談到測試...不管是那國人的測試,已經免不了來個super pi mod 1.5
super pi測試從16k~32m長度不等. 要真正穩定.只有測上32m才知
多年前曾有人把super pi批評成粗糙不負責的測試.只有prime95才是唯一
這種要命的觀念實在是很遭糕.試想如果連電腦最基本的浮點運算都不能勝任
就算你把整個系統能100% loaded 滿載24小時,那又如何?
user買電腦來不是只得燒機,天天一直燒機?但是許多程式卻都是浮點運算的變形
真正要讓電腦發揮它的功能才是你買電腦的目的. 當然求一切環境穩定當然要燒機也得prime一下
但卻不是把電腦攪到生不如死,遊走在虛脫的邊緣吧?
super pi講究的是靈活的系統記憶體運用和個人對系統校調的認知程度;這就是為啥同樣的速度,為啥可以相差很多...super pi講的是效能加效率...prime95講的是熱的承受及烤打..那一種比較粗糙
並不是反對prime95或是sp2004, orth0...而是我們要對各種工具有既定的認知...這樣來調自己所滿意的系統才不會最後還一知半解!!
狂少今天就是要從頭講起,大家才會有整體印象..
所以我們就從super pi的最佳放置處一步一步來...
1.把super pi整個檔案夾 COPY到不同於作業系統的分割槽
最好是與分頁檔同一槽..通常我都設在D,
分頁檔最好不要設在C...而且設512~512是最好的(對PI而言啦)
將以下文字(虛線之間)
copy,貼在notebook.exe
存成opbtweakpi.bat....
目的是在暫停一些不必要的干擾服務和動作
@echo off
reg add HKLM\SYSTEM\CurrentControlSet\Services\upnphost /v start /t REG_DWORD /d 4 /f
reg add HKLM\SYSTEM\CurrentControlSet\Services\SSDPSRV /v start /t REG_DWORD /d 4 /f
Rundll32.exe advapi32.dll,ProcessIdleTasks
net stop "dhcp client"
net stop "dns client"
net stop "ipsec services"
net stop "task scheduler"
net stop "application layer gateway service"
net stop "automatic updates"
net stop "system event notification"
net stop "com+ event system"
net stop "computer browser"
net stop "cryptographic services"
net stop "distributed link tracking client"
net stop "error reporting service"
net stop "fast user switching compatibility"
net stop "help and support"
net stop "hid input service"
net stop "logical disk manager"
net stop "usnsvc"
net stop "network location awareness (nla)"
net stop "print spooler"
net stop "protected storage"
net stop "remote access connection manager"
net stop "remote registry"
net stop "secondary logon service"
net stop "security center"
net stop "server"
net stop "shell hardware detection"
net stop "ssdp discovery service"
net stop "system restore service"
net stop "tcp/ip netbios helper"
net stop "telephony"
net stop "terminal services"
net stop "themes"
net stop "webclient"
net stop "windows audio"
net stop "windows firewall/internet connection sharing (ics)"
net stop "windows time"
net stop "wireless zero configuration"
net stop "workstation"
start opbtweak.reg
再開一個新notebook.exe..save成opbtweake.reg
所以只要你每次執行 super pi 優化時這兩個洞作就會前後連接呼應
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer]
"AlwaysUnloadDLL"="1"
[HKEY_CURRENT_USER\Control Panel\desktop]
"AutoEndTasks"="1"
"HungAppTimeout"="5000"
"MenuShowDelay"="400"
"WaitToKillAppTimeout"="4000"
"WaitToKillServiceTimeout"="4000"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem]
"NtfsDisable8dot3NameCreation"=dword:00000001
"NtfsDisableLastAccessUpdate"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
"ClearPageFileAtShutdown"=dword:00000001
"DisablePagingExecutive"=dword:00000001
"LargeSystemCache"=dword:00000001
"NonPagedPoolQuota"=dword:00000000
"NonPagedPoolSize"=dword:00000000
"PagedPoolQuota"=dword:00000000
"PagedPoolSize"=dword:00000000
"SecondLevelDataCache"=dword:00000000
"SystemPages"=dword:000c3000
"PagingFiles"=hex(7):44,00,3a,00,5c,00,70,00,61,00,67,00,65,00,66,00,69,00,6c,\
00,65,00,2e,00,73,00,79,00,73,00,20,00,35,00,31,00,32,00,20,00,35,00,31,00,\
32,00,00,00,00,00
"PhysicalAddressExtension"=dword:00000000
"SessionViewSize"=dword:00000030
"SessionPoolSize"=dword:00000004
"WriteWatch"=dword:00000001
"IoPageLockLimit"=dword:00010000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters]
"VideoInitTime"=dword:000002ce
"EnablePrefetcher"=dword:00000003
"EnableSuperfetch"=dword:00000001
下一步;
長到run...打入msconfig,也就是系統設定公用程式.
看到'ˋ面有boot.ini 的tab, maxmem請填入616或624
好了之後請重新開機
界下來完全都是要實戰...
而且做錯一步是要從做
所以實戰部分務必攪懂...
...碰巧...e6850剛出...
狂少又踩到幸運狗屎....老外找到沒力都找不到...卻很簡單讓我一買就買到...
C大現在都叫我"B狂"了
先透露...這一顆...1.435v~1.46v...4g空冷一定穩定
而且外頻也沒啥組礙...真是B級大雕...等等一些例子全是用他當主要CPU
不要再鐵齒了...:D
將以下文字(虛線之間)
copy,貼在notebook.exe
目的是在暫停一些不必要的干擾服務和動作
@echo off
net stop "usnsvc"
net stop "server"
net stop "themes"
start opbtweak.reg
"AutoEndTasks"="1"
32,00,00,00,00,00
下一步;
好了之後請重新開機
界下來完全都是要實戰...
而且做錯一步是要從做
所以實戰部分務必攪懂...
...碰巧...e6850剛出...
C大現在都叫我"B狂"了
不要再鐵齒了...:D
