[狂]GTX580 4張行
john801110
狂少一出手便知有沒有!
bubun369
報告,我看完了,對焦有點慢所以有時候看不太清楚字
85%的風扇好吵~"~
過程絕對是真材實料啦,FPS整整是我的兩倍在跑
狂少
Bulletproof Themer
直接用兩顆PUS作兩路使用應該比較簡單也不用調東調西吧 ! :rolleyes:
1顆供電給MB及CPU...另1顆專屬給GTX 580 四兄弟 ! ;ranger;
錯了..是:
A-->mb and gtx580(so 我們可以調整ioh/ioh&pcie)
B--->cpu only(最好用單路)
狂少
Bulletproof Themer
那一個壓降比較嚴重.........^^b
那一個電壓抽比較多且快?;em03;
所以才需要好的多路去給mb+graphic跑..
單路留給CPU..
狂少
Bulletproof Themer
哇...秀一下那顆cpu單獨的power.........;shakehand
100a PC Power and cooling 1200w turbo cool
Turbo-Cool 1200
As the newest model in the renowned PC Power & Cooling Turbo-Cool series, the robust Turbo-Cool 1200 power supply is truly the ultimate next-gen PSU! This Single-Rail power house (+12V @ 100A) will provide optimum distribution of rock-solid power for the most demanding configurations possible. Delivering a continuous 1.2 Kilowatts (1400W peak) with a high efficiency rating of 83%, the Turbo-Cool 1200 is the ultimate power supply solution for those that require the very best, long-lasting, industrial-grade components for their mission-critical system or cutting-edge gaming machine. NVIDIA® SLI™ Certified to the highest level (3-way SLI), the Turbo-Cool 1200 power supply (1200w PSU) is built to last and absolutely future-proof!
1.2KW Continuous (1.4KW peak) @ 50°C
Fits Std. ATX Cases (20" min. depth)
+12VDC @ 100A (115A pk) (Massive Single Rail)
High Efficiency (83%); .98 Active PFC
Rock-Solid, Super-Clean DC Output
24-pin, Dual 8-pin, 4-pin M/B Connectors
Six PCI-E and 17 Drive Connectors
NVIDIA® SLI Certified
Individual 14-point Certified Test Report
7-Year Warranty; Unbeatable Support
Happypc
********.com低階會員
chinringo
狂大~
可以用一下GPU-Z 新搞出來的 GTX 580功耗限制破解
讓我們看一下效能跟功耗能衝到那裡嗎
而且狂大有四張!!!!
m2315961
特級會員
狂大上炮啦!友站已經有人在R3E上4張GTX580和980x 全部都用LN2去測了!!!
