前言:
為因應 Intel即將推出了的下一代處理器,各家主機板廠也趁勢推出新規格之 Z790主機板來搭配新處理器,滄者也在最近取得了專為下一代而設計的 ASUS TUF GAMING Z790-PRO WIFI主機板 Sample,但因為下一代處理器還待上市,在等待下一代處理器上市之前,滄者就先來個 TUF GAMING軍規認證綜合開箱,並在 13700K、7800X3D雙平台效能比較,本次參與測試開箱的 TUF GAMING包含了 Z790-PRO WIFI、RTX 4070 12GB OC、LCII 360 ARGB AIO、1000W GOLD PSU,敬請持續關注
ASUS TUF GAMING Z790-PRO WIFI概述
TUF GAMING Z790-PRO WIFI LGA 1700 ATX主機板採 16+1 DrMOS供電解決方案,PCIe 5.0、 DDR5 RAM、four M.2 slots、Intel WiFi 6E、front USB USB 20Gbps,、Power Delivery (PD) 3.0、Thunderbolt 4 header、RGB燈效
TUF GAMING Z790-PRO WIFI SPEC
CPU
Intel LGA 1700 socket: Ready for Intel Core Next-Gen & 13th Gen Intel Core processors, Intel Core 12th Gen, Pentium Gold and Celeron Processors
Supports Intel Turbo Boost Technology 2.0 and Intel Turbo Boost Max Technology 3.0
Chipset
Intel Z790 Chipset
Memory
4 x DIMM slots, max. 192GB, DDR5 7800+(OC)/7600(OC)/7400(OC)/7200(OC)/7000(OC)/6800(OC)/6600(OC)/6400(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/ 5600/ 5400/ 5200/ 5000/ 4800 Non-ECC, Un-buffered Memory
Dual channel memory architecture
Supports Intel® Extreme Memory Profile (XMP) memory module
ASUS Enhanced Memory Profile II (AEMP II)
Graphics
1 x DisplayPort
1 x HDMI port
Expansion Slots
Intel Core Processors(Next-Gen & 13th & 12th )
1 x PCIe 5.0 x16 slot
Intel Z790 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
1 x PCIe 4.0 x4 slot
1 x PCIe 3.0 x16 slot (supports x1 mode)
Storage
Supports 4 x M.2 slots and 4 x SATA 6Gb/s ports
M.2_1 slot (Key M)type 2242/2260/2280/22110 (supports PCIe 4.0 x4 mode)
Intel Z790 Chipset
M.2_2 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 mode)
M.2_3 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 mode)
M.2_4 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 & SATA modes)
Ethernet
1 x Intel 2.5Gb Ethernet
TUF LANGuard
Wireless & Bluetooth
Wi-Fi 6E
2×2 Wi-Fi 6E (802.11ax)
Supports 2.4/5/6GHz frequency band
Bluetooth v5.3
USB
Rear USB (Total 8 ports)
1 x USB 20Gbps port (1 x USB Type-C)
3 x USB 10Gbps ports (2 x Type-A + 1 x USB Type-C)
4 x USB 5Gbps ports (4 x Type-A)
Front USB (Total 7 ports)
1 x USB 20Gbps connector (supports USB Type-C with up to 30W PD Fast-charge)
1 x USB 5Gbps header supports 2 additional USB 5Gbps ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC
– Impedance sense for front and rear headphone outputs
– Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
– Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
– High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
– Supports up to 32-Bit/192 kHz playback
Audio Features
– Audio Shielding
– Rear optical S/PDIF out port
– Premium audio capacitors
– Dedicated audio PCB layers
– Audio Cover
-Unique de-pop circuit
-supported for 7.1 Surround Sound audio.
Back Panel I/O Ports
1 x DisplayPort
1 x HDMI port
1 x Wi-Fi module
1 x Intel 2.5Gb Ethernet port
5 x Audio jacks
1 x Optical S/PDIF out port
Internal I/O Connectors
Fan and Cooling Related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
4 x 4-pin Chassis Fan headers
Power Related
1 x 24-pin main power connector
2 x 8-pin +12V power connectors
Storage Related
4 x M.2 slots (Key M)
USB
1 x USB 20Gbps connector (supports USB Type-C)
Miscellaneous
3 x Addressable Gen 2 headers
1 x Aura RGB header
1 x Clear CMOS header
1 x COM port header
1 x Front panel audio header (F_AUDIO)
1 x 20-3 pin system panel header with chassis intrusion function
1 x Thunderbolt (USB4) header
Special Features
ASUS TUF PROTECTION
– DIGI+ VRM (Digital power design with DrMOS)
– ESD Guards
– TUF LANGuard
– Overvoltage protection
– SafeSlot
– Stainless-steel back I/O
ASUS Q-Design
– M.2 Q-Latch
– PCIe Slot Q-Release
– Q- Antenna
– Q-DIMM
– Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
– Q-Slot
ASUS Thermal Solution
– M.2 heatsink
– VRM heatsink design
ASUS EZ DIY
– CPU Socket lever protector
– ProCool
– Pre-mounted I/O shield
– SafeDIMM
AURA Sync
– Aura RGB header
– Addressable Gen 2 headers
Front Panel USB 20Gbps with PD Fast Charge Support
– Support: up to 30W fast charging and USB Wattage Watcher
– Output: 5V/9V max. 3A, 12V max 2.5A
– Compatible with PD3.0
Software Features
ASUS Exclusive Software
Armoury Crate
– Aura Creator
– Aura Sync
– Fan Xpert 4 (with AI Cooling II)
– Power Saving
– Two-Way AI Noise Cancelation
AI Suite 3
– Easy Optimization with AI Overclocking
– TPU
– DIGI+ VRM
– Turbo app
– PC Cleaner
MyAsus
USB Wattage Watcher
TUF GAMING CPU-Z
DTS Audio Processing
Norton 360 for Gamers (60 Days Free Trial)
WinRAR (40 Days Free Trial)
UEFI BIOS
AI Overclocking Guide
ASUS EZ DIY
– ASUS CrashFree BIOS 3
– ASUS EZ Flash 3
– ASUS UEFI BIOS EZ Mode
– ASUS MyHotkey
BIOS
192 (128+64) Mb Flash ROM, UEFI AMI BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
2 x SATA 6Gb/s cables
Miscellaneous
1 x ASUS WiFi Q-Antenna
1 x TUF GAMING sticker
3 x M.2 rubber packages
1 x Screw package for M.2 SSD
Documentation
1 x TUF certification card
1 x Quick start guide
Operating System
Windows 11, Windows 10 64-bit
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
ASUS TUF GAMING Z790-PRO WIFI VS ASUS TUF GAMING Z790-PLUS WIFI比較
ASUS TUF GAMING Z790-PRO WIFI VS ASUS TUF GAMING Z790-PLUS WIFI造型大同小異,只是新的 TUF GAMING Z790-PRO WIFI官方聲稱支援記憶體超頻至 DDR5 7800 (但經測試僅跑到 DDR5 7200),TUF GAMING Z790-PLUS WIFI僅支援 DDR5 7200
⇧右側為 TUF GAMING Z790-PLUS WIFI,左側為 TUF GAMING Z790-Pro WIFI
ASUS TUF GAMING Z790-PRO WIFI開箱
彩盒正面
顯著的灰色 TUF GAMING徽圖案佔據了彩盒正面,少不了 TUF GAMING Z790-PRO WIFI品名
彩盒背面
盒裝背面印有 ASUS TUF GAMING Z790-PRO WIFI各項配置之圖片與規格說明
彩盒側面
彩盒側面印有多國語言的簡介
掀蓋
TUF一貫簡約的配置
ASUS TUF GAMING Z790-PRO WIFI主機板正面鳥瞰
16+1 DrMOS VRM供電解決方案、六層 PCB、ProCool插座、合金扼流圈和耐用電容器,4 DIMM DDR5記憶體插槽,支援 DDR5 7800+,最多可安裝 192GB容量,支援 PCIe 5.0、USB 20Gbps、前置 USB 20Gbps、Thunderbolt 4、Power Delivery 3.0
網路部分支援 WiFi 6E,配備 WiFi Q-Antenna、Intel 2.5 Gb以太網路、 TUF LANGuard,前置 USB 20Gbps,支援 PD快充,相容PD3.0,高達 30W快速充電,輸出最大 5V/9V 3A、12V 2.5A
ASUS TUF GAMING Z790-PRO WIFI主機板背面
電源相關
左側 1 x 24pin主電源插座,下側雙 8pin ATX 12V CPU電源插座
16+1 DrMOS VRM供電解決方案搭配大型散熱馬甲
Z790-PRO WIFI還支援 5組 M.2插槽,不須搭配 Hyper M.2擴充卡即可在 M.2_1插槽上實現 PCIe 5.0 x4
主機板下沿之 1 x 4pin CPU風扇插座、 1 x 4pin CPU OPT風扇插座、 1 x 4pin AIO Pump插座、4 x 4pin 機殼風扇插座
4 x DIMM slots,max 192GB,官方聲稱支援 DDR5 7800+,滄者不才僅跑到 DDR5 7200
晶片組上散熱片上的特寫「成為最後一位站立之人」(因為其他人都睡了)
音效晶片
ASUS TUF GAMING Z790-PRO WIFI不銹鋼背版 I/O
⇧1 x USB 20Gbps port (1 x USB Type-C),3 x USB 10Gbps ports (2 x Type-A + 1 x USB Type-C),4 x USB 5Gbps ports (4 x Type-A),1 x DisplayPort,1 x HDMI port,1 x Wi-Fi module,1 x Intel 2.5Gb Ethernet port,5 x Audio jacks,1 x Optical S/PDIF out port,Internal I/O Connectors
ASUS TUF GAMING Z790-PRO WIFI不銹鋼背版上的徽標與 Slogon
ASUS TUF GAMING Z790-PRO WIFI配件
1 x 華碩 WiFi Q天線
1 x TUF遊戲貼紙
3 x M.2橡膠套件
1 x M.2 SSD螺絲包
1 x 說明書
TUF GAMING雖然沒有 Debug LED但是善用 Q Led也是蠻方便的
Q Led簡易教學
接著來看 ASUS TUF GAMING LCII 360 ARGB一體式 CPU水冷散熱器開箱
彩盒正面放有 ASUS TUF GAMING LCII 360 ARGB一體式 CPU水冷散熱器之彩照
彩盒背面則標示了 ASUS TUF GAMING LCII 360 ARGB一體式 CPU水冷散熱器之規格與特色
為降低噪音,LCII水冷馬達已從 LC第一代置於水冷頭基座中分離出並外置於水冷管水道上,有助於將噪音水平保持在最低水平
LCII第二代分離式水冷馬達特寫
水冷頭散熱銅底板
更多 ASUS TUF GAMING LCII 360 ARGB一體式 CPU水冷散熱器開箱之介紹請按連結前往
跟著是 ASUS TUF GAMING 1000W GOLD PSU開箱
更多 ASUS TUF GAMING 1000W GOLD PSU開箱之介紹請按連結前往
最後是 ASUS TUF GAMING RTX 4070 12GB GDDR6X OC Edtion開箱
RTX 4070彩盒正面
RTX 4070彩盒背面
RTX 4070彩盒背面的諸元說明
移開外盒露出內盒
掀開內盒上蓋可見 RTX 4070密實的包紮在靜電袋裡,盒內還放有以下配件
1 x Collection Card、1 x Speedsetup Manual、1 x Thank you Card、1 x TUF Velcro Hook & Loop、1 x TUF Graphics card holder、1 x TUF Gaming Certificate
將 RTX 4070本體取出,先來看看 RTX 4070正面特寫,印入眼簾的是大型散熱器及 3具風扇,RTX 4070尺寸:301 x 139 x 63 mm
RTX 4070背面特寫,全覆蓋式金屬背板,骨架增加了結構剛度和通風口以提高散熱可靠性,透過增強散熱和強大電力傳輸以提升整體效能,並以堅固的背板與設計為後盾,並在遊戲上提供穩定動力,讓您無後顧之憂
RTX 4070上沿末端的 TUF GAMING徽標 RGB可以定制以顯示一系列美學和功能效果,並與其他華碩組件同步以實現均勻照明
RTX 4070單 8PIN電源接口特寫,依不同處理器建議使用 550W(Core i5、Ryzen 5)~650W(Core i7、Ryzen 7)750W(Core i9、Ryzen 9、Threadripper) PSU
RTX 4070 不鏽鋼 304背板及原生 DP 1.5a x3+原生 HDMI 2.1 x1接口,顯示卡寬度約占 3.15 Slot
RTX 4070背面散熱格柵及鰭片特寫
RTX 4070下部散熱鰭片特寫
RTX 4070之效能模式與靜音模式切換紐
測試項目:
a.UNIGINE Superposition Benchmark
b.3DMark Time Spy Extreme
c.3DMark Port Royal
d.3DMark DirectX Raytracing feature test
e.New 3DMark test measures mesh shader performance
f.Final Fantasy XV Benchmark《太空戰士15:新帝國》
g.Final Fantasy XIV Benchmark《太空戰士14:重生之境》
h.3DMark DLSS feature test
i.Far Cry 5 Benchmark 《極地戰嚎 5》
j.Far Cry 6 Benchmark 《極地戰嚎 6》
k.DIRT 5 《大地長征 5》
l.Middle-earth: Shadow of War Benchmark《中土世界:戰爭之影》
m.Ashes of the Singularity Benchmark《奇點灰燼》
n.Shadow of the Tomb Raider 《古墓奇兵:暗影》
o.Gears 5 《戰爭機器 5》
p.Assassin's Creed Odyssey《刺客信條奧德賽》
q.Total War: Warhammer《全軍破敵:戰鎚》
r.Horizon Zero Dawn《地平線 黎明時分》
s.Tom Clancy's Ghost Recon: Breakpoint Benchmark《火線獵殺:絕境》
t.Total War: Three Kingdoms《全軍破敵:三國》
u.Cyberpunk 2077《電馭叛客2077》
CPU: Intel Core i7-13700K
CPU: AMD Ryzen 7 7800X3D (對照組)
CPU Cooler:ASUS TUF GAMING LCII 360 ARGB
MB: ASUS TUF GAMING Z790-PRO WIFI
MB:ASUS ROG CTOSSHAIR X670E EXTREME (對照組)
VGA:ASUS TUF GAMING RTX 4070 OC 12GB
SSD:Kingston FURY Renegade 2TB PCIe 4.0 NVMe M.2 SSD
RAM:G.SKILL Trident Z5 DDR5 7800 32GB
RAM:G.SKILL Trident Z5 Neo RGB DDR5 6000 16GBX2 (對照組)
PSU:ASUS TUF GAMING 1000W GOLD PSU
OS:Windows11 pro 64bit
電源計畫:High Performance
Temperature :Room Temp. 29°C
ASUS TUF GAMING Z790-PRO WIFI平台燈效
ARGB Setting
CPU Fan Setting
AIO Pump Setting
測試諸元
Core i7-13700K
對照組
7800X3D
測試項目
UNIGINE是一款專有的跨平台遊戲引擎,由俄羅斯軟件公司 UNIGINE Corp開發。除了用作遊戲引擎外,它還用於虛擬現實系統,嚴肅遊戲和可視化 UNIGINE最強大的功能是它的高級渲染器,支持 OpenGL 4.0和 DirectX 11,Superposition則為 2017版本,包含極端性能和穩定性測試:視頻卡,電源,冷卻系統,檢查預設和超頻模式與真實負載及在環境中的互動體驗
Benchmark Extreme Results
13700K 4K UNIGINE Superposition Benchmark 4K Optimazed:13754分
7800X3D 4K UNIGINE Superposition Benchmark 4K Optimazed:13687分
UNIGINE Superposition 4K Optimazed Benchmark比較表
⇧單位: fPerformance Score數字愈大愈好
3DMark Time Spy用來測試處理器及顯示卡之 3D圖形表現和工作負載,現由 UL擁有,主要是針對 DirectX 12的效能,測試有三個部分,第一個為顆粒陰影、曲面細分等效果,第二個則是光線追蹤的體積光照明技術,最後則是 CPU效能測試,在前兩個測試中,包含了數千萬個頂點跟多邊形,上百萬個曲面細分,這些都是 FireStrike的幾十倍,而 3DMark Time Spy Extreme是 3DMark Time Spy的 4K版本,所有圖形都是 4K規格
13700K 3DMark Time Spy Extreme Results:8787分
7800X3D 3DMark Time Spy Extreme Results:7959分
3DMark Time Spy Extreme Benchmark測試比較表
⇧單位:Score數字愈大愈好
c.3DMark Port Royal
3DMark之 Port Royal加入 DirectX 12 的 DXR(DirectX Raytracing)選用 API集,能夠於當代遊戲大量使用的光柵化成像,加入即時光影追蹤效果,以便達成視區外物件反射、即時陰影等光柵化無法達成的畫面效果
13700K 3DMark Port Royal Results:11147分
7800X3D 3DMark Port Royal Results:10988分
3DMark Port Royal Benchmark測試比較表
⇧單位:Score數字愈大愈好
GPU上的實時光線追踪非常重要,最新的顯卡具有針對光線追踪操作進行了優化的專用硬件,儘管 GPU性能取得了進步,但對於僅依賴光線追踪的遊戲來說,要求仍然太高,這就是為什麼遊戲使用光線追踪來補充傳統渲染技術的原因 3DMark DirectX光線追踪功能測試旨在使光線追踪性能成為限制因素,不再依賴傳統渲染,而是一次通過光線追踪和繪製整個場景。測試結果完全取決於光線追踪性能,這意味著您可以測量和比較最新顯卡中專用光線追踪硬件的性能。
13700K 3DMark DirectX Raytracing feature test Results:52.52fps
對照組
7800X3D 3DMark DirectX Raytracing feature test Results:51.77fps
3DMark DirectX Raytracing feature test測試比較表
⇧單位: fps數字愈大愈好
DirectX 12 Ultimate 為 DirectX 12 添加了強大的新特性和功能,包括 DirectX Raytracing Tier 1.1、網格著色器、採樣器反饋和可變速率著色 (VRS) 在 DirectX 12 Ultimate發布後,我們開始向 3DMark添加新測試,以展示遊戲如何從這些新功能中受益 我們最新添加的是3DMark 網格著色器功能測試,這是一項新測試,展示了遊戲開發人員如何通過在圖形管道中使用網格著色器來提高幀速率
New 3DMark test measures mesh shader performance Results
13700K mesh Shader off 277.83fps mesh Shader on 530.44fps
7800X3D mesh Shader off 274.46fps mesh Shader on 528.20fps
New 3DMark test measures mesh shader performance測試比較表
⇧單位: fps數字愈大愈好
f.Final Fantasy XV BenchmarkFinal Fantasy XV《太空戰士 15》的 Benchmark,是一款由史克威爾艾尼克斯在 2016年 11月推出的動作角色扮演遊戲《Final Fantasy系列》的第 15部,依照傳統,太空戰士都有 Benchmark的項目
13700K Final Fantasy XV 4K Benchmark:7531分
7800X3D Final Fantasy XV 4K Benchmark:7546分
Final Fantasy XV Benchmark 4K High Quality Benchmark《太空戰士 15》比較表
⇧單位:fPerformance Score數字愈大愈好
《Final Fantasy XIV》(日語:ファイナルファンタジーXIV,英語:Final Fantasy XIV)是 Final Fantasy系列的第 14部本傳遊戲,也是繼《Final Fantasy XI》之後又一款大型多人線上角色扮演遊戲。遊戲由史克威爾艾尼克斯開發並發行,依照傳統,太空戰士都有 Benchmark的項目
13700K Final Fantasy XIV 4K Benchmark:15157分
7800X3D Final Fantasy XIV 4K Benchmark:15065分
Final Fantasy XIV Benchmark 4K High Quality Benchmark《太空戰士 14》比較表
⇧單位: Performance Score數字愈大愈好
3DMark DLSS feature test Results
13700K DLSS3 off 23.57fps
DLSS3 on 86.55fps
7800X3D DLSS3 off 23.22fps
DLSS3 on 85.62fps
3DMark DLSS feature test測試比較表
⇧單位: fps數字愈大愈好
Far Cry 5《極地戰嚎5》是一個自帶 Benchmark的新遊戲,是由育碧蒙特婁、育碧多倫多開發和育碧軟體發行的開放世界第一人稱動作冒險遊戲
1440P
13700K Far Cry 5 Benchmark Ave Results Ave 191fps
7800X3D Far Cry 5 Benchmark Ave Results Ave 193fps
Far Cry 5 1440P Benchmark《極地戰嚎5》測試比較表
⇧單位:fps數字愈大愈好
j.Far Cry 6《極地戰嚎6》
Far Cry 6《極地戰嚎6》(英語:Far Cry 6,中國大陸譯作「孤島驚魂6」)是一款由育碧多倫多開發並由育碧發行在 Amazon Luna、Microsoft Windows、PlayStation 4、PlayStation 5、Xbox One、Xbox Series X/S和 Google Stadia平台上的動作冒險第一人稱射擊遊戲,是極地戰嚎系列的第六部正統作品 《極地戰嚎6》支援 AMD FidelityFX Super Resolution (FSR)、AMD FreeSync Premium Pro,以及 AMD FidelityFX視覺工具套件,包括在未使用 FSR時的對比調適銳化(CAS)這項不受硬體限制的動態銳化濾鏡可改善低對比畫面區域的細節,提高影像清晰度並針對因後製而導致柔化的影像進行銳化處理,確保在激烈對戰時視線不會被阻擋
Setting
13700K Far Cry 6 Benchmark Ave Results Ave :159fps
7800X3D Far Cry 6 Benchmark Ave Results Ave :158fps
Far Cry 6 1440P Benchmark《極地戰嚎6》測試比較表
⇧單位:fps數字愈大愈好
k.DIRT 5 《大地長征 5》
DIRT 5 《大地長征 5》是一款專注於越野賽車的賽車遊戲。遊戲中的紀律包括拉力賽,冰上賽車,體育場超級卡車和越野車。玩家可以在亞利桑那州,巴西,摩洛哥,中國,意大利,紐約市和挪威等眾多地區的比賽項目中比賽,遊戲包含動態天氣系統和季節,影響賽車;例如,玩家只能在冬季參加紐約的冰上比賽。遊戲中還引入了四人分屏系統 DIRT 5還具有敘述性的職業生涯模式,在一系列錦標賽中,玩家角色與競爭對手布魯諾·杜蘭德(Blano Durand)(由諾蘭·諾斯(Nolan North)表達)相對,玩家還有一位名為 Alex“ AJ”Janiček的導師(由 Troy Baker講),在整個職業生涯中為他們提供建議
Setting
1440P
13700K DIRT 5 Benchmark Results:139.6fps
7800X3D DIRT 5 Benchmark Results:141.16fps
DIRT 5 1440P Benchmark《大地長征 5》測試比較表
⇧單位:fps數字愈大愈好
Middle-earth: Shadow of War《中土世界:戰爭之影》亦為一自帶 Benchmark的角色扮演遊戲,是由 Monolith Productions開發並由華納兄弟互動娛樂發行並於 2017年 10月 10日在全球發布
Setting
1440P
13700K Middle-earth: Shadow of War Benchmark:157fps
7800X3D Middle-earth: Shadow of War Benchmark:155fps
Middle-earth: Shadow of War 1440P Benchmark《《中土世界:戰爭之影》測試比較表
⇧單位:fps數字愈大愈好
Ashes of the Singularity Benchmark《奇點灰燼》是一款科幻即時戰略遊戲,號稱全球首款基於 Win10系統的 DX12遊戲,采用 Oxide Games的 Nitrous引擎打造,背景設定在遙遠的未來,那時人類完全以意識形態存在,人們已經掌握了上帝一樣的力量。但是人類發現自己已經處於戰爭之中,敵人就是一個叫做 “Haalee”的具有意識形態的 AI,企圖推翻人類在宇宙之中的統治地位
Setting
1440P
13700K Ashes of the Singularity Benchmark Results:179.7fps
7800X3D Ashes of the Singularity Benchmark Results:187.5fps
Ashes of the Singularity 1440P Benchmark《奇點灰燼》測試比較表
⇧單位:fps數字愈大愈好
《古墓奇兵:暗影》(英語:Shadow of the Tomb Raider)是一款由藝奪蒙特婁開發,史克威爾艾尼克斯發行的動作冒險遊戲,是繼2013年《古墓奇兵》和2015年《古墓奇兵:崛起》後古墓奇兵重啟系列的第三部作品,也是該系列第11部主要系列作品。遊戲在2018年9月14日發行於 Microsoft Windows、PlayStation 4和Xbox One平台。本作包含繁簡中文字幕及中文配音。遊戲的macOS、Linux版本由Feral Interactive於2019年11月5日發行,Stadia版則在2019年11月19日發布
Setting
1440P
13700K Shadow of the Tomb Raider Benchmark Results:264fps
7800X3D Shadow of the Tomb Raider Benchmark Results:293fps
Shadow of the Tomb Raider 1440P Benchmark《古墓奇兵:暗影》測試比較表
⇧單位:fps數字愈大愈好
o.Gears 5 《戰爭機器 5》
《戰爭機器 5》(英語:Gears 5)是一款已上市的第三人稱射擊的電子遊戲,由 The Coalition 製作,並由 Xbox遊戲工作室作為 Xbox Play Anywhere 的一部份發表於 Microsoft Windows 和 Xbox One 平台上。這是第六款《戰爭機器》系列的遊戲,同時作為 2016年的作品《戰爭機器 4》的續作。該作品已在 2019年 9月 10日正式發行。2020年 3月,The Coalition確認本作將在新世代主機 Xbox Series X發售首日發布對應新平台主機的版本
Setting
1440P
13700K Gears 5 Benchmark Results:165.5fps
7800X3D Gears 5 Benchmark Results:161.5fps
Gears 5 1440P Benchmark《戰爭機器 5》測試比較表
⇧單位:fps數字愈大愈好
(英語:Assassin's Creed Odyssey,中國大陸譯作「刺客信條:奧德賽」) 是由魁北克育碧( Ubisoft Quebec)開發,育碧( Ubisoft)發行的動作角色扮演視頻遊戲。這是《刺客教條》系列的第十一個主要部分,總體上是第 21個,是 2017年《刺客教條》起源的繼任者。該情節設定於公元前 431-422年,講述了雅典和斯巴達之間的伯羅奔尼撒戰爭的神話歷史。玩家控制男性或女性傭兵(古希臘: μίσθιος misthios )在試圖團結家人的同時在衝突雙方中戰鬥的人
Setting
1440P
13700K Assassin's Creed Odyssey Benchmark Results:102fps
7800X3D Assassin's Creed Odyssey Benchmark Results:100fps
Assassin's Creed Odyssey 1440P Benchmark《刺客信條奧德賽》 測試比較表
⇧單位:fps數字愈大愈好
Total War: Warhammer《全軍破敵:戰鎚》(英語:Total War: Warhammer,中國大陸譯作「全面戰爭:戰錘」)是一款由 Creative Assembly開發,經 SEGA公司通過Steam向Microsoft Windows、Linux、Mac OS平台發行的電子遊戲。本作結合了全軍破敵系列的玩法和 Games Workshop公司戰鎚系列的背景設定;所以是全軍破敵系列第一款非歷史背景的作品。本作是《全軍破敵系列》第十部作品及「全軍破敵:戰鎚」三部曲的首作
Setting
1440P
13700K Battle Benchmark 94.6fps
13700K Campaign Benchmark 90.5fps
7800X3D Battle Benchmark 94.5fps
7800X3D Campaign Benchmark 90.5fps
Total War: Warhammer 1440P Benchmark《全軍破敵:戰鎚》測試比較表
⇧單位:fps數字愈大愈好
《地平線 黎明時分》(英語:Horizon Zero Dawn,中國大陸譯作「地平線 零之曙光」,又譯作「地平線 期待黎明」、「地平線 零點黎明」,符號化為(HORIZON ZERO DΛWN)是由 Guerrilla Games開發並由索尼互動娛樂發行在 PlayStation 4平台的動作角色扮演遊戲,在 2017年開始全球發布,SIE在2020年 3月 10日發表本作將於夏季正式登陸在 PC平台上,而在 2020年 8月 7日正式登入 steam與 epic平台,是首次有 SIE全球工作室的自家旗下工作室的遊戲作品脫離獨佔,在 PlayStation以外的平台上發行,且這次由 AMD與 Guerilla聯手合作,在《地平線:期待黎明》Horizon Zero Dawn PC完全版 8/7發表當天同步釋出支援,為採用 DirectX 12的 Radeon遊戲玩家提供令人屏息的視覺特效與強悍的效能
Setting
關閉 DLSS
1440P
13700K Horizon Zero Dawn Benchmark Results:152fps
7800X3D Horizon Zero Dawn Benchmark Results:154fps
Horizon Zero Dawn 1440P Benchmark《地平線 黎明時分》測試比較表
⇧單位:fps數字愈大愈好
Tom Clancy's Ghost Recon: Breakpoint Benchmark《火線獵殺:絕境》中國大陸譯作「幽靈行動:斷點」,全稱「湯姆·克蘭西之火線獵殺:絕境」)是一款由育碧巴黎開發,育碧發行的戰術射擊遊戲。本作是火線獵殺系列的第 8部作品。遊戲於 2019年 10月 4日在 PlayStation 4、Xbox One和 Windows平台發售,遊戲在發售後獲得了業界相當一般的評價
Setting
1440P
13700K Tom Clancy's Ghost Recon: Breakpoint Benchmark 135fps
7800X3D Tom Clancy's Ghost Recon: Breakpoint Benchmark 135fps
Tom Clancy's Ghost Recon: Breakpoint 1440P Benchmark《火線獵殺:絕境》 測試比較表
⇧單位:fps數字愈大愈好
t.Cyberpunk 2077 《電馭叛客 2077》
Cyberpunk 2077《電馭叛客2077》(英語:Cyberpunk 2077,中國大陸譯作「賽博朋克2077」,香港常用英文)是一款由CD Projekt開發並於 2020年 12月 10日發行的動作角色扮演遊戲。本作採用了桌上遊戲《電馭叛客 2020》的世界觀與規則設計,背景為2077年美國加利福尼亞州的「賽博龐克」風格反烏托邦式城市「夜城」,玩家在這一開放世界中扮演名為「V」的僱傭兵
Setting
關閉 DLSS
13700K Cyberpunk 2077 1440P Benchmark Ave 83.11fps
7800X3D Cyberpunk 2077 1440P Benchmark Ave 78.87fps
Cyberpunk 2077 1440P Benchmark《電馭叛客 2077》 測試比較表
⇧單位:fps數字愈大愈好
小結 :
TUF GAMING是 ASUS遊戲產品中的一個設計系列,旨在提供耐用性和高性能,這些設計特點包括強化的零組件、冷卻解決方案以及特別的外觀風格,以滿足遊戲愛好者的需求,採用 TUF GAMING設計之產品已橫跨 MOBO、Graphic Card、CPU Cooler、PSU、MONITOR以及 MOUSE、KEYBOARD等週邊裝置,而無論是使用 Intel處理器加 ASUS TUF GAMING Z790-PRO WIFI,或是 3D V-Cache加 ASUS TUF GAMING X670E系列主機板,當再搭配 10年保固的 ASUS TUF GAMING 1000W GOLD PSU、五年保固的 ASUS TUF GAMING RTX 4070 OC 12G,就都是一款既經濟又耐久的實用遊戲平台,謝謝收看
- Intel LGA 1700 插槽:適用於 Intel Core下一代和第 13代 Intel Core處理器、Intel Core第 12代、Pentium Gold和 Celeron處理器
- 優質電源解決方案: 16+1 DrMOS VRM供電解決方案、六層 PCB、ProCool插座、合金扼流圈和耐用電容器,可實現穩定的電力傳輸
- 獨家 AI與記憶體技術: AI Overclocking、AI Cooling II、雙向 AI降噪和 ASUS Enhanced Memory Profile II記憶體技術
- 下一代連接: PCIe 5.0、USB 20Gbps、前置 USB 20Gbps、Thunderbolt 4、 Power Delivery 3.0
- 專為線上遊戲而設計: WiFi 6E配備 WiFi Q-Antenna、Intel 2.5 Gb以太網路、 TUF LANGuard
- 雙向人工智能降噪:減少麥克風和音頻輸出的背景噪音,在遊戲或視頻會議中實現清晰的通信
- 全面冷卻:加大 VRM和晶片組散熱器、M.2散熱器、混合風扇接頭連接器以及 Armoury Crate中的 Fan Xpert 4應用程式
- Aura Sync RGB燈效:時尚的邊緣照明設計、可尋址 RGB接頭和 RGB條形接頭支持
- PC DIY友善設計: PCIe插槽 Q-Release、M.2 Q-Latch、Q-LED、Q-Antenna、SafeSlot
CPU
Chipset
Intel Z790 Chipset
Memory
Graphics
1 x DisplayPort
1 x HDMI port
Expansion Slots
Intel Z790 Chipset
Storage
Intel Z790 Chipset
Ethernet
TUF LANGuard
Wi-Fi 6E
Bluetooth v5.3
USB
Audio
Audio Features
– Audio Shielding
– Audio Cover
1 x DisplayPort
1 x HDMI port
1 x Wi-Fi module
5 x Audio jacks
Power Related
Storage Related
USB
Miscellaneous
1 x Aura RGB header
1 x COM port header
Special Features
ASUS TUF PROTECTION
– ESD Guards
– TUF LANGuard
– SafeSlot
ASUS Q-Design
– M.2 Q-Latch
– Q- Antenna
– Q-DIMM
– Q-Slot
– M.2 heatsink
ASUS EZ DIY
– ProCool
– SafeDIMM
AURA Sync
– Aura RGB header
Software Features
Armoury Crate
– Aura Creator
– Aura Sync
– Power Saving
AI Suite 3
– TPU
– DIGI+ VRM
– Turbo app
– PC Cleaner
MyAsus
USB Wattage Watcher
TUF GAMING CPU-Z
UEFI BIOS
ASUS EZ DIY
– ASUS EZ Flash 3
– ASUS MyHotkey
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
Miscellaneous
Documentation
Operating System
Form Factor
ATX Form Factor
彩盒正面
彩盒背面
彩盒側面
彩盒側面印有多國語言的簡介
掀蓋
TUF一貫簡約的配置
電源相關
音效晶片
1 x 華碩 WiFi Q天線
1 x TUF遊戲貼紙
3 x M.2橡膠套件
1 x M.2 SSD螺絲包
1 x 說明書
Q Led簡易教學
LCII第二代分離式水冷馬達特寫
水冷頭散熱銅底板
RTX 4070彩盒正面
RTX 4070彩盒背面
RTX 4070彩盒背面的諸元說明
移開外盒露出內盒
RTX 4070背面散熱格柵及鰭片特寫
RTX 4070下部散熱鰭片特寫
測試項目:
c.3DMark Port Royal
k.DIRT 5 《大地長征 5》
o.Gears 5 《戰爭機器 5》
ARGB Setting
CPU Fan Setting
AIO Pump Setting
測試諸元
Core i7-13700K
對照組
7800X3D
測試項目
⇧單位:Score數字愈大愈好
c.3DMark Port Royal
⇧單位:Score數字愈大愈好
對照組
⇧單位: fps數字愈大愈好
⇧單位: fps數字愈大愈好
DLSS3 on 86.55fps
DLSS3 on 85.62fps
⇧單位: fps數字愈大愈好
1440P
⇧單位:fps數字愈大愈好
j.Far Cry 6《極地戰嚎6》
Setting
⇧單位:fps數字愈大愈好
k.DIRT 5 《大地長征 5》
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
1440P
⇧單位:fps數字愈大愈好
o.Gears 5 《戰爭機器 5》
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
關閉 DLSS
1440P
⇧單位:fps數字愈大愈好
Setting
1440P
⇧單位:fps數字愈大愈好
Setting
關閉 DLSS
⇧單位:fps數字愈大愈好
小結 :
