CPU/SMP 高獎勵得分 選購/設定/除錯...集中綜合討論串
kazama
2600K@4.3Ghz DDR3-1866Mhz運算P6903超級bigadv,TPF為60:52左右,約55800 ppd.
kazama
P6903約253萬個原子,TPF相較於P6900(約110萬原子)大致上是等比例增加,有意運算
超級bigadv的隊友可依此比例(253/110)算出現有平台的P6903推估TPF,再以SMP2
calculator(http://linuxforge.net/bonuscalc2.php)估算ppd.
oegg
我本身就是 6C/12T 所以沒改 corefix, 我接到一個 6904 根 2689 還沒接到 6903
另外 我 share 權限 還是不成功
kazama
P2689為一般的bigadv,而P6904與P6903同屬253萬原子的超級bigadv.
lchiang
今天早上以Overclock.net網頁作法安裝並設定Ubuntu已接到第一個P6903,使用此作法
請留意Overclock.net網頁關於corefix.sh的權限設定有一個小問題:
FAH client設定中的corefix.sh權限設定,網頁文字為:
13 - one last thing to do back in the terminal. We need to set permissions for the
scripts we just made. One at a time:
chmod +X corefix.sh
其中X誤植為大寫,請自行改為:
chmod -x corefix.sh
此外corefix.sh中[yourpassword]也請記得改為Ubuntu登入密碼,corefix.sh方能成功
執行. 若執行成功SMP client terminal會顯示偵測到12 cores,使用6C/12T以下平台的隊友
請務必確認SMP client偵測到12 cores方能收到P6903.
謝謝提醒, smp client也顯示了12 cores, 還是沒接到新的big bigadv WU, 看來人品也是很重要地... 呵呵
題外話, 2600K實在是好物, 已經幫3個親戚朋友裝過2600K, 三顆都能1.25v跑4.5G, 希望年底的LGA2011也一樣出色....
nybaao
希望2011的CPU的熱量再少點 這樣可超幅度就越大
不知道FAH有沒有一個甚麼進度之類的 哈哈哈
用力算 我現在用筆電的獨顯加入運算 每天大概可以算完一筆多一點
A4GTRS
X6 1090T oc@4.1g 不跑 bigadv
已經完成24個WU
還是呆呆在用core A3在跑
參數有下-bigadv -verbosity 9 -advmethods
一定要用VM才能跑bigadv?
[21:59:59] + Number of Units Completed: 24
[22:00:06] Trying to send all finished work units
[22:00:06] + No unsent completed units remaining.
[22:00:06] - Preparing to get new work unit...
[22:00:06] Cleaning up work directory
[22:00:12] + Attempting to get work packet
[22:00:12] Passkey found
[22:00:12] - Will indicate memory of 4094 MB
[22:00:12] - Connecting to assignment server
[22:00:12] Connecting to http://assign.stanford.edu:8080/
[22:00:13] Posted data.
[22:00:13] Initial: 8F80; - Successful: assigned to (128.143.199.96).
[22:00:13] + News From Folding@Home: Welcome to Folding@Home
[22:00:13] Loaded queue successfully.
[22:00:13] Sent data
[22:00:13] Connecting to http://128.143.199.96:8080/
[22:00:14] Posted data.
[22:00:14] Initial: 0000; - Receiving payload (expected size: 1767621)
[22:00:18] - Downloaded at ~431 kB/s
[22:00:18] - Averaged speed for that direction ~419 kB/s
[22:00:18] + Received work.
[22:00:18] Trying to send all finished work units
[22:00:18] + No unsent completed units remaining.
[22:00:18] + Closed connections
[22:00:18]
[22:00:18] + Processing work unit
[22:00:18] Core required: FahCore_a3.exe
[22:00:18] Core found.
[22:00:18] Working on queue slot 06 [July 11 22:00:18 UTC]
[22:00:18] + Working ...
[22:00:18] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 6 -checkpoint 15 -verbose -lifeline 1928 -version 634'
這兩天i7-970和2600K跑SMP的PPD真是慘不忍睹啊 ;oq;
kazama
已經完成24個WU
還是呆呆在用core A3在跑
一定要用VM才能跑bigadv?
我是直接裝ubuntu(非VM)接到第一個P6903. 4C/8T平台裝ubuntu請確定corefix.sh
正確執行且SMP client顯示偵測到12 cores,才有可能接到超級bigadv.
lchiang
已經完成24個WU
還是呆呆在用core A3在跑
一定要用VM才能跑bigadv?
參數除了bigadv, 最基本的還要 -smp
