無懼1155的來臨, 趕上1156尾班車.
Blank
如果可以的話能分享一下U的序號嗎
方便大家去尋雕....
這不是雕吧, 而且在這主板上;oq;
反而喜歡這張5850, 有五支熱管, 很不錯, 只可惜不是公版, afterburner不給調電壓, 但不加壓1.088v能上900/1200, 算滿意, 溫度壓得不錯又安靜.
狂少
Bulletproof Themer
Blank
L934b的860就是95%是雕;)
喔, 原來是這樣.
沒玩過又沒練過, 才剛上手, 但偶爾回會藍屏0x124;ng; 還沒時間找問題出來
可能msi發揮不出來了, 不然就是不會調;smash;
狂少
Bulletproof Themer
0x00000124通常是ide controller問題
如果是發生在64bit OS上,那 percentage更加確定是disk 32bit access的問題
其它就是sound card driver衝到
"WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, MCA_ASSERT
Arg2: fffffa8008045c6e, Address of WHEA_ERROR_RECORD structure
Arg3: 00000000b2000040, High 32 bits of MCi_STATUS MSR for the MCA bank that had
the error
Arg4: 0000000000000800, Low 32 bits of MCi_STATUS MSR for the MCA bank that had
the error
Debugging Details:
WHEA_ERROR_RECORD: !errrec fffffa8008045c6e
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: f
STACK_TEXT:
fffffa60`0176a958 fffff800`01e0f72a : 00000000`00000124 00000000`00000000 fffffa80`08045c6e 00000000`b2000040 : nt!KeBugCheckEx
fffffa60`0176a960 fffff800`01f713b3 : 00000000`00000001 00000000`00000001 00000000`00000000 00000000`00000001 : hal!HalBugCheckSystem+0x12e
fffffa60`0176a9d0 fffff800`01e0f097 : fffffa60`00000c3e fffffa60`0176abb0 fffffa60`0176ac30 00000000`00000000 : nt!WheaReportHwError+0x243
fffffa60`0176aa30 fffff800`01ea25f1 : 00000000`00000000 fffffa60`0176ac30 fffffa80`04f17f00 00000000`00000000 : hal!HalpMcaExceptionHandler+0xf3
fffffa60`0176aa70 fffff800`01ea2435 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x71
fffffa60`0176abb0 fffffa60`00905d3c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0xf5
fffffa60`0178aae8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : acpi!DefPortReadAcpiRegister+0x104"
Blank
Arguments:
the error
the error
Debugging Details:
CURRENT_IRQL: f
STACK_TEXT:
沒錯, 是Win7 64 bit AHCI, 那請教一下應該怎樣解決? 我還以為是IMC問題勒
之前用85GT測沒試過0x124, 後來插上5850才有出現.
狂少
Bulletproof Themer
那就是顯卡驅動和IO衝到, Clean install吧:)
如不想reinstall OS,那就務必把NV driver移掉:)
Blank
但是這本來就是clean install, 85GT時是win7他自子build in抓的driver,
win7 64bit音效卡一直都用這driver沒出現過問題.
之前你說IDE controller有問題? 會不會這張主板有問題?
sipo720815
我也是用860去超頻 用win7 64
網路爬文 0x124 大都是說是imc不穩
我自己試 也似乎是這樣
慢慢加imc電壓去測 就不會發生了
有時覺得測燒機到底有沒有用處
32m八匹馬跑好幾次都過 ibt 10次過 記憶體測2000%
跑遊戲也沒問題 就是看影片 上網待機時就偶而不定時藍
後來就不怎去燒
就調低點電壓 進系統 做平常事
當機藍屏
0x101就加vcore電壓
0x124就加imc電壓
加到不藍就是穩....還真不當機了
感覺比用程式去燒出來還穩 燒機那麼久 過了但平時會藍就很惱
真是旁門左道測法-.-
ds934118
不錯的版
撿到便宜XD
Blank
我也是用860去超頻 用win7 64
我自己試 也似乎是這樣
慢慢加imc電壓去測 就不會發生了
有時覺得測燒機到底有沒有用處
後來就不怎去燒
就調低點電壓 進系統 做平常事
當機藍屏
0x101就加vcore電壓
0x124就加imc電壓
加到不藍就是穩....還真不當機了
真是旁門左道測法-.-
改跑200*20 DDRIII 1600 CL8, 跑8匹馬(AMD, 775, 1156)都是跑好玩的, 還是用我喜歡用的Sp2004, cpu加壓到1.30v就沒出現過問題了.
更奇怪的事這四條ram在AM3平台居然電壓比p55低;smash; 能跑2000 CL9但很不穩.
