Display Type
LCD display / TFT active matrix - LED Backlight technology Width
22.3 in Depth
5.9 in Height
16 in Weight
8.4 lbs Enclosure Color
Black/blue Image
Image Color Temperature
Adjustable Image brightness
250 cd/m2 Image Contrast Ratio
1000000:1 (dynamic) Max horizontal view angle
170 Max vertical view angle
160 Display
Diagonal Size
23 in - Widescreen Dot Pitch / Pixel Pitch
0.265 mm Max Resolution
1920 x 1080 Video Format
1080p Color Support
24-bit (16.7 million colors) Max Sync Rate (V x H)
75 Hz x 85 KHz
Response Time
2 ms Controls / Adjustments
Contrast, Brightness, Input select, Color temperature Display Positions Adjustments
Tilt Video Output
None Tilt Angle
10 Signal Input
HDMI, VGA Features
HDCP, Touch keys, Skin-Tone Selection, ASUS Splendid Video Preset Mode, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Intelligence Technology Audio Output
Type
Headphone Input Device
Type
None Expansion / Connectivity
Interfaces
1 x VGA - 15 pin HD D-Sub (HD-15), 1 x HDMI - 19 pin HDMI Type A, 1 x Headphones - Mini-phone 3.5 mm Miscellaneous
Cables Included
1 x VGA cable, 1 x HDMI-DVI cable Features
Security lock slot (cable lock sold separately) Compliant Standards
CB, CE, UL, CCC, FCC, PSB, cUL, BSMI, RoHS, VCCI, WEEE, WHQL, C-Tick, GOST-R, PSE Mark Power
Power Consumption Operational
33 Watt Power Consumption Stand by / Sleep
1 Watt Software / System Requirements
Software type
Drivers & Utilities Sustainability
EPA Energy Star Compliant
Yes
