【檔案名稱】:VideoHIVE Wedding Projects Package for After Effects 婚禮系列集合包
【軟體語言】:N/A
【軟體類型】:模板素材
【檔案格式】:RAR
【檔案大小】:1.65GB (解壓後的大小)
【壓縮密碼】:無
【上傳空間】:Filepost/Crocko/Filejungle/Filesonic/FreakShare
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
[font=標楷體]這是VideoHive公司出品的影視電視廣告等影視後期包裝模板素材婚禮系列集合包。
Videohive Wedding Projects Pack 的婚禮視頻模板,以After Effects 為主,包括工程文件,腳本,模板等等。
你只需要添加圖像 /視頻 /編輯文本AE炫麗工程文件是學習和使用AE最好的資源,對後期製作專業人士有極大的幫助作用。
Happy Wedding
http://videohive.net/item/happy-wedding/310112 視頻預覽
This is my latest project. This is perfect for your “Wedding Movie” Openers. You just add your images/videos and edit text and its ready for render. Hope you find it useful.
Main features are:
■CS4 , CS5 compatible.
■No plugin required.
■HD resolution 1280×720
■11 placeholders
■0:44 minutes long
■Instructions file included.
La Vie en Rose - Wedding template
http://videohive.net/item/la-vie-en-rose-wedding-template/542940視頻預覽
“La vie en Rose” is a marriage / Valentine’s template. A romantic atmosphere filled with rose petals and soothing feelings! Great for sauna, massage, health & beauty treatment centers & spa resorts!
* 9 Images/videos Placeholders (Very easy to replace!)
* 10 texts (Link to download font is provided)
* Pdf help file & video tutorial
* No external plugins needed to render this file (Works even with the demo version of After Effects)
* Rapid rendering
Wedding Particles Words
http://videohive.net/item/wedding-particles-words/139827視頻預覽
Wedding Particles Words CS4 project file can be used for a movie wedding intro, or simply to display your pictures and video if you re photographer or videographer.
Wedding Flowers CS4
http://videohive.net/item/wedding-flowers-cs4/309125視頻預覽
Wedding Flowers is an image video gallery with a total of 17 place holders, and 12 animated flower elements ready to use in other projects.(the flowers element are in a project a part so you can import in future projects).
The Project fas been realized with customization in mind, in the main comp you can adjust value like BG color, picture frame color, opacity,size,light color, and more.
Custom particles are provide in the project ready to use by switching on/off layer and decide the shape of particle text transitions,and the overhaul particles.
Frame for landscape or vertical aspect ratio of picture are provide if you want to insert different orientation pictures.
4 short tutorials explain how to change text, replace image, customize the scene and elements,and finally add more place holders.
The script Expression Universalizer has been applied on this file, so you shouldn’t receive any error due to expression when you open in a non english version of AE.
The native format is 1080p, 29,97 FPS , Square pixels.
Wedding Slideshow v2.0
http://videohive.net/item/wedding-slideshow-v20/152298視頻預覽
Version 2.0 is finally here! This new and improved version of wedding slideshow is a great way to show off engagement pictures, wedding pictures, or even just to show someone how much you care about them.
Wedding Moment
http://videohive.net/item/wedding-moment/423779視頻預覽
Make your moment eternal, with this smooth and elegant project.
‧ 1:55 min of After Effects CS4 / CS5 animation in Full HD ( 1920 X 1080 px ).
‧ 27 placeholders for your photos and videos.
‧ The project was created in modular structure in 20 independent scenes.
‧ Complete helpful instructions. Very easy to use! ( File with comments and tips )
‧ 5 resolutions options pre defined, ready to render! *FULL HD ( 1920 X 1080 ) *HD ( 1280×720 ) *DV NTSC Widescreen ( 720×480 ) *DV PAL Widescreen ( 720×576 ) *Half Size ( 960×540 )
‧ No Plugins needed, however Cycore plugins that comes with the After Effects, must be installed. If you haven’t, just turn off the layer responsible for making little spheres particles. Flares was made with the VideoCopilot Optical Flares plugin, however the file comes with pre rendered version and original plugin version, if you need change anything.
‧ The original photos used in preview are not included. Can be easily replaced by yours.
Zip Contains
‧ Wedding_Moment_VC_plugin.aep ( VideoCopilot Optical Flares plugin )
‧ Wedding_Moment_Pre_Rendered.aep ( Pre Rendered version )
‧ PDF Help file
‧ 27 generic JPGs / 2 assets files
‧ 1 Mov with pre-rendered flares
Weddings Particles
http://videohive.net/item/weddings-particles-cs4-project-file/125019視頻預覽
Wedding Particles,is a CS4 + After Effect file where you can display 10 media place holders.
Wedding ScrapBook
http://videohive.net/item/wedding-scrapbook/114557視頻預覽
This Wedding Slide Show is entirely made in after effects and use his standard tools.[/font]
下載地址: (等待5秒再按下右上的Skip AD/HIDE FRAME就可到下載頁)
Filepost載點
Crocko載點
Filejungle載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載
JDownloader載點 || JDownloader後備載點
各空間等待時間為10至30分鐘,本身是該空間之Premium用戶則無以上問題
請勿使用續傳軟體抓取(如迅雷、Flashget等等),以免抓取失敗或抓到不完整檔案
[更新]WinRAR 4.0.1 Pro 32bit&64bit
4.0.1載點 || 4.0.1後備載點
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
1.僅供網路測試無任何販售行為及獲得任何利益!請於測試完後24小時以內將檔案刪除!
2.請支持正版!本檔案的提供純為試看用途,請勿作商業上之用途!!!!請於下載完後24小時以內將檔案刪除!!!
【軟體語言】:N/A
【軟體類型】:模板素材
【檔案格式】:RAR
【壓縮密碼】:無
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
Happy Wedding
Main features are:
■11 placeholders
■0:44 minutes long
* Rapid rendering
Wedding Flowers CS4
Wedding Moment
Zip Contains
‧ PDF Help file
Weddings Particles
Wedding ScrapBook
Filepost載點
Crocko載點
Filejungle載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
