Uniblue Registry Booster (2010) Ver. 4.5.0.18 + Full Seria
rapidmoon
代碼:
Info:
How many errors does your computer have?
You no longer need to guess! This free stability scan will give you a complete diagnosis of your Windows registry, identifying errors and conflicts.
The Problem
Have you noticed that the longer you have your computer, the slower it runs and the more it crashes? Often this is because whenever you install or uninstall software, add or remove hardware, or change your computer’s settings, the Windows registry is updated. These changes can leave the registry fragmented, with obsolete, corrupted and, in some cases, harmful files. Over time the registry starts to get bogged down and conflicts emerge. Left unchecked, your system will become increasingly unstable, run more slowly and crash more frequently.
The Solution
RegistryBooster is the easy answer to all your Windows registry problems. This award winning software starts by conducting a deep scan of your registry, checking for file extension errors and other registry conflicts. RegistryBooster will then repair or remove unused, corrupted and harmful files so optimizing your PC’s performance. You can then use regular scans to keep your registry structured and your PC speeding along at peak efficiency. With RegistryBooster you’ll see immediate increases in performance and decreases in system conflicts.
Key Benefits of RegistryBooster 2010
Clean Your System and Boost Performance
Boost system performance by cleaning out all missing, unwanted, obsolete and corrupt registry entries automatically with RegistryBooster.
Repair Your PC and Keep It Tuned
Dramatically improve your computing experience by repairing all registry problems and minimizing application seizures and crashes.
Exceptionally Simple to Use
Set in a highly intuitive, attractive, logical and user-friendly graphical user interface, Uniblue's registry cleaner sets the standard for ease-of-use.
More Scanning Options
Due to the improvements made to the scanning engine you are now able to scan for more sections within the registry.
An Ignore List
This is quite an innovative feature and very useful for those users who are extra cautious with their registry. By specifying the registry section and path the user will be able to exclude registry parts from the scan.
Log Generation
Displays a transcript of all the actions performed on the registry by a particular fix operation. Especially helpful for those users wanting to know what has been done to their registry.
Windows Vista Compatible
RegistryBooster is now fully Windows Vista compatible and can still be run on Windows XP. The program automatically adapts itself according to the version of your operating system so you do not have to configure any manual settings.
Safe and Trusted
Avoid crashes, seizures, slow downs and error messages with the safest and most trusted solution from a leading software vendor.
System Requirements for RegistryBooster 2010
Intel Pentium 3 500MHz or equivalent processor
At least 256 MB RAM
100 MB free hard disk space
Graphics mode 800x600, 256 colours
Internet Explorer 6
Microsoft Windows XP / Vista / 7
Recommended system requirements:
Intel Pentium 4 1GHz or equivalent processor
512 MB RAM
200 MB free hard disk space
Graphics mode 1024x768 true color (highest 32-bit)
Internet Explorer 6
代碼:
Download Link: (Rapidshare)
http://rapidshare-mm.blogspot.com/2009/12/part1_02.html
No Pass
noavkitty
www.wretch.cc
tsai0915
感謝樓主的大力分享~ 吼 找有夠久的拉!!! 終於扒到了 ^^
