FAH 硬體及客戶端綜合討論 (part 1)
浩雲
這樣快嗎 ? 第一次跑SMP, 沒比較過 ... ;oq;
剛剛約3h跑完一個Task(100%), 1core ... :confused:
這太強了...
我用E8400預設下去試跑
約16~17分左右1%
也是要算天才能完成的:PPP:
JCornell
5w337
問題又來了 ...
用到 ID=5 就連不上了, 目前只能跑4cores :o ... any idea ?
THX
PS : 同時跑好幾台電腦(同一個帳號), 分數是否會併合算 ?
F@H滄者極限團隊
pleaseenterme
用CPU這樣跑真的超快的;oplc; ..我跑SMP也都是算天的;oq; ...
真好奇這樣PPD可以高到多少?
cooky7620
www.wretch.cc
*;x; ......太快了吧
比我的GPU都還要快了
大大能不能看一下PPD多少
monkp
... loading ...
請問-local有何意義 ? 第一個SMP沒加此參數 ... :)
-local Use configuration files from local directory. This option has no meaning on Linux, but is vital on Windows and Macintosh for running multiple clients on a machine. It instructs the client to read its config information from the client.cfg file in the current directory rather than, on Windows, from the installation directory specified in the registry, or, on Macintosh, the Library/Folding@home directory. Information such as the user name, team name, proxy information, machine ID are maintained in the client.cfg file. The flag ensures that work does not conflict. Use "-local" only if you are planning on running more than one instance of Folding@Home on the same machine (this is only useful if you are running on a multi-processor machine). Create as many directories as there are processors on the machine, copy the exe files and client.cfg file into each of these directories, run "FAH3Console -local -config" on each and specify unique machine IDs for each directory (under the Advanced Settings option). From then onwards you may run each copy by switching to its directory and running with the -local flag.
這好像沒設定好耶, 請 JC 大參考在下的這篇教學 6.22 SMP Deino 安裝簡介
在這之前, 也請安裝 Affinity Changer 1.05
當你安裝完 Deino MPI, 換上 -shm 執行檔, 建立捷徑加上 -configonly 啟動後, 設定
Machine ID <1-16> [1]? 18 就您的 case
Disable CPU affinity lock <no/yes> [no]? yes
Additional client parameters []? -smp -deino -local -forceasm -verbosity 9
完畢, 請跑看看 SMP 是否工作正常.
沒有問題後, Ctrl + C 暫時關閉 FAH 運算, 回到 SMP 安裝的資料夾 (something like Folding@home xxx), Copy 另外七份, 命名 Folding@home xxx-1, -2, or whatever ;)
各回到這 7 個 folder, 刪除 work 資料夾, queue.dat, 再執行 -configonly 更改 machine id.
請注意: install.bat 只需跑一次就好, Deino MPI 也只需要安裝一次
當八個 SMP 都正常工作後, 啟動 Télécharger Bill2's Process Manager, 配置 CPU0, CPU1 給第一個 SMP 等等 ...
Good Luck :MMM:
JCornell
5w337
這好像沒設定好耶, 請 JC 大參考在下的這篇教學 6.22 SMP Deino 安裝簡介 ("http://forum.coolaler.com/showpost.php?p=2138402&postcount=301")
在這之前, 也請安裝 Affinity Changer 1.05 ("http://distributed.org.ua/index.php?go=distribredir&url=http://fah-smp-affin...
;ranger; , 未搞好又來Deino了 :PPP: ... 這是用Vista 64Bit呢(可行嗎?) ...
以上我再慢慢吸收了 ;rr;
感謝您的指導 ... :MMM:
monkp
... loading ...
以上我再慢慢吸收了 ;rr;
感謝您的指導 ... :MMM:
Vista 64 只能裝 MPICH 這版哩 ... 步驟差不多 ... 只是在 Additional client parameters 這裡輸入 -smp -local -forceasm -verbosity 9 就可以了
affinity changer 1.05 也要記得裝上, 還有換上 -shm 執行檔
JCornell
5w337
JCornell
5w337
affinity changer 1.05 也要記得裝上, 還有換上 -shm 執行檔...
Ok, 我再研究看看 ... ;shakehand
最多只能同時跑8個SMP ?
