[台北售]友通 DFI LANPARTY NF4 ULTRA-D
homeman
1.欲售二手物品名稱:DFI LANPARTY NF4 ULTRA-D 友通 已改SLI與SATA2
2.欲售物品數量:X1
3.欲售物品之品相規格使用狀況:原廠保固中 已改SLI與SATA2 想換INTEL
4.欲售價格:3000含運
5.欲售地點:台北市
6.交易方式(郵寄、面交): 皆可
7.聯絡方式 msn : homeman168@hotmail.com
wenchang
是NF4 or ultra-D??
ultra-d 不需要改就有sata2..
homeman
預設 SATA speed up to 1.5Gb/s <----SATA 1~~這張~改成SATA 3Gb/s
http://www.dfi.com.tw/Product/xx_pr....jsp?PRODUCT_ID=3471&CATEGORY_TYPE=LP&SITE=TW
LANPARTY UT nF4 Ultra-D 附加功能
看大圖
LANPARTY UT Ultra-D exclusive features
DXG(Dual Xpress Graphics) supported
Karajan Audio(Theater like7.1 /8ch supported)
Dual Gigabit LAN
nVIDIA nVRAID
nVIDIA nTune(embedded overclocking solution)
nVIDIA ActiveArmor
(Embedded hardware firewall & network solution)
nF4 chipset supported Serial ATA(3Gb/s)
100% Japanese Capacitors
UV sensitive slots
EZ-on / EZ-touch onboard switch button
CMOS reloaded
All New Genie BIOS
內包裝
產品摘要
產品規格
CPU
AMD Athlon 64 X2 / Athlon 64 FX / Athlon 64 / Sempron
Socket 939
Front Side Bus
2000MT/s HyperTransport interface
Chipset
NVIDIA nForce4 Ultra
Memory
Four 184-pin DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports DDR266, DDR333 and DDR400 DDR SDRAM DIMM
Expansion Slots
2 PCI Express x16 slots
1 PCI Express x1 slot
1 PCI Express x4 slot
2 PCI slots
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-USB Keyboard/Mouse
- Wake-On-LAN
- RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system/chipset temperature
Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vchipset/Vdram voltages
Monitors the speed of the CPU fan, Fan 2 and chipset fan
CPU Overheat Protection function monitors CPU temperature during system boot-up
Audio
Karajan audio module
- Realtek ALC850 8-channel audio CODEC
- 6 audio jacks
- 1 CD-in connector
- 1 front audio connector
S/PDIF-in/out interface
LAN
Dual Gigabit LAN - Vitesse VSC8201 Gigabit Phy and Marvell 88E8001 Gigabit PCI
Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and
802.3ab (1000BASE-T) standards
IDE
Two IDE connectors that allows connecting up to four UltraDMA 133Mbps hard drives
NVIDIA RAID allows RAID arrays spanning across Serial ATA and Parallel ATA
RAID 0, RAID 1 and RAID 0+1
Serial ATA with RAID
Four Serial ATA ports
SATA speed up to 3Gb/s
IEEE 1394
VIA VT6307
Supports two 100/200/400 Mb/sec ports
Rear Panel I/O Ports
1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
Karajan audio module (6 audio jacks)
1 IEEE 1394 port
2 RJ45 LAN ports
6 USB 2.0/1.1 ports
I/O Connectors
2 connectors for 4 additional external USB 2.0/1.1 ports
1 connector for 1 external IEEE 1394 port
1 connector for 1 external serial port
1 front audio connector for external line-out and mic-in jacks (on the Karajan audio module)
1 CD-in internal audio connector (on the Karajan audio module)
1 S/PDIF connector for optical cable connection
1 IR connector
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
1 24-pin ATX power connector
1 4-pin ATX 12V power connector
2 4-pin 5V/12V power connectors (FDD-type and HDD type)
1 front panel connector
5 fan connectors
4 diagnostic LEDs
EZ touch switches (power switch and reset switch)
PCB
ATX form factor
24cm (9.45") x 30.5cm (12")
All specifications above are subject to change without prior notice.
dinoking
不能再敗了
應該有吧,我的就有
homeman
已有網友預定~
謝謝
