[W7 撥放王者] PotPlayer 將領風騷
松山ACT
如果真的要比
我比較喜歡POWERDVD這一套軟體
princewang8
TAS
"人"生淫家...
我想喜歡"自訂"的才會比較愛用POT或KMP這類的
不然懶得調有的沒的話PowerDVD就可以適用大部分"正常"格式了
starsing
敢想敢要敢得到
www.facebook.com
很多人該是不會調…才對…而且有時候的POWERDVD的字暮調不出來?
princewang8
DVB support 站上的統計
ps:[ lav 0.28] is out
princewang8
恩…設定ok(原來不知道設定那個,直接在解碼器優先權,強制使用就好了)
…不過…內建的音效卡&喇叭真的蠻糟的…設定32位元會破音...;oplc;
內建第三代<模擬>;smash;杜比環繞音效技術...這要說是廣告不實嗎...;director;
換個這個.....
princewang8
轉貼部份
org: http://www.homecinema-hd.com/reclock_en.html
II. Reclock Configuration
I will follow the settings in order and explain.
A. Audio Settings tab
Audio Interfaces to use for
•PCM : WASAPI Exlusive◦In analog - HDMI PCM will here the sound in stereo and 5.1. If you have XP you can put KernelStreaming.
•Bitstream : WaveOut◦Digital S/PDIF - HDMI in stereo and 5.1 the sound decoded, resampled and reencoded to AC3 by reclock send the sound by WaveOut output. In Bitsream sound pass here without being modified.
Devices to use with
•WaveOut : Realtek Digital Output (RCA)◦You have to choose your output, HDMI, S/PDIF. The sound will be sent to the receiver either decoded, resampled and reencoded in AC3, either without modification in Bitstream.
•WASAPI Exclusive : Haut-parleurs◦You have to choose your output, analog or HDMI PCM. Decoded and resampled sound will be sent in stereo and 5.1 by this output. For MPC-HC 2.0 you have to choose your analog output (for headphones, speakers 2.0...)
Sound pre-buffer
•Duration : 500 ms // Leave like that.
Max Latency
•PCM : 20% // Leave like that.
•Bitstream : 5% // Leave like that.
PCM Output
Analog - HDMI PCM remember to configure your sound card with the same parameters as Reclock (Format et Sampling Rate).
•Sampling rate : 96khz // If your sound card supports it. Otherwise turn down until it's ok (48khz).
•Format : 24 bit int padded to 32 // If your sound card supports it put "24 bit int padded to 32" otherwise put "16 bit int".
•Quality : Best Sinc Interpolation // Determines the resampling quality.
•Output mono source to both front chnnels // You can check it, it's allow to output mono on front speakers.
•Set matching speakers configuration // In analog - HDMI PCM check it. In digital HDMI - S/PDIF don't check it.
•Time Streching // Attention it deteriorates a bit the sound quality I don't advise to check. This feature will help to keep the sound pitch when you speed up or slow down the film. Normally when we slow down from 25 to 24fps should not check when slowing down and when speed up from 23.976 to 25fps should check when speeding up.
•Use AC3 encoding // If you are in analog - HDMI PCM - Bitstream don't check this box. But if you're in digital HDMI - S/PDIF (not bitstream) is this option that will allow you to get the sound via the S/PDIF by re-encode it to AC3.
•Only with multi-channel sources // Leave unchecked.
Bitstream
•Accept bitstream formats // Check this option only if you are in Bitstream. It is to pass the AC3/DTS directly by S/PDIF - HDMI if you do not decode before. It will not be resampled so make sure that the TV frequency is the same or a multiple as video.
•Disable media speed correction with bitstream audio // Check this box if you are in bitstream to reclock don't touch the video.
jamesfuh
[1.5.28663] 2011/06/10
+ 添加虛擬 杜比/環繞/耳機 輸出
+ 添加用戶自定義 DVD導航/HDTV分離器 功能
+ 添加支持 AMR 音頻播放
+ 添加立體字幕輸出功能
- 在 MP4/MOV 中支持了EAC3
- 修正被誤識別為H.264 的 MPEG2 視頻
- 修正 GMA 4500 顯卡上H.264 使用 DXVA 問題
- 改善 WTV 文件播放能力
- 將安裝包改為 Unicode 編碼
- 修正某些 MP4/MOV 影片時間識別錯誤問題
- 改善 點播/HTTP流媒體 下載速度
- MPEG2 TS 分離器支持 AAC LATM 解析
- 修正 TV吧 視頻縮略圖顯示問題
- 修正可自由設置點播的分辨率
- 修正某些 LPCM 音頻低速播放問題
- 修正某些 AVI 文件反交錯出錯問題
princewang8
[重覆了] 請無視 :mad:
