Compatibility
Socket LGA1155
Front-side bus
Memory
Memory Type DDR3
Memory Speed 1333 MHz
Capacity Up to 16GB
Expansion
Expansion Slots 1 x PCI Express x4 (open-end)
1 x Mini-PCI Express (occupied by WiFi card)
1 x mSATA
3D API
DirectX DirectX 11
OpenGL OpenGL 4.1
Networking
Ethernet 10/100/1000 Mbps
Audio
Analog 8-ch HD
Digital S/PDIF
Ports
DVI 2
HDMI 1 (HDMI 1.4a)
VGA (With included adapter)
DisplayPort 1
2 (SATA 3.0 Gb/s)
eSATA NA
IDE N/A
Serial Port NA
4 USB 2.0 (2 on back panel, 2 on pin header)
Firewire N/A
Cooler
Cooler Active (with fan)
Form Factor
OS Compatibility
General
SLI Supported No
Maximum Resolution 2560x1600
Other
Wake-On Support
Packaging
1 x I/O back plate
2 x WiFi antennas
1 x 4-pin power extension cable
1 x DVI-to-VGA adapte
zyx1487
低等會員
三大不知何時才出MINI-ITX的Z68;ng;
再不出就跳APU;tongue;
superbn
斌仔
Oh~~~這個也是超想要的... 之前的wifi 小板 用到現在 非常滿意..
isaf03
YOOOO~等好久了。
pigfoot
小板魔人的最愛 ;nq;
ccbxeon
呵呵~剛好正需要這種板子
等3大廠的ITX板子囉
aa11ss22
挖我從來沒碰過小板
DRAM要買小張的嗎??
ccbxeon
這兩款Z68 ITX預計6月底會上市
到時再買來試玩看看囉
zyx1487
低等會員
這兩款Z68 ITX預計6月底會上市
到時再買來試玩看看囉
ccbxeon大確定要買囉
價格你有去詢問了優
PM一下八
我也想買WIFI那張但看到是索泰就呵呵;em44;
Happypc
********.com低階會員
