**真的懶的翻中文了,不懂的問C大; C大現在英文一把罩(先挖個洞給他跳;bike; 快酸;em25; )
hello guys, here is the brief explanation about how to obtain the 500 fsb onto the great Asus board ,
p5b deluxe for only on decent air cooling.
Actually, if you don't mod, then it won't be the big deal as well. Am I serious,? yes. let's see.
let see the picture and mods.
about the mods, very important, if you mod the vdroop, you gotta mod hte vcore as well to ensure
the vcore stable.
1. let's get everything ready.
you will need a nice cooler and fan: The NH-u12 and panaflo
certainly excellent DDR2;)
A good cpu can handle 500 FSB without pain ( I am lucky that I got couple L624a610 or L624a609
x6800)
OF course a P5b dx with " 0505 or 0507 bios)
ok now, let see , before that, here are some drawbacks that p5b dx got:
A. it is still not supported by clock-gen, so you will need to boot it from BIOS
B. memset 965 can't be used, cuz once I change any timings , whole system freeze
Under bios: Vcore depends,
the key points is mch need 1.65v
FSB termination volt do not use over 1.4v
SB volt need to be around 1.7v
so let 's see the simple super pi 1m 4g , 8x500, ddr1000 4-4-3@ 1.54v vcore and 2.3v for vdimm
how about 8m?
from the ready to run;); see that vcore is 1.54v?
not showing how strong my cpu is, but it's the point that you need to mod the vdroop and vcore
together , you will see during the run, vcore will NOT drop but raise .:D
so for 32m, all you need is raise some vcore and run it. Hope this helps.
Completely no tweak super pi
the vcore stable.
x6800)
how about 8m?
