OverFold
假如你的SMP2之前已在運算中,請先刪掉你的Client.cfg(或rename為其他文字),再執行
你的Shortcut,當然你的命令行已在最後加上-smp 8 等參數 (即使你打8但偵測到4都會以四核來跑~)
,照足以下的對答輸入相關資料,記緊User name一欄必須填入OverFold否則無效!(~~)
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.30
http://folding.stanford.edu
Launch directory: C:\Folding@Home\Folding@home-SMP2
Executable: C:\Folding@Home\Folding@home-SMP2\Folding@home-Win32-x86.exe
Arguments: -verbosity 9 -bigadv -smp 8
[17:44:29] Configuring Folding@Home...
User name [Anonymous]? OverFold
Team Number [0]? 31403
Passkey []? (務必輸入你的Passkey)
Ask before fetching/sending work (no/yes) [no]? (見[no]拍一下Enter就是~)
Use proxy (yes/no) [no]?
Acceptable size of work assignment and work result packets (bigger units
may have large memory demands) -- 'small' is <5MB, 'normal' is <10MB, and
'big' is >10MB (small/normal/big) [normal]? big
Change advanced options (yes/no) [no]? yes (此處請打 yes)
Core Priority (idle/low) [idle]? (照拍Enter)
CPU usage requested (5-100) [100]? (照拍Enter,如果GPU3需要10%CPU資源,此處建議打90)
Disable highly optimized assembly code (no/yes) [no]?
Pause if battery power is being used (useful for laptops) (no/yes) [no]?
Interval, in minutes, between checkpoints (3-30) [15]? (照拍Enter)
Memory, in MB, to indicate (4096 available) [4096]? (照拍Enter)
Set -advmethods flag always, requesting new advanced
scientific cores and/or work units if available (no/yes) [no]? yes
Ignore any deadline information (mainly useful if
system clock frequently has errors) (no/yes) [no]?
Machine ID (1-16) [1]? 6 (本人習慣用6,以盡量與其他機不衝突為大前提)
Launch automatically, install as a service in this directory (yes/no) [no]? yes (yes 重點所在)
The program will continue in non-service mode now, working in C:\Folding@Home\Folding@home-SMP2.
The next time the computer is starts up, you should see work automatically
continue there. Note that when this service is running, you should not try
to manually run F@H from that directory at the same time.
The following options require you to restart the client before they take effect
Disable CPU affinity lock (no/yes) [no]?
Additional client parameters []? -verbosity 9 -bigadv -smp 8
(-smp隔位後務必要輸入2或以上數值,否則一次Project完成後改跑單核,i7 user跑-bigadv可照足我填)
IP address to bind core to (for viewer) []? (照拍Enter)
大功告成!想知道下次開機會否從服務自動執行請入services.msc檢查是否已有Folding@Home[MID]項目就是
