K-Lite Codec Pack Standard/Basic/Full v2.43
K-Lite Codec Pack is a collection of codecs and related tools. Codec is short for Compressor-Decompressor. Codecs are needed for encoding and decoding (playing) audio and video. This Codec Pack is designed as a user-friendly solution for playing all your movie files. You should be able to play all the popular movie formats and even some rare formats.
The K-Lite Codec Pack has a couple of major advantages compared to other codec packs: It it always very up-to-date with the latest versions of the codecs; It is very user-friendly and the installation is fully customizable, meaning that you can install only those components that you really want; It has been very well tested, so that the package doesn't contain any conflicting codecs; It is a very complete package, containing everything you need to play your movies; and has different packages.
Latest Changes:
Updated huffyuv with version 2.1.1 (CCE Patch 0.2.5)
Re-added Ogg DirectShow splitter and Vorbis DLLs
Added Matroska splitter
Updated DirectVobSub to version 2.36
Removed DivX Anti-Freeze
Added VobSubStrip
Minor changes
下載點擊
QuickTime Alternative 1.44
QuickTime Alternative will allow you to play QuickTime (.mov .qt) files. This way there is no need to install the offical QuickTime Player. It also supports QuickTime content that is embedded in webpages. The QuickTime plugins include iPIX and QuickTimeVR. The QuickTime Browser plugin supports Internet Explorer, Opera, Mozilla and Netscape.
Latest Changes:
Improved installation of browser plugin
Improved iTunes compatibility
AAC encoding works now
Minor changes
下載點擊
Real Alternative 1.34
Real Alternative will allow you to play RealMedia files without having to install the official RealPlayer. You do need a media player that is capable of playing RealMedia files. The included Media Player Classic supports it. Supported are RealAudio (.ra .rpm), RealVideo (.rm .ram .rmvb), RealText (.rt), and ReadPix (.rp). Not fully supported are: Streaming smil files (.smi .smil) and Realmedia embedded in webpages.
Latest Changes:
Minor changes
下載點撃
ps.弟今晚 要下南部 明天一早要跟車子俱樂部的朋友 聚會
過幾天才會再上CBB 會想念各位大大滴 像JEFF兄跟風大還有台中的C伯伯
Latest Changes:
Added VobSubStrip
Minor changes
下載點擊
Latest Changes:
Minor changes
下載點擊
Latest Changes:
Minor changes
下載點撃
