1.品名 :ZEROtherm CF800(銅底+熱導x4)
2.數量 : 1組
3.品相及保固 :正常使用2個月
4.售價 :600 , 郵寄+70
5.地點 :龍山寺捷運面交
6.交易方式:面交 郵寄
產品規格
ㆍSupport CPU list
Intel Core™ 2 Exterme(Socket LGA775)
Intel Core™ 2 Duo (Socket LGA775)
Intel Pentium Extreme Edition (Socket LGA 775)
Intel Pentium D (Socket LGA 775)
Intel Pentium 4 (Socket LGA775)
Intel Celeron D (Socket LGA775)
ㆍDimension
100(L) x 94(W) x 77(H) mm
ㆍHeatsink Material
Fin : Aluminum
Base : Copper
Heatpipe : Copper
ㆍHeat Dissipation Area 2,360 ㎠
ㆍCooling Capacity Up to 130W
ㆍFan Dimension 92 x 25 mm
ㆍFan Speed Automatic fan speed control by Temp. sensor
800~2,300 rpm (± 10%), normally under 1,500 rpm
ㆍAcoustical Noise Max. 27 dBA (± 10%), normally under 18 dBA
ㆍAir Flow Max. 42.8 CFM
ㆍFan Connector 4-pin, 3-wire (NOT support PWM)
ㆍRated Voltage DC 12V
ㆍWeight 357g (w/o optional components)
2.數量 : 1組
3.品相及保固 :正常使用2個月
4.售價 :600 , 郵寄+70
5.地點 :龍山寺捷運面交
6.交易方式:面交 郵寄
產品規格
ㆍSupport CPU list
ㆍDimension
ㆍHeatsink Material
Fin : Aluminum
Base : Copper
Heatpipe : Copper
