http://mixim.myweb.hinet.net/BUMI TMPGEnc.40.XPress.v462266.rar
TMPGEnc XPress 4.6.2.266零售版(HINET@SMG@28.3M)
主要加入支援NVIDIA的CUDA功能(加速轉檔)
【官方來源】:BT
【結合程式】:WINRAR
【空間位置】:HINET
【分享時間】:10天
【補檔時限】:10天內
【下載程式】:IE、SMG、FG等
【解壓密碼】:請參文後
【檔案大小】:28.7MB
【檔案格式】:RAR
【內容說明】:TMPGEnc XPress 4.6.2.266零售版
PS:快樂檔使用方式
1-先安裝46.2.266版
2-先開啟一次程式 然後不要注冊
3-開啟KEYGEN
4-在Version的地方 將4.5.1.254改成46.2.266
5-按下Generate
6-在按下面的patch即可破解使用
TMPGEnc 4.0 XPress encoder is now twice as powerful as before. Offering the most common file formats including HDV import/output along with DivX 6 AVI, MPEG-1/2/4, QuickTime (MOV), and Window Media (WMV/WMV-HD/WMA) input/output.
TMPGEnc 4.0 XPress gives you the freedom to take almost any video file and encode it to your desired file format including DivX, AVI, QuickTime, MPEG 4-ISO, H.264, DVD-Video, DVD-VR, HDV camcorder, Blu-ray Disc and much more. This powerful software provides you with functions and features ranging from a simple cut-editor tool to multiple powerful video filtering and effects. Now with NVIDIA CUDA™ support!
TMPGEnc 4.0 XPress gives you an easier way of encoding with 4 steps: Start, Input, Output, Encode, along with settings template so you don’t waste your time figuring out the spec settings. Now it doesn’t take a video guru to be able to encode video; with the simple user interface, workflow is a lot more enjoyable.
• Convert Almost Any Video File!
TMPGEnc 4.0 XPress excells at converting video from one format to another. Got a Media Center recording that you'd like to convert to DivX? Or maybe you have a DivX file you'd like to convert to DVD-compliant MPEG? TMPGEnc 4.0 XPress can do it all, and you'll have complete control over the output settings. You can even make your own custom output settings!
• NVIDIA CUDA Support! NEW!
If you have a NVIDIA CUDA™ compatible graphics card, you can unleash the power of the GPU's multiple cores to crush the processing time for decoding and applying video filters! (Speed increases are dependent on your hardware environment and are not guaranteed.)
• Edit Your Video
TMPGEnc 4.0 XPress includes plenty of tools to enhance your video. Use the cut-editor to cut out unwanted scenes. Add filters to correct color, crop the picture, resize, sharpen, deinterlace, reduce noise, and more!
• AVCHD input support!Convert Your AVCHD Footage! NEW!
The popular AVCHD video format is now officially supported as an input source! Easily take your AVCHD footage and convert it to other video formats such as DVD-Video!
• Blu-ray Disc output Blu-ray Disc Encoding! NEW!
We've added a new output template for the Blu-ray Disc format! Convert your video into BDMV or BDAV compliant MPEG-2 video and maintain the quality of your high definition footage!
Main features:
• H.264/MPEG-4 ISO output (Standard and High Definition)
• High Definition Video support and encoding template
• 19 Audio and Video Filters
• High Speed Thumbnail Navigation
• Smart Scene Search™
• MP3 input/output
• QuickTime output
• Officially licensed DivX® video software product
• Creates high-quality DivX® video
• Flash Video input support
• Multi core CPU support
• SlideShow creations
• DVD Video Subtitle support
• Support for Intel® Core™2 Extreme quad-core processors
New Features:
• Utilize NVIDIA CUDA™ For Filtering and Decoding NEW!
NVIDIA CUDA technology is now supported for processing the video filters and decoding. The multiple cores of the GPU can divide the workload and run the processes in parallel for a huge boost in processing speed over your computer's CPU*. This lets you apply multiple filters such as video noise removal (time), smart sharpen, color correction, and more without having to add hours to your output time!
*Speed improvements are dependent on your hardware specifications.
The GeForce8800 GTX/GTS video card using the G80 core is not currently supported. Thank you for your understanding.
Decoding benefits apply to MPEG-1/2 video only and may produce unexpected video output quality compared to regular CPU decoding.
You can activate NVIDIA CUDA processing by going to Options > Preferences > NVIDIA CUDA 2.0.
To learn more about NVIDIA CUDA technology, CUDA enabled graphics cards and graphics card drivers, visit NVIDIA's website.
• Performance Optimization Feature NEW!
You can choose to optimize your CPU and CUDA performance based on your hardware when you start up the program. This allows the video filters to use the processing method that will obtain the best results, increasing the performance of your hardware and saving you time.
• Real Time Processing Rate Display NEW!
During output, the processing performance of the CPU and CUDA processors are displayed so you can see how much your computer is utilizing them. These results are not cumulative and only display the current processing rate.
• Test results show impressive performance gains NEW!
In the beta version, application performance has been increased by up to 446% with CUDA technology, compared to the Intel Core2Quad Q9450, a top-of-the-line CPU. This demonstrates that CUDA technology will have a major impact on encoding speed, which requires a lot of filter processing.
Changes in TMPGEnc 4.0 XPress Version 4.6.2.266 - October 29, 2008:
Added - NVIDIA CUDA 2.0 support. Can be used with filters and the MPEG-1/2 decoder. CUDA-capable graphics card required. For more information on CUDA, CUDA supported video cards, and downloading the latest drivers, please see NVIDIA's website.
Fixed - For AVI codec output quality, keyframe interval and bitrate would not function properly.
Fixed - Deadlock could occur when using the VFAPI file reader.
Fixed - Green blocknoise could sometimes appear when importing a MPEG-2 PS file through the MPEG file reader.
Fixed - Some MPEG file aspect ratios could not be properly determined.
Fixed - Imported AAC audio would be delayed by several milliseconds.
Fixed - MPEG-2 TS file importation would fail when the stream header contains garbled data.
Fixed - An error would occur during the output when joining several clips with different YUV colorspace.
Fixed - The MPEG tool would output a LPCM file with a *.tlp extension when demultiplexing.
Fixed - Other minor issues have been fixed.
下載位置:
解壓密碼:
【官方來源】:BT
【結合程式】:WINRAR
【空間位置】:HINET
【分享時間】:10天
【補檔時限】:10天內
【下載程式】:IE、SMG、FG等
【解壓密碼】:請參文後
【檔案大小】:28.7MB
【檔案格式】:RAR
PS:快樂檔使用方式
1-先安裝46.2.266版
2-先開啟一次程式 然後不要注冊
3-開啟KEYGEN
5-按下Generate
6-在按下面的patch即可破解使用
• Edit Your Video
Main features:
• MP3 input/output
• QuickTime output
New Features:
下載位置:
解壓密碼:
bumi_by_fdzone.org@南英論譠@SW
