以下是小弟的硬體設備:
CPU: I7 920 D0
記憶體 HyperX DDR3 ULT1 2000 1G*3 8-8-8-24 1.65V
主機板: LANPARTY UT X58-T3eH8
顯示卡: MSI 4850 OC 512MB
電源: 振華 650W 80+
CPU散熱器: Thermalright 120
OS:WIN7 64 7600版
BIOS設定:~~版本 0619 ~~
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1024M
DRAM Command Rate: AUTO/1N/2N
CAS Latency Time (tCL): 8
RAS# to CAS# Delay (tRCD): 8
RAS# Precharge (tRP): 8
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Disable O.C.S.D.F
CPU VID Control: 1.36V
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.65v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add:
CPU VTT Voltage: 1.48v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.1v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: 4.8GT
CPU Base Clock (BCLK): 200 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: 2000Mhz
UnCore Frequency: 4000MHz
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
以上是BIOS與硬體設備,想請教一下..為什麼無法穏定跑3通道DDR3 2000??
小弟改用雙通道就可以跑DDR3 2000 可跑完8PI 32M 與IBT 10圈??而三通道卻不行??這樣的問題是出在....???煩請敎導一下..感謝!!
CPU: I7 920 D0
電源: 振華 650W 80+
OS:WIN7 64 7600版
BIOS設定:~~版本 0619 ~~
CPU Feature
x TDC Limit: 0
x TDP Limit: 0
DRAM Timing
Voltage Setting
PCIE Clock: 100 Mhz
