[測試]超值Ivy-Bridge XEON E3 1230-V2上市
mydmtw
E3-1200 V2系列,不是說全面來襲嗎?
怎麼只出1230 V2 一顆,我在等待1245 V2
什麼時候要開賣呀?
ccbxeon
jason930
路過,請問這一顆cpu 能否使用intel smart response嗎???
styx
Rockin'The Paradise
drfly
現在這顆真的是不錯
但是有些店都只能要搭機買
史柯爾
昨天晚上也去入手一顆來玩
zxcvb680
你講錯E3 1230 V2. 3.3GHz 同架構 效能怎麼跟3770k同階
你測出來結果差很大
人會跟3570k比 3570k 3.4GHz 比E3 1230 V2 3.3GHz快一點. 同樣Ivy Bridge 架構
多四核心八線程
如果要跟3770k比最起碼是Intel® Xeon® Processor E3-1275V2
(8M Cache, 3.50 GHz) 伺服器cpu架構更貴 比3770k貴
jason930
真的是晶片組功能嗎?
我的z68和E3-1235 開不到smart response /.\ ><
所以想知道ivy bridge 的xeon 可否開啟
styx
Rockin'The Paradise
真的是晶片組功能嗎?
Intel® Smart Response Technology User Guide
Note: This feature requires that the SATA controller be set to RAID mode via the system BIOS.
Intel® Smart Response Technology is an Intel® Rapid Storage Technology (RST) caching feature that
improves computer system performance. It allows a user to configure computer systems with an SSD
used as cache memory between the hard disk drive and system memory. This provides the advantage of
having a hard disk drive (or a RAID volume) for maximum storage capacity while delivering an SSD-like
overall system performance experience. Intel® Smart Response Technology caching is implemented as a
single drive letter solution; no additional drive letter is required for the SSD device used as cache.
System Requirements:
For a system to support Intel Smart Response Technology it must have the following:
 Intel® Z68 Express Chipset-based desktop board
 Intel® Core™ Processor in the LGA 1155 package
 System BIOS with SATA mode set to RAID
 Intel Rapid Storage Technology software 10.5 version release or later
 Single Hard Disk Drive (HDD) or multiple HDD’s in a single RAID volume
 Solid State Drive (SSD) with a minimum capacity of 18.6GB
 Operating system: Microsoft Windows* Vista 32-bit Edition and 64-bit Edition, Microsoft Windows*
7 32-bit Edition and 64-bit
抱歉~除了晶片組之外,這個功能需要Core等級的CPU
Core i3 i5 i7 才能使用,xeon就沒支援嘍~
我在大陸某論壇上也看到不支援Pentium G系列~
qaz1522001
錯!
這顆確定不能用ISRT,別被誤導了!!!!
ISRT除了晶片組要配合外,CPU也要Core系列才支援
Celeron/Pentium/Xeon都不支援
曾經G620搭Z77開不成ISRT的人留
