[W7 撥放王者] PotPlayer 將領風騷
princewang8
starsing
敢想敢要敢得到
www.facebook.com
CoreAVC 2.51...
還是沒辦法開mkv檔…等待更新中~
暫時先用406、407樓的解決辦法~
styx
Rockin'The Paradise
真的有比KMPLAER好嗎?來試看看~~Thanks
jamesfuh
[1.5.27433] 2011/03/30
+ 添加 FFmpeg-MT 解碼器支持(MPEG4, VP3, Theora, HUFFYUV)
+ 添加 ATI Radeon HD 6xxx 系列顯卡MPEG4 DXVA 支持(待完善)
- 修正某些 MP4 在播放中出錯問題
- 修正某些 PC 中 BASS 存在的兼容問題
- 修正某些 H264 輸送到 VGA 後加速顯示問題
- 修正因打開無效書籤引起的鎖死問題
- 修正錄製點播時畫面變得很卡問題
jamesfuh
[1.5.27459] 2011/04/05
- 修正某些 MP4 在播放中出錯問題
- 修正因打開無效書籤引起的鎖死問題
- 修正錄製點播時畫面變得很卡問題
princewang8
<< LAV audio decoder>> powerful mate
jamesfuh
[1.5.27750] 2011/04/15
+ 添加 DXVA 支持在無渲染模式下工作
+ 添加 HTTP Live 流媒體播放功能
- 修正某些 MP4 在播放中出錯問題
- 修正因打開無效書籤引起的鎖死問題
- 修正錄製點播時畫面變得很卡問題
- 修正某些 GMA 顯卡以 VGA 輸出時 H264 兼容問題
princewang8
<<< [ maybe better than CoreAVC for NV ] ( You should give it a TRY) >>>
Changes in LAV CUVID Decoder 0.4:
- Frames flagged as progressive will not be doubled anymore (Fixes playback of streams with forced pull-down flags)
- Fixed an issue that could cause a crash in media type handling
• LAV CUVID Decoder 0.3
- Improved decoding performance by up to 40%
- Added "Double Framerate" Deinterlacing
- Added a DXVA Interoperability mode, which increases deinterlacing quality.
- Added an option to control the field order supplied to the deinterlacer.
Important Note:
- This is a decoder for NVIDIA GPUs, it does not work with ATI/AMD or Intel, and it never will!
[DL]: 0.4
http://www.mediafire.com/?j8l5p6huq1rp6yj
starsing
敢想敢要敢得到
www.facebook.com
it does not work with ATI/AMD or Intel, and it never will!....=0=
