Memset 4.0
-Use WinRing0 driver.
-Interface is the same for all chipsets/CPUs.
-Add support for Intel Core i7 CPU (Reading only).
-Loading time was improved.
-Improve frequency reading on Core i7.
-Improved reading SPD info on DDR2 & DDR3.
-Fixe frequency reading on some Core 2 Duo CPU.
下載
http://www.tweakers.fr/download/MemSet40.zip
CoreTemp 0.99.4
Version 0.99.4 - 19th January, 2009
Major changes:
Completely rewritten base code.
Core Temp is now available in both 32 and 64 bit versions.
- Add: CPU detection improved, efficiency improved, speed improved, clock speed detection improved.
- Add: Initial support for Core i5 (Lynnfield).
- Add: Automatically detect Core i7/i5 series TjMax.
- Add: Show real-time TDP of Core i7 processors (still needs work).
- Add: Alternative clock speed detection for Core 2, i7 and i5 series and up.
- Add: Support for all currently available and some future processor families. (Intel & AMD)
- Add: Temperature changes color when temperatures hit high levels to alert the user. (Orange = hot, Red = critical)
- Add: Show (!) besides the temperature of a core which hit critical temp as a notification of past overheating.
- Add: Invalid temperature values are followed by (?) for both Intel and AMD.
- Add: AMD AM2+ 65nm processors get a 21c offset to fix incorrect temperature reporting (info from AMD).
- Add: AMD Black Edition processors identified by "BE" suffix after PR rating.
- Add: Display time and date on G15 LCD.
- Add: Complete DPI awareness - Core Temp GUI now scales perfectly with any DPI setting.
- Add: Rewritten algorithm for "Register dump" function, works much faster and more accurate (no ghost devices).
下載
32Bit - http://www.alcpu.com/CoreTemp/CoreTemp32.zip
64Bit - http://www.alcpu.com/CoreTemp/CoreTemp64.zip
下載
CoreTemp 0.99.4
Major changes:
下載
