Are you looking for the ultimate thermal interface material? Coollaboratory Liquid Pro is the first thermal interface material to consist of 100% liquid metal. The metals in Coollaboratory Liquid Pro remain at a liquid state at ambient room temperature. This unique composition allows Coollaboratory Liquid Pro to transfer heat eight times faster than conventional thermal paste.
To truly earn its name, Coollaboratory Liquid Pro does not contain any non-metallic additives such as silicone or oils. Liquid Pro exceeds the performance of the best thermal pastes available on the market today by a factor of 10. It outperforms simpler pastes such by a factor of 100!
Application of Coollaboratory Liquid Pro must be done carefully with a small, lint-free brush. Coollaboratory Liquid Pro behaves similar to mercury. The material should be evenly applied over the processor. After 48 hours, Coollaboratory Liquid Pro solidifies into its most optimal state to provide the best cooling performance.
More care is required when applying Coollaboratory Liquid Pro versus conventional thermal paste. If you are experienced in dealing with computer hardware, you may want to pick a more conventional, poorer performing thermal paste
:MMM:
