補貼3張畢業照圖
4.7G上跑3D~~~
4.8G時、温度和電壓~~
4.9G時、温度和電壓~~
以上測試都是用水冷、
空冷在1.45V就極限了。
発見能低壓跑的CPU在1.4V以上、開始異常高温。 空冷不好跑、EO版的CPU不知如何?
4.7G以上時、
最後bios設定如下
JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: auto
FSB Frequency: 480~526
PCI-E Frequency: 100
DRAM Frequency: 1000~1200
...................................其他都 AUTO................................
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
DRAM Static Read Control: D
DRAM Read Training: D
MEM. OC Charger: E
CPU Voltage: 1.45~1.525
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.6
FSB Termination Voltage: 1.27
DRAM Voltage: 2.11
NB Voltage: 1.5~1.6
NB GTL Reference: AUTO
SBridge Voltage: 1.13V
PCIE SATA Voltage: 1.60V
Load Line Calibration: enable
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
上FSB550以上時的bios設定如下
CPU Ratio Setting: 6~8.5
FSB Frequency: 550~590
1st Information :
CAS# Latency: 5
MEM. OC Charger: E
CPU Voltage: 1.26~1.4
CPU PLL Voltage: 1.55
FSB Termination Voltage: 1.25
DRAM Voltage: 2.10
NB Voltage: 1.37~1.4
SBridge Voltage: 1.10V
PCIE SATA Voltage: 1.50V
4.7G上跑3D~~~
4.8G時、温度和電壓~~
4.9G時、温度和電壓~~
以上測試都是用水冷、
空冷在1.45V就極限了。
4.7G以上時、
最後bios設定如下
1st Information :
CAS# Latency: 5
MEM. OC Charger: E
DRAM Voltage: 2.11
NB Voltage: 1.5~1.6
上FSB550以上時的bios設定如下
1st Information :
CAS# Latency: 5
MEM. OC Charger: E
DRAM Voltage: 2.10
