太棒了![]()
【軟體名稱】:TMPGEnc Authoring Works v4.0.9.37 Retail
【軟體語言】:英文
【軟體分類】:影片視訊編輯製作
【檔案大小】:106 MB
【檔案類型】:RAR壓縮檔【WinRAR CHT&CHS (32+64bit+Portable)】【7-Zip 9.10 beta (32+64bit)】
【解壓密碼】:***回覆後可見***
【官方網頁】:http://tmpgenc.pegasys-inc.com/en/product/taw4.html
最強大的DVD制作軟體TMPGEnc DVD Author不僅可以將通過電腦錄制的電視節目,通過各種影片編輯軟體制作的數碼影片文檔,家用DVD或硬盤錄像機錄制的電視節目作為素材,支撐您原創的視訊DVD,同時還支持制作DivX ULTRA光盤。
在前版本TMPGEnc DVD Author 3.0 的基礎上、強化了重要功能,並增加了眾多新功能。是一款既適用于初學用戶也使專業用戶感覺得心應手的產品。
■易懂易用的用戶界面
■豐富多樣的菜單模板
■選單中兼有筆記功能
■支持字幕編輯和輸出輸入
■通過我公司獨自技術SmartRendering實現的精確到畫格的剪輯功能節省最多的再編碼時間(DVD/DivX)
■轉碼(Transcode)處理整合輸出數據量提高光盤使用效率(只適用於DVD-Video)
■支持單面雙層DVD±R 的 DVD-Video 刻錄制作
■支持 DivX ULTRA 數據輸出以及在 DVD/CD 上的刻錄
Full Featured:
• Input MPEG-1/2, AVI, WMV, QuickTime, DivX, MPEG-4/H.264, AVCHD, DV/HDV, DVD-VR, DVR-MS video files and author to DVD-Video, Blu-ray (BDMV), and DivX Ultra formats.
• Camcorder AVCHD/HDV/DV video input support.
• Creates high quality DivX video.
• Edit out unwanted scenes or commercials.
• Create interactive menus from templates or make your own custom menus.
• Add or edit subtitles.
• Make your own slideshow DVDs and Blu-ray Discs in standard or high definition.
• Apply audio filters such as gap correction, noise reduction, and fade-in/out.
• 5.1 Dolby Digital Surround sound input/output.
It's Better With Blu. Plus more new features.
• Author your favorite AVCHD, HDV and DV camcorder footage to the high-capacity Blu-ray Disc format.
• Create HD menus complete with pop-up menus that you can access during playback.
• Or how about making your own HD slideshows? It's all possible with Blu-ray Disc.
Changes in Version 4.0.9.37 - March 4, 2010:
Added Input support for the Microsoft TV recorder file format "WTV". (WTV file importation is possible on the computer that recorded the file, or can create such files, and are not copy-protected.)
Improved Improved memory usage for when the memory is too low, "Insufficient memory," "Invalid sample format," or other errors would display. Because of this improvement:
Memory usage has been dramatically lowered when enabling the "Clip linking" option of the Track settings.
The negative affects of large memory address space usage are limited, especially in Windows XP.
Memory usage has been lowered when registering a large amount of chapters in a project.
Limits the usage of the file importation cache when the host computer contains a large memory.
Improved Updated the MP4/AVCHD file reader. This new version:
Allows the reading of some files that could not be imported before.
Fixes a doubled playback speed issue.
Fixes a pink video noise appearing in certain configurations.
Fixes a bold stripe pattern noise appearing in certain configurations.
Improved YUV color space information contained in the source file is now taken in account when imported through the MP4/AVCHD File Reader. If no color space information is available, the BT.709 or SMPTE 170M color space is automatically selected according to the pixel rate.
Improved The MPEG file reader can now import a PTS data-only MPEG file.
Improved The Dolby Digital decoder continues outputting audio even after encountering corrupted data.
Improved Some specific chapter thumbnail pictures from certain DVD-Video data could not be imported.
Improved Following a silence, the audio uniformization filter could highly increase the volume, resulting in an explosion-like effect. The improved filter reduces the occurence of such an issue.
Improved Updated Disc writing tool. It would output an error log under Windows 7 64-bit.
Improved Prevents the computer from going into stand-by mode when the output Autoresume is enabled. (This improvement has been added to the Batch authoring tool too)
Improved When an optical drive is absent, outputting an ISO image file no longer makes the Disc writing tool unresponsive at the end of the output.
Fixed Some anti-virus applications would prevent the correct writing of DVD-Video files.
Fixed The Batch authoring tool no longer displays a warning that would stop the output when starting the batch.
Fixed In certain cases where there are long-duration clips, an insuficient memory error would occur during the authoring process.
Fixed The video would not display correctly when using the high speed rendering mode in the cut-edit or preview window. This problem would appear only with certain graphic cards.
Fixed Other minor fixes.
Good Thanks
