【系統檢測】AIDA64 Extreme Edition 1.00.1147 Beta (原名EVEREST)
TAS
"人"生淫家...
【軟體名稱】:AIDA64 Extreme Edition 1.00.1147 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.3 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.00.1147 Beta 更新紀錄:
* preliminary support for Intel Sandy Bridge processors
* extended CPUID features (Float-16 Conversion Instructions)
* extended CPUID features (RDRAND Instruction)
* chipset information for Intel Cougar Point PCH
* extended reference OpenGL Extensions list (for AMD Barts)
* GPU information for nVIDIA GeForce 315M (GT218M)
* GPU information for nVIDIA GeForce 320M (C89)
* GPU information for nVIDIA GeForce 405 (GT218)
* GPU information for nVIDIA GeForce 9300 GS (GT218)
* GPU information for nVIDIA GeForce GT 440 (GF108)
* GPU information for nVIDIA GeForce GT 555M (GF108M)
* GPU information for nVIDIA GeForce GTS 450 (GF106)
* GPU information for nVIDIA GeForce GTX 580 (GF110)
* GPU information for nVIDIA Ion (GT218)
* GPU information for nVIDIA Quadro 400 (GT216GL)
* GPU information for nVIDIA Quadro 6000 (GF100GL)
* motherboard specific sensor info for EVGA E635, E637, E651, E652, E653
* motherboard specific sensor info for EVGA E767, E770
* improved motherboard specific sensor info for ASRock boards
* hardware links added to DMI, OpenGL, HD Audio, Windows Devices, PCI Devices pages
* fixed: Intel QST sensor support
* fixed: chipset information for nVIDIA nForce 7025-630a (MCP68SE)
* fixed: PCH temperature measurement on Intel Ibex Peak
* fixed: voltage measurement on Gigabyte Odin GT PSUs
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的
感謝支持!也別忘了支持正版唷!
saku0520
感謝分享新版,先下來用用看!
prochang
感謝分享 , 正好需要這個
張小弟
感謝 TAS 大的分享!!
as1981
感謝分享新版本
jack26704678
感恩 下載去
Happypc
********.com低階會員
收下更新版嘍,謝謝TAS大長期提供分享...感恩 ^^ ;shakehand
yichn
謝謝分享 很實用的軟體
best no1
謝謝大大及時分享最新的軟體
