再來一顆G0盒裝!Intel Core 2 Duo E6750
hardrock
看來G0不是每顆都好超
再忍一下下;em44; 囉
angel-ghost
看了你的情況
原本以為g0每顆都不錯超....
td200672
白。
好像719A的可見度比較高,不知道719B的體質如何呢?
你說的是E6550吧?我今天也有看到B版的
通常B版體質都很棒,不過7倍頻實在不想下手...:PPP:
tom7089
C/P之王
NONO!我確定是719B的E6750,在台中電子街看到的,雖然還蠻想衝的,但想想還是等四核算了,因為最近實在沒什麼空去搞超頻:lkl:
td200672
白。
咦?6750也有B版喔 ;nq;
tucheng
看到大家買的E6X50烙賽的樣子真的很失望,在等一陣子啦^^^
芝風
哇…怎麼之前有看到大大測隨便都上3g?
seven9999
多謝澇賽~小弟謹記在心~
等下一週期~離7/22還有一段時間~
smartbuy0827
The boxed Intel� Pentium� dual-core desktop processors E2160 and E2140 will undergo the following changes for the L-2 to M-0 stepping conversion:
� New S-Spec and Material Master Number for the converting product
� CPUID will change from 6F2 to 6FD
� Extended HALT power specification will reduce from 12 Watts to 8 Watts
� Maximum allowed Case Temperature will increase from 61.4蚓 to 73.2蚓
� Tcontrol offset will remain the same relative to 0 with the increase in maximum allowed Case Temperature, which will help reduce acoustics
� Minor visible difference between the L-2 and M-0 packages but is pin-compatible
The boxed Intel� Core�2 Extreme processor QX6800 will undergo the following changes for the B-3 to G-0 processor stepping conversion:
� CPUID will change from 06F7 to 06FB
� New S-specs for converting product
� Packaging will move from a white box to standard Retail packaging
� Boxed processor will now include the Intel designed thermal solution
� Thermal specification has changed: Maximum allowed Case Temperature for the Intel� Core�2 Extreme processor QX6800 on G-0 stepping has been increased by 9.7 oC. Tcontrol offset will remain same relative to 0 with increase in Maximum allowed Case Temperature, which will help reduce acoustics.
從vr zone擷取的
dtjordan
我也是剛買一顆E6750
現在只有一句話
~千金難買早知道.萬般無奈想不到~
這樣大家應該可以知道意思吼T.T
