sogood 說:
說opteron不支援C'N'Q
可是這一期電X王雜誌上測試說可以耶!
這是怎麼回事???
小弟本來也以為不支援cnq.到處去爬文也灌了powernow還是沒作用.就把速龍64的cnq驅動拿來試試.設定最小電源管理.居然有作用.真是太好了.關於驅動的說明如下.供大家參考..
AMD Athlon™ 64/Sempron™/Turion™ 64/Opteron™ Processor Driver
Version 1.2.2
(Windows® XP, Windows® Server 2003)
DESCRIPTION:
This driver supports processor performance control via the processor objects defined in the ACPI 2.0 specification.
REQUIREMENTS:
1) AMD Athlon™ 64/Sempron™/Turion™ 64/Opteron™ systems with ACPI 2.0 processor performance control objects
2) Windows XP or Windows Server 2003
KNOWN Windows XP LIMITATIONS:
1) "System Properties" reports wrong processor speed.
For more information, please refer to the following website:
http://support.microsoft.com/default.aspx?scid=kb;en-us;303602
2) The Processor speed may be reported incorrectly in Windows XP.
http://support.microsoft.com/default.aspx?scid=kb;en-us;316965
3) If not running ServicePack 2 (SP2), the processor performance state may not be restored to the maximum state if the CPU runs at 100 percent. This problem occurs if the computer is 100 percent busy when the power policy changes.
For more information and support options, please refer to the following website:
http://support.microsoft.com/?kbid=330512
NOTE: As with all driver installations on Windows XP or Server 2003, you need to login as Administrator or have administrator rights for your domain login.
REVISION HISTORY:
Version 1.2.2.0 – 3/09/05
Added support for multi-core processors and software thermal control
Version 1.1.0.18 – 8/16/04
Added MP support for Opteron
Version 1.1.0.14 – 5/11/04
Fixed issues with Portuguese and Hebrew
Updated signature files
