SLI 的窮人救星出來了, 939SLI-eSATA2 與 939SLI32-eSATA2
熱鬥小狐
939SLI-eSATA2
CPU - 939-Pin Socket Supporting AMD Athlon™ 64 / 64FX / 64X2 Processor
- Supports AMD's Cool 'n' Quiet Technology
- FSB 1000 MHz (2.0 GT/s)
- Supports Untied-Overclocking Technology
- Supports Hyper-Transport Technology
Chipset - ULi M1697
Hybrid Booster - CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Memory - Dual Channel DDR memory technology
- 4 x DDR DIMM slots
- Supports DDR400/333/266
- Max. capacity: 4GB
Expansion Slot - 1 x Future CPU Port (Supports CPU upgrade from AMD K8 939-Pin CPU to AM2 940-Pin CPU through AM2 CPU Board)
- 3 x PCI slots
- 1 x PCI Express x 16 / x 8 slot
- 1 x PCI Express x 1 x 8 slot
- 1 x PCI Express x 1 slot
- Supports NVIDIA SLI™
Graphics - n/a
Audio - Realtek ALC 660 5.1 channel CODEC with High Definition Audio
LAN - Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
Connector - 4 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, JBOD, and RAID 5) and "Hot Plug" functions
- 2 x eSATAII 3.0 Gb/s connectors (shared with 2 SATAII ports), support "Hot Plug" function
- 2 x ATA133 IDE connectors (support 4 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- CPU/Chassis FAN connectors
- 20 pin ATX power connector
- 4 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O ASRock eSATAII I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x COM Port
- 1 x Parallel Port (ECP/EPP Support)
- 4 x Ready-to-Use USB 2.0 Ports
- 2 x eSATAII Ports
- 1 x RJ-45 LAN Port
- Audio Jack: Line in / Line out / Microphone
BIOS Feature - 2Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories - Quick Installation Guide, Support CD, I/O shield
- Floppy/ATA 133 cables
- 4 x SATA data cables
- 2 x SATA 1-to-1 power cables
Form Factor - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS - Microsoft Windows 2000/XP/XP 64-bit compliant
Certifications - FCC, CE, WHQL
熱鬥小狐
939SLI32-eSATA2
CPU - 939-Pin Socket Supporting AMD AthlonTM 64 / 64FX / 64X2 Processor
Chipset - Northbridge: ULi M1695
- Southbridge: ULi M1697
- ASRock U-COP
- 3 x PCI slots
- 2 x PCI Express x 16 slots
- 1 x PCI Express x 4 slot
Graphics - n/a
LAN - Gigabit LAN 10/100/1000 Mb/s
- PCIE x 1 Realtek RTL8111B
Connector - 4 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, JBOD, and RAID 5), and "Hot Plug" functions
- 1 x IR header
- 1 x Game header
- CD in header
- Front panel IEEE 1394 header
Rear Panel I/O ASRock eSATAII+1394 I/O
- 1 x COM Port
- 1 x IEEE 1394 Port
- 2 x eSATAII Ports
- AMI Legal BIOS
熱鬥小狐
竟然還有754的,這次高中低檔全力出台 ;painkille
K8SLI-eSATA2
CPU - 754-Pin Socket supporting advanced 64-bit AMD Athlon™ 64 and 32-bit / 64-bit Sempron processors
- Chipset capable to FSB 1000 MHz (2.0 GT/s)
Chipset - ULi M1697
- ASRock U-COP
Memory - 2 x DDR DIMM slots
- Max. capacity: 2GB
Expansion Slot - 1 x Future CPU Port (Supports CPU upgrade from AMD K8 754-Pin CPU to K8 939-Pin CPU or AM2 940-Pin CPU through 939CPU Board or AM2 CPU Board)
- 3 x PCI slots
- 1 x PCI Express x 1 / x 8 slot
- Supports NVIDIA SLITM
Graphics - n/a
- 1 x IR header
- 1 x Game header
- CD in header
- 1 x COM Port
- 2 x eSATAII Ports
- AMI Legal BIOS
Form Factor - ATX Form Factor: 12.0-in x 8.2-in, 30.5 cm x 20.8 cm
glbi
潛水會員
造訪網站
939Dual sata2才剛買沒多久.....
效能有比較好在來考慮衝不衝
青春的肉體
造訪網站
939SLi32-eSATA2 是S-ATA II x 4 + eS-ATA II x 2 嗎~?
有IEEE 1394 又有三個PCI 擴充槽..
接下來就看超頻性能了~
已經迫不及待想看測試了~
dearest
請問esata2跟sata2有什麼差別?
enix
青春的肉體 說:
好像是外接式吧..
esata是sata外接裝置外接跟內接的接頭略有一些不同
enix
kain2000a 說:
這台灣買的到嗎??
華擎的板子只銷內地(大陸)不賣台灣.除非透過某人代購買回來 ;oplc;
