ASUS Striker Extreme 680i 簡單教學
abababc123
這領域還真是深奧呀~
很多不懂的事情呢,看來得多學學這方面的知識了...
辛苦囉版大:MMM:
NETAVA
gordon3210
逢いたいよ
推啦
樓主辛苦勒
這個機殼不便宜哩
hyde211
:PPP: 機殼外觀是不錯!
不過散熱就....Orz
hyde211
別的論壇看到的
目前最新 1102 BIOS有改進的地方!
01. Fixed it fails to resume from D3 mode by PS2 Keyboard
02. Update AWDFLASH V1.30
03. Fixed CPU uCode will update fail.
------[Kentsfield1066 2.66GHz/8MB EM64T QXUZ G0/Kentsfield-1066 2.66GHz/8M EM64T QQMM B1.]
04. Patch Transcend DDR800 1G fail to boot when 4 DIMMs
05. Support EIST function for Wolfdale CPU family.
06. Fixed Wolfdale L2 cache show incorrect in DMI.
07. Update NV RAID ROM to 6.98
08. Update NVMM to 4.A72.24
09. Support wolfdale CPU.
10. Release EZflash B322
11. Add microcode not found & update fail message.
12. Modify CPU fan speed warning item value.
13. Fixed gtltable for better Kentsfield OC.
14. Use new French translation.
15. Modify General Help string.
16. Use new B5 translation.
17. Fixed floppy item value error.
18. Skip checking 2nd Checksum for some memory patch
19. Disable unused PCIE Bridge to fix
------a.DTM -PCI Compliance issue
------b.ATI Crossfire fail issue.
20. Use new GB translation.
21. Patch Hynix HYMP512U64CP8-S5-AB when Full Loading for stability
22. Update new microcode :
------a.New Micro Code for CPU: 06FBH Patch ID=B3H Platform ID =10h (Kentsfield-G0).
------b.New Micro Code for CPU: 06FBH Patch ID=B3H Platform ID =01h (Conroe-G0).
------c.New Micro Code for CPU: 06FDH Patch ID=A1H Platform ID =01h (Conroe-M0).
23. Use new Japanese translation.
24. Support post message in Japanese
25. Added SATA trap for MCP55.
26. Fixed L1 and L2 cache size will show incorrect in DMI with Conroe-L CPU.
27. Update Micro Code for CPU: 10661H Patch ID=32H Platform ID =01h (Conroe-L-A1).
28. Fixed Conroe-L CPU L2 cache size show incorrect issue.
29. Update Micro Code for CPU=0F65H ID=09H Platform ID=04h. (Cedar Mill/Cedar Mill ICP/Presler)
30. Fixed when Post96h update DMI data and AC power loss.The DMI data might be destroyed.
以上給大家參考
話說新的BIOS應該也快要出了!
2個多月沒更新了
之前有1202的傳聞,不過至今都沒釋出
:D
hyde211
BIOS version: 1202 Date:05/23/2007
Checksum: A800H
01.Update NV RAID ROM to 6.98
02.Update NVMM to 4.A72.24
03.Support wolfdale CPU.
04.Release EZflash B322
05.Add microcode not found & update fail message.
06.Modify CPU fan speed warning item value.
** Micro Code Information **
ID CPUID |ID CPUID |ID CPUID |ID CPUID
2C 0F25 |17 0F34 |17 0F41 |05 0F43
06 0F44 |03 0F47 |04 0F4A |03 0F49
04 0F64 |0A 0F32 |02 0F37 |05 0F60
07 0F61 |0F 0F62 |09 0F65 |A1 06FD
B3 06FB |82 06F9 |66 06F7 |C6 06F6
56 06F2 |33 06F5 |33 06F5 |26 06F4
32 0661 |04 0660 |B3 06FB |06 0671
06 0671 |
hyde211
BIOS version: 1201 Date:05/09/2007
Checksum: 1200H
01.Use new French translation.
02.Modify General Help string.
03.Use new B5 translation.
04.Fixed floppy item value error.
05.Skip checking 2nd Checksum for some memory patch
06.Disable unused PCIE Bridge to fix
07.Use new GB translation.
08.Patch Hynix HYMP512U64CP8-S5-AB when Full Loading for stability
09.Release EZ Flash2 version B321.
10.Update new microcode :
11.Use new Japanese translation.
12.Support post message in Japanese
13.Added SATA trap for MCP55.
14.Fixed L1 and L2 cache size will show incorrect in DMI with Conroe-L CPU.
15.Update Micro Code for CPU: 10661H Patch ID=32H Platform ID =01h (Conroe-L-A1).
16.Fixed Conroe-L CPU L2 cache size show incorrect issue.
17.Update Micro Code for CPU=0F65H ID=09H Platform ID=04h. (Cedar Mill/Cedar Mill ICP/Presler)
18.Fixed when Post96h update DMI data and AC power loss.The DMI data might be destroyed.
06 0F44 |03 0F47 |03 0F49 |04 0F4A
07 0F61 |0F 0F62 |09 0F65 |32 0661
A1 06FD |B3 06FB |B3 06FB |82 06F9
56 06F2 |66 06F7 |C6 06F6 |04 0660
33 06F5 |33 06F5 |26 06F4 |
BIOS version: 1102 Date:03/28/2007
Checksum: 0F00H
01. a.Added New Micro Code for the Intel(R) Core(TM)2 Duo processor E4300 :
L-2 stepping processor signature 000006F2 (Conroe) CPUID = 06F2H,
Patch ID = 56H, Platform ID = 01H.
b.Added New Micro Code for the Intel(R) Core(TM)2 Duo processor :
B-2 stepping processor signature 000006F6 (Conroe & Conroe XE)
CPUID = 06F6H, Patch ID = C6H, Platform ID = 01H.
c.Added New Micro Code for Intel(R) Core(TM)2 Quad processor Q6600, QX6700
B-3 stepping processor signature 000006F7
CPUID = 06F7H, Patch ID = 66H, Platform ID = 10H.
02.Don't remove GPU Ex item and modify the option as the same as before on Spectrum item.
07 0F61 |0F 0F62 |07 0F65 |15 0661
82 06F9 |56 06F2 |66 06F7 |C6 06F6
04 0660 |33 06F5 |33 06F5 |26 06F4
BIOS version: 1101 Date:03/23/2007
Checksum: 5E00H
01.Patch G-SKILL F2-6400CL6D-4GBMQ DDR2-2G MMIO and Voltage in Dual-Channel mode
02.Remove Linkboost Function
03.Patch Corsair CM2X1024-6400C4 MMIO and Voltage when heavy loading
82 06F9 |51 06F2 |60 06F7 |44 06F6
BIOS version: 1004 Date:03/05/2007
Checksum: 1F00H
01.Add C1E function support for Conroe-L A-1 stepping CPU .(Ref. Conroe-L_A-1_DCL_QS.doc)
02.Change back the NVMM to 4.A64.03 and added all DRAM MMIO Patch.
BIOS version: 1003 Date:03/03/2007
Checksum: 2E00H
01.Fixed PreslerXE 3.73G will run at 3.19G when CMOS fail
02.Use new German translation.
03.Update NVMM to 4.071.09 and remove all DRAM MMIO Patch
04.Fixed PreslerXE & SmithfieldXE CPU fail to boot
05.Removed unnecessary CPU ucode (CPUID=0F4AH, Patch ID=02H) to reduce code size.
06.Release EZ-Flash B320 .
BIOS version: 1002 Date:02/15/2007
Checksum: 1B00H
01.Fixed Vcore wrong above 1.80V.
02.Fixed CPU Vcore cannot be set by user when Overclocking at some frequency
03.Added New Micro Code for CPU: 10661H Patch ID=15H Platform ID =01h (Conroe-L-A1).
02 0F4A |04 0F64 |0A 0F32 |02 0F37
05 0F60 |07 0F61 |0F 0F62 |07 0F65
15 0661 |82 06F9 |51 06F2 |60 06F7
44 06F6 |04 0660 |33 06F5 |33 06F5
26 06F4 |
BIOS version: 1001 Date:02/13/2007
Checksum: 7C00H
01.Fixed CPU Vcore will abnormal when over 1.60V and restore CPU OV GPIO to default before Setting Vcore.
BIOS version: 0901 Date:02/07/2007
Checksum: D400H
01.Modify Corsair CM2X1024-10000C5D & Corsair CM2X1024-6400C4D patch rule
02.Fixed FSB 1333Mhz CPU clock incorrect
03.Fixed sometime the CPU VID table will be dystroyed
04.Fixed Vcore error when CMOS checksum fail.
05.Fixed summary page "CPU ID/ucode ID" string will show to "CPU ID/uc"
06.Patch Corsair CM2X1024-6400C4D to fit H/W Request
07.Update EZ-Flash to B319 :
a.Fixed error occurs when there is only a SATA ODD connected and legacy floppy is disable.
b.Fixed if the last byte of the bios date is aligning on 16bytes
08.Fixed SETUP hang on when item position at "Internal Connector LED" in Triditional Chinese mode
czh
昨天升級完重新開机後
測試到RAM就無法開机
