X800Pro to X800XT-PE
北京小胡
Before Proceeding
Make sure you have 1.6ns Samsung GRam.
This guide absolutely works, don't forget to underclock your XT to about 20Mhz lower than stock XT settings, it will run a lot more stable.
Also after the flash if your display does not post then remove the svideo cable from your video card if there is 1 plugged in, and reboot and it will post - i had the same problem. Running perfectly - it never goes above 52 C
Here a Link to ATi Tool with which you can check your pipelines and clock - http://atitool.ocfaq.com/
Heres a screenshot and proof it works
http://ottomans.home.comcast.net/mod.bmp
ATI RADEON X800 Pro VIVO > X800 XT
BIOS FLASH GUIDE
Equipment & files required
2 x floppy discs
DrDos boot disk creator: HERE
http://paddy007uk.freeservers.com/VGAbios/drdflash.exe
FlashROM 2.37 + floppy creator: HERE
http://paddy007uk.freeservers.com/VGAbios/...+Floppy2.37.exe
Gigabyte Flash utility & X800 XT BIOS: HERE
http://paddy007uk.freeservers.com/VGAbios/...,0&at_a_time=50
Retail ATI X800 XT BIOS: HERE
http://paddy007uk.freeservers.com/VGAbios/X800XT.bin
**BEFORE FLASHING THE BIOS, MAKE SURE YOU MAKE A BACKUP OF YOUR OLD ONE**
To back up your BIOS: (Floppy 'A')
(a) Create a bootable floppy disc with flashrom on it by double clicking the Flasher+Floppy2.37.exe.
(B) Restart the PC with the floppy disc inserted & boot in DOS.
© Once activity has ceased you will be at the A: prompt, type the following command line to back up your existing BIOS:
flashrom -s 0 backup.bin
You now have a file on the floppy disc named 'backup.bin' this is your original BIOS which you may require at a later date.
(d) Remove the floppy disc & reboot the PC.
To flash to the Gigabyte X800XT BIOS for enabling the 4 locked pipelines (Floppy 'B')
(a) Create a bootable floppy disc by double clicking the DrDos boot disc creator.
(B) Unzip the Gigabyte Flash utility & X800 XT BIOS, then place the files on the floppy disc.
© Restart the PC with the floppy disc inserted & boot in DOS.
(d) Once activity has ceased you will be at the A: prompt, type the following command line to flash the BIOS:
GVF11 -p -f A:r80x256v.f1
(e) Remove the floppy disc & reboot the PC.
To flash to the ATI Retail X800 XT BIOS, for improved over clock (Floppy 'A')
(a) Insert floppy disc 'A' into into the floppy drive (leaving existing files in tact).
(B) Place the downloaded Retail ATI X800 XT BIOS ( X800XT.bin ) on to the floppy.
flashrom -p -f 0 X800XT.bin
I recommend you retain the 2 floppy discs for future use.
If you have followed the instructions carefully you should have a fully fledged ATI Radeon X800 XT 520mhz core / 560mhz memory.
Due to the heat generated by the additional 4 pipelines your maximum core over clock is likely to be reduced by on average 20mhz
FORM http://china.sapphiretech.com/forum BY drpeppir
jason-c
樓主! 這個是舊消息囉!
X800 PRO VIVO 可以改BIOS成X800 XT PE
但是現在要買X800 PRO VIVO越來越難了, 大部份都是X800 PRO
lada0953
= =小弟的就是這一張 原本那一張被改到冒雪花
送展�= =變新的回來 愉快開16管使用中
快1年摟
Arbicool
來自千年後的異界
造訪網站
某版主是變身高手 ;x;
Schumacher.
其實我一直在懷疑前陣子那批X800XT是X800PRO VIVO變身後,在重新包裝後賣出.
體質更好的X800PRO VIVO甚至被變身成X800XTPE在賣出!
以上純屬猜測!不過可能性也很大!
如果真是如此那賺取的利潤真是雄厚!
北京小胡
消息是旧了点,我还是从蓝宝石的官方论坛上帖过来了...
嘿嘿...有什仄s东西,我也会即时帖过来的...
在北京,我们公司经营ATI全系列显卡,从古老的RAG128到至今的X850XT...
不过再过几天就要辞职了...
对ATI的产品依旧会继续关注...不舍得放弃快两年了...
jeffchen
jeffchen1204.spaces.live.com
Originally posted by Arbicool@Jul 23 2005, 05:05 PM
某版主是變身高手 ;x;
素水啊~ 偶怎麼不豬道 :o||:
