Yamaha TZR 125/250
Make Model
Yamaha TZR 125
Year 1987
Engine
Liquid cooled, single cylinder, two stroke, , read valve,
Capacity
124
Bore x Stroke 56.4 x 50 mm
Compression Ratio 5.9:1
Induction
Mikuni VM26SS carbs
Ignition / Starting
CDI
Max Power
26.hp @ 10200 rpm
Max Torque
1.8 kg-m @ 10000 rpm
Transmission / Drive
6 Speed / chain
Front Suspension
Telescopic fork 140mm wheel travel
Rear Suspension
Monocross 100mm wheel travel.
Front Brakes
Single disc
Rear Brakes
Drum
Front Tyre
90/90 16
Rear Tyre
100/90 18
Dry-Weight / Wet-Weight
104 kg / 122.7 kg
Fuel Capacity
12 Litres
Consumption average
21.5 km/lit
Braking 60 - 0 / 100 - 0
13.8 m / 39.6 m
Standing ¼ Mile
15.8 sec / 130.6 km/h
Top Speed
154.7 km/h
Make Model
Yamaha TZR 125R
Year
1991
Engine
Liquid cooled, single cylinder, two stroke, , reed valve,
Capacity
124
Bore x Stroke 124
Compression Ratio 56.4 x 50 mm
Induction
5.9:1
Ignition / Starting
Max Power
Max Torque
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
2x discs
Rear Brakes
Single disc
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Make Model
Yamaha TZR 125R
Year
1993
Engine
Liquid cooled, two stroke, single cylinder, reed valve,
Capacity
124
Bore x Stroke 56 x 50.7 mm
Compression Ratio 6.2:1
Induction
Mikuni TM28SS carb
Ignition / Starting
Max Power
Max Torque
6 Speed / chain
Front Suspension
39mm Upside-down forks, 120mm wheel travel.
Rear Suspension
Monoshock adjustable preload,
Front Brakes
Single disc 4 piston calipers
Rear Brakes
Single disc 2 piston caliper
Front Tyre
110/70-17
Rear Tyre
140/70-17
Dry-Weight
136 kg
Fuel Capacity
15 Litres
Make Model
Yamaha TZR 250 (2MA)
Year
1985
Engine
Liquid cooled, two stroke, parallel twin cylinders, read valve,
Capacity
249
Induction
2x Mikuni TM28SS carbs
Ignition / Starting
CDI
Max Power
50 hp 36.4 kW @ 10000 rpm
Max Torque
35.5 Nm @ 9750 rpm
6 speed / chain
Front Suspension
Telescopic fork adjustable preload 140mm wheel travel,
Rear Suspension
Coil and gas spring preload 9-way preload position, 100mm wheel travel.
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
128 kg / 140 kg
Fuel Capacity
16 Litres (4L)
Make Model
Yamaha TZR 250
Year
1988
Engine
Capacity
249
Induction
Ignition / Starting
CDI
Max Power
Max Torque
35.5 Nm @ 9750 rpm
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
128 kg / 140 kg
Fuel Capacity
16 Litres (4L)
Make Model
Yamaha TZR 250 (3MA)
Year
1989
Engine
Liquid cooled, two stroke, parallel twin cylinder, read valve,
Capacity
249
Compression Ratio 7.2:1
Induction
2x 32mm Mikuni carbs
Ignition / Starting
CDI
Max Power
Max Torque
35.5 Nm @ 9750 rpm
6 Speed / chain
Front Suspension
37mm Telescopic fork adjustable preload 140mm wheel travel,
Rear Suspension
Front Brakes
Single 320mm discs 2 piston calipers
Rear Brakes
Single 210mm disc 1 piston caliper
Front Tyre
110/80-17
Rear Tyre
140/70-18
Dry-Weight
136 kg
Fuel Capacity
16.5 Litres
Make Model
Yamaha TZR 250SP
Year
1990
Engine
Capacity
249
Compression Ratio
Induction
Ignition / Starting
Max Power
Max Torque
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Make Model
Yamaha TZR 250R (3XV)
Year
1991
Engine
Liquid cooled, two stroke, 90° V-Twin cylinder, read valve induction
Capacity
249.7
Compression Ratio 7.5:1
Induction
2x Mikuni flatside carbs
Ignition / Starting
Microcomputer controlled
Max Power
45 hp @ 9500 rpm
Max Torque
3.8 kg-m @ 8000 rpm
6 speed / chain
Front Suspension
Rear Suspension
Monocross linkage
Front Brakes
2X disc 4 piston calipers
Rear Brakes
Front Tyre
110/70 Z17
Rear Tyre
150/60 Z17
Dry-Weight
126 kg
Fuel Capacity
Top Speed
112 mpg 180.2 kmh
Make Model
Yamaha TZR 250R-SP (3XV)
Year
1991
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
Max Torque
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Top Speed
Make Model
Yamaha TZR 250RS
Year
1992
Engine
Capacity
249.7
Induction
2x Mikuni flatslide carbs
Ignition / Starting
Max Power
45 hp @ 9500 rpm
Max Torque
3.8 kg-m @ 8000 rpm
6 Speed / chain
Front Suspension
Rear Suspension
Monocross linkage
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Top Speed
112 mpg 180.2 kmh
Make Model
Year
1993
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
Max Torque
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Consumption average
Standing ¼ Mile
Top Speed
112 mpg 180.2 kmh
Make Model
Yamaha TZR250R-SPR
Year
1995
Engine
Capacity
249.7
Bore x Stroke 56 x 50.7mm
Induction
Ignition / Starting
Max Power
45 hp @ 9500 rpm
Max Torque
3.8 kg-m @ 8000 rpm
6 speed / chain
Front Suspension
Rear Suspension
Monocross linkage
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Top Speed
112 mp/g 180.2 km/h
![Yamaha%20TZR125%2087%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR125%2087%20%201.jpg)
Make Model
Yamaha TZR 125
Year 1987
Engine
Capacity
124
Induction
Mikuni VM26SS carbs
Ignition / Starting
CDI
Max Power
26.hp @ 10200 rpm
Max Torque
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
Single disc
Rear Brakes
Drum
Front Tyre
90/90 16
Rear Tyre
100/90 18
104 kg / 122.7 kg
Fuel Capacity
12 Litres
Consumption average
21.5 km/lit
13.8 m / 39.6 m
Standing ¼ Mile
Top Speed
154.7 km/h
![Yamaha%20TZR125%2087.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR125%2087.jpg)
![Yamaha%20TZR125R%2091.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR125R%2091.jpg)
Make Model
Yamaha TZR 125R
Year
1991
Engine
Capacity
124
Bore x Stroke 124
Induction
5.9:1
Ignition / Starting
Max Power
Max Torque
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
2x discs
Rear Brakes
Single disc
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
![Yamaha%20TZR125R%2093%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR125R%2093%20%201.jpg)
Make Model
Yamaha TZR 125R
Year
1993
Engine
Capacity
124
Induction
Mikuni TM28SS carb
Ignition / Starting
Max Power
Max Torque
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
110/70-17
Rear Tyre
140/70-17
Dry-Weight
136 kg
Fuel Capacity
15 Litres
![Yamaha%20TZR125R%2093.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR125R%2093.jpg)
![Yamaha%20TZR250%2085.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2085.jpg)
Make Model
Year
1985
Engine
Capacity
249
Induction
Ignition / Starting
CDI
Max Power
Max Torque
35.5 Nm @ 9750 rpm
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
128 kg / 140 kg
Fuel Capacity
16 Litres (4L)
![Yamaha%20TZR250%2085%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2085%20%201.jpg)
![Yamaha%20TZR250%2086.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2086.jpg)
![Yamaha%20TZR250%2088%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2088%20%201.jpg)
Make Model
Yamaha TZR 250
Year
1988
Engine
Capacity
249
Induction
Ignition / Starting
CDI
Max Power
Max Torque
35.5 Nm @ 9750 rpm
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
128 kg / 140 kg
Fuel Capacity
16 Litres (4L)
![Yamaha%20TZR250%2088.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2088.jpg)
![Yamaha%20TZR250%2090%20%202.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2090%20%202.jpg)
Make Model
Year
1989
Engine
Capacity
249
Induction
Ignition / Starting
CDI
Max Power
Max Torque
35.5 Nm @ 9750 rpm
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
110/80-17
Rear Tyre
140/70-18
Dry-Weight
136 kg
Fuel Capacity
16.5 Litres
![Yamaha%20TZR250%2090%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2090%20%201.jpg)
![Yamaha%20TZR250%2090%20%203.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2090%20%203.jpg)
![Yamaha%20TZR250%2090%20SP.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250%2090%20SP.jpg)
Make Model
Yamaha TZR 250SP
Year
1990
Engine
Capacity
249
Compression Ratio
Induction
Ignition / Starting
Max Power
Max Torque
6 Speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
![Yamaha%20TZR250R%2091%20%202.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250R%2091%20%202.jpg)
Make Model
Year
1991
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
45 hp @ 9500 rpm
Max Torque
3.8 kg-m @ 8000 rpm
6 speed / chain
Front Suspension
Rear Suspension
Monocross linkage
Front Brakes
Rear Brakes
Front Tyre
110/70 Z17
Rear Tyre
150/60 Z17
Dry-Weight
126 kg
Fuel Capacity
Top Speed
112 mpg 180.2 kmh
![Yamaha%20TZR250R%2091%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250R%2091%20%201.jpg)
![Yamaha%20TZR250R%2092%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250R%2092%20%201.jpg)
![Yamaha%20TZR250RSP%2091.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250RSP%2091.jpg)
Make Model
Year
1991
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
Max Torque
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Top Speed
![Yamaha%20TZR250RS%2092.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250RS%2092.jpg)
Make Model
Yamaha TZR 250RS
Year
1992
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
45 hp @ 9500 rpm
Max Torque
3.8 kg-m @ 8000 rpm
6 Speed / chain
Front Suspension
Rear Suspension
Monocross linkage
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Top Speed
112 mpg 180.2 kmh
![Yamaha%20TZR250RS%2093.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250RS%2093.jpg)
![Yamaha%20TZR250RS%2094.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250RS%2094.jpg)
![Yamaha%20TZR250R%2093.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250R%2093.jpg)
Make Model
Year
1993
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
Max Torque
6 speed / chain
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Consumption average
Standing ¼ Mile
Top Speed
112 mpg 180.2 kmh
![Yamaha%20TZR250SP%2094.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250SP%2094.jpg)
Make Model
Yamaha TZR250R-SPR
Year
1995
Engine
Capacity
249.7
Induction
Ignition / Starting
Max Power
45 hp @ 9500 rpm
Max Torque
3.8 kg-m @ 8000 rpm
6 speed / chain
Front Suspension
Rear Suspension
Monocross linkage
Front Brakes
Rear Brakes
Front Tyre
Rear Tyre
Dry-Weight
Fuel Capacity
Top Speed
112 mp/g 180.2 km/h
![Yamaha%20TZR250SP%2095%20%201.jpg](http://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20TZR250SP%2095%20%201.jpg)
