簡介:
XnView來自法國,是一款非常棒的看圖程式,豪不遜色於ACDSee。支持100多種圖片格式,安裝插件後支持圖片格式近500種。
除了一般的查看、瀏覽、幻燈顯示等功能外,還內建多種濾鏡,方便編輯修改;可以批次轉換文件格式,小巧實用。
Change Log:
- Link problem - http://newsgroup.xnview.com/viewtopic.php?t=11788
- Save selection - http://newsgroup.xnview.com/viewtopic.php?t=11760
- Column with - http://newsgroup.xnview.com/viewtopic.php?t=11796
- File open/Save dialog on NT
- Sort by descriptio - http://newsgroup.xnview.com/viewtopic.php?t=11787
- no sound in exe slide - http://newsgroup.xnview.com/viewtopic.php?t=11767
- category pane - http://newsgroup.xnview.com/viewtopic.php?t=11739
- No files in convert - http://newsgroup.xnview.com/viewtopic.php?t=11746
- Del in fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=11806
- Blanck screen in fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=11734
- Files with different X/Y DPI - http://newsgroup.xnview.com/viewtopic.php?t=11705
- Partition as favorite - http://newsgroup.xnview.com/viewtopic.php?t=11709
- Dos filename - http://newsgroup.xnview.com/viewtopic.php?t=11702
ShareBig
YouSendIt
解壓密碼:KoFung@CBB
Change Log:
ShareBig
YouSendIt
解壓密碼:KoFung@CBB
