請教各位大大 UT X58 的問題!!!謝謝><~
kye7721
以下是小弟跑4G開HT的BIOS設定
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled<<<<<<<<<<是否要開?
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1024M<<<<<<<<<<<<是否要設1536??
DRAM Command Rate: AUTO/1N/2N
CAS Latency Time (tCL): 8
RAS# to CAS# Delay (tRCD): 8
RAS# Precharge (tRP): 8
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Disable O.C.S.D.F<<<<<<<<<<是否要開?
CPU VID Control: 1.375V<<<<<<<<<<<<<<<<<電壓要如何降><~
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.65v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.52v<<<<<<<<<<<<<<<<<電壓要如何降><~
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.23v<<<<<<<<<<用預設的就好了嗎?我調1.11V與1.23V感覺差別不大@.@~
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: 4.8GT
CPU Base Clock (BCLK): 200 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: 2000Mhz
UnCore Frequency: 4000MHz
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
小弟的硬體:
CPU:INTEL I7 920 D0 3921A631
CPU COOL: Thermalright Ultra-120
M/B: DFI UT X58 BIOS:0619版<<<<<<<<<<<<<<<<<<<要換版本會比較好超嗎?
RAM: 金士頓 DDR3 2000 1G*3 8-8-8-24 1.65V(跑2:10)
POWER: 振華冰山旗艦 650W 80+
HD:WD SATA2 160G YS
VGA: ASUS 4670 512MB HDMI
機殼: 偵查兵
OS: WIN7 X64 17600版
問題:
1.Virtualization Technology: Disabled<<<<<<<<<<是否要開?
2.Memory LowGap: 1024M<<<<<<<<<<<<是否要設1536??
3.O.C. Shut Down Free: Disable O.C.S.D.F<<<<<<<<<<是否要開?
4.CPU VID Control: 1.375V<<<<<<<<<<<<<<<<<電壓要如何降><~
5.CPU VTT Voltage: 1.52v<<<<<<<<<<<<<<<<<電壓要如何降><~
6.IOH/ICH 1.1V Voltage: 1.23v<<<<<<<<<<用預設的就好了嗎?我調1.11V與1.23V感覺差別不大@.@~
7.M/B: DFI UT X58 BIOS:0619版<<<<<<<<<<<<<<<<<<<要換版本會比較好超嗎?
8.上4G後,待機溫度平均48~52度,跑 8 PI 32M(可跑完沒錯誤)升到86~92度..這樣正常嗎?(有開HT)
但跑OR卻只能跑二分鐘後..就火山了><~
以上問題,煩請大大教賜!!感謝!!!!
ctsun
Paradise in heaven
920要燒機散熱要做好....
因為會很燒!
稍稍回答你問題
1.Disabled
2.1024M
3.Disable
4.視CPU體質
5.視CPU體質
6.加一格或不加
7.不用
8.正常
kye7721
感謝CTSUN回應..但..文中的第6點"加一格或不加"
這句不懂...是指1.1V+0.1..還是1.23+0.1??????
ioh/ich auto就好
kye7721
OK~C大的建言..小弟收到..^^謝謝!
