[KMPlayer Terminator] --> PotPlayer 1.5.22548 x86 (Hot Stuff)
Hsiang2012
PotPlayer 有支援DXVA硬體解碼功能(BD)
播放會比KMP很順暢,
超推薦PotPlayer
chientai
Thank you very very much for sharing this great player with us, Prince Wang. ;cheer2;
Please send me the password please. ;shakehand
;em25;
princewang8
播放會比KMP很順暢,
超推薦PotPlayer
Try [MadVR],use as your Default Renderer.
princewang8
;em25;
幸好不是叫我 Prince 王八;tongue;
作者對 <KMPlayer> 的[承諾期]已過!瘋狂開發 PotPlayer 中.
Beta 更新太快了! 有穩定版!我再 Modify 了
princewang8
http://depositfiles.com/en/files/v0354jap5
( 免安裝,攜帶版 )[國際英文版]
基於:
1,未經作者同意,就修改語系,有點不妥. ;oq;
2,傷害管控,會員獨享 :PPP:
如果你有需要請[回應]並按下右下角的[感謝]
我會用[悄悄話]回你
Have Fun.....;painkille
Version History of the PotPlayer
[ 1.5.22618 ] 2010/06/21
+ Add DVD speed function
+ Add Volume range
+ Add to the mouse pointer in the search bar on the screen can display weather information
+ Add shutdown at a certain time
+ Add slow motion playback
+ Add automatic identification interlaced scanning TV movie
- Fixed issues with skin
- Fixed kinder to the application buffer mode
- Fixed some windows default is the most front-end problems
- Fixed some computer problems can not be the end of the thread
- Fixed problem in determining the Vista screen
- Fixed TV card / full-screen game / demand problem
- Fixed some issues , MP4 files subtitles not synchronized
- Fixed more than three audio tracks in AC3 SPDIF output compression problem
- Fixed sound noise problem in order
- Fixed position of subtitles output word spacing settings for disability
- Fixed 64- bit system , the audio decoder playback delays
- Fixed menu shortcuts failure
- Fixed start using the resource manager should not use the default album problem
- Fixed problem will not delete any temporary files
- Fixed the screen using a keyboard shortcut to minimize the problem can not be restored after
- Fixed screen tearing play some MPEG2 files problem
- Fixed MPEG2 <-> H.264 conversion play after the BDA issue can not be
- Fixed audio track switching BDA issue of machine flexibility
- Fixed some computer programs use the clip operation will lead to lethargy problem
[Note]:
Sound noise problem still in order (Wait)
chientai
Wow, ;nq;
first to say thanks for this super update. ;cheer2;
Please send me the password, Prince Wang. ;0a155537;
;shakehand; ;em25; ;ranger; ;tongue;
princewang8
( 免安裝,攜帶版 )[國際英文版]
Daum PotPlayer 1.5.22627 Beta
•Add VP8 coding support
•Add WebM playback
•Fixed related skin issues
http://depositfiles.com/en/files/i87y9zxo9
2,傷害管控,會員獨享 :PPP:
3,僅供 Beta 測試,請於下載後 24hrs 內刪除該檔.
4,嚴禁[外放][分流]
5,只提供到 06/28
6,僅供至此版為止,太累了, 反應不如預期,以後為 inter-use only
<如果你有需要請[回應]並按下右下角的[感謝] 我會用[悄悄話]回你>
[Note:]
<<<<<<< AAC 如有雜音,請改為 FFmpeg >>>>>>>
[Still in order]
