[轉貼官網原文~~~]
Ultimate Boot CD lets you run diagnostics from CD, not from an unwell hard drive or a series of teeny floppies. You can create a boot CD with any of a variety of hard drive diagnostics, hard disk management programs, memory diagnostics, Linux-based rescue discs, and more.
You need the Ultimate Boot CD if you want to:
* Run floppy-based diagnostic tools from CDROM drives. More and more PCs are shipped without floppy drives these days, and it is such a royal pain when you need to run diagnostic tools on them.
- Free yourself from the slow loading speed of the floppy drive. Even if you do have a floppy drive, it is still much much faster to run your diagnostic tools from the CDROM drive, rather than wait for the tool to load from the floppy drive.
- Consolidate as many diagnostic tools as possible into one bootable CD. Wouldn't you like to avoid digging into the dusty box to look for the right floppy disk, but simply run them all from a single CD? Then the Ultimate Boot CD is for you!
- New! Run Ultimate Boot CD from your USB memory stick. A script on the CD prepares your USB memory stick so that it can be used on newer machines that supports booting from USB devices. You can access the same tools as you would from the CD version.
When you boot up from the CD, a text-based menu will be displayed, and you will be able to select the tool you want to run. The selected tool actually boots off a virtual floppy disk created in memory.
Tools currently included in the Ultimate Boot CD
Changes in version 4.0 :
- This version uses syslinux V3.36 instead of CDShell due to the latter's compatibility issues and lack of new development.
- Removed INSERT/UBCD as integration of a Linux distro is thought to be best left as a customization option. This means there is now only one version of UBCD instead of two (basic/full).
- Introduced experiment support for writing UBCD to a USB memory stick (UBCD2USB).
- Added PTDD Super Fdisk V1.0. Thanks to coco7 for the suggestion.
- Added EASEUS Disk Copy V1.0. Thanks to coco7 for the suggestion.
- Added BugHunter V1.9.3.
- Added Intel Processor Identification Utility V3.1.20060901. Thanks to Zilli Samuel for the suggestion.
- Added ViVARD V0.4. Thanks to alm to the suggestion.
- Added COPYR.DMA Build 013. Thanks to alm to the suggestion.
- Added SUTIL V1.01. Thanks to alm to the suggestion.
- Added HDAT2 V4.52. Thanks to alm to the suggestion.
- Added UDPcast. Thanks to Andrius Kazimieras Kasparavicius for the suggestion.
- Added CopyWipe V1.14. Thanks to stidyup for the suggestion.
- Re-added HUTIL V1.21. Thanks to soeren for the suggestion.
- Added dummy menu item for Volkov Commander. Thanks to kethd for the suggestion.
- Added Cute Partition Manager V0.9.5.
- Added DIMM_ID V3.01. Thanks for kethd for the suggestion.
- Make XOSL run from RAM disk, otherwise installation cannot proceed. Thanks to BootyM for the update.
- Updated Partition Saving to V3.20. Thanks to SebastianG for the update.
- Update HDClone to V3.1.12. Thanks to A J for the update.
- Updated Drive Fitness Test to V4.08. Thanks to SebastianG for the update.
- Added LZ-DOS boot disk from Erwin Veermins.
- Updated various FreeDOS boot disks from Erwin Veermins.
- Updated IBM Feature Tool to V2.04. Thanks to SebastianG for the update.
- Updated TestDisk to V6.6. Thanks to Christophe Grenier for the update.
- Updated Super Grub Disk to V0.9575.
- Updated GWSCAN to V5.11. Thanks to A.J for the update.
- Updated GAG to V4.6. Thanks to A J for the update.
- Updated BasicLinux to V3.40. Thanks to Reinhard Max for the instructions.
- Updated Boot Partition to V2.6. Thanks to Zilli Samuel for the update.
- Updated Offline NT Password & Registry Editor to 060213. Thanks to SBanzai for the update.
- Updated SPFDISK to 2000-03t. Thanks to SebastianG for the update.
- Updated XXCopy to V2.93.1. Thanks to SebastianG for the update.
- Updated Gujin to V1.5. Thanks to SebastianG for the update.
- Updated ATAPICD to V2.22. Thanks to Dmitry Stefankov for the update.
- Updated Darik's Boot and Nuke to V1.0.7. Thanks to SebastianG for the update.
- Updated DLG Diagnostic to V5.04f. Thanks to Zilli Samuel for the update.
- Updated Data Lifeguard to V11.2. Thanks to Zilli Samuel for the update.
- Updated ExcelStor ESTest to V3.80. Thanks to Zilli Samuel for the update.
- Updated DOS Navigator to V6.4.0. Thanks to Zilli Samuel for the update.
- Updated Samsung HUTIL to V2.03. Thanks to alm for the update.
- Updated CHZ Monitor Test to V1.01. Thanks to nynyny for the update.
- Updated datapol-technologies NTFS4DOS (Freeware) to Avira NTFS4DOS Personal V1.8 due to merger of datapol-technologies and Avira. Thanks to PsiMoon314 for the suggestion.
- Updated PCISniffer to V1.5. Thanks to SebastianG for the update.
- Updated NNSI to V0.59.9. Thanks to Zilli Samuel for the update.
- Updated CTIA to V2.7. Thanks to Zilli Samuel for the update.
- Updated Astra to V5.21. Thanks to SebastianG for the update.
- Removed UniFlash V1.40. Decided that it is best left as a customization option.
- SCSIMax version number should be 1.21. Fixed. Thanks to Zilli Samuel for the correction.
- Lucifer has been removed.
Homepage
http://www.ultimatebootcd.com
Download - Size : 95.1 MB
ftp://192.231.203.131/diagnostics/ubcd411.exe
Mirror
http://www.pharry.org/data/ubcd411.exe
Mirror
http://www.grab-me.de/public/ubcd411.exe
Homepage
Mirror
Mirror
